Inner fork tubes stuck
Discussion in 'XJ Technical Chat' started by Proar, Oct 26, 2016.
  1. Proar
    Proar Member
    Denmark
    so im trying to disassemble my fork tubes completely, and ive gotten the spring, bottom bolt and dampener rod out but when i try to pull out the inner tubes i hit a sort of bump, the pull out id say 95 percent of the way but then it stops. Ive removed the upper seal, o ring, and the bushing from the tubes but im unsure if there is any more to remove. If it help its the anti dive fork system
    Hope you guys can help
    Proar
    Yamaha xj750 seca 1983 uk
  2. Toomanybikes
    Tsawwassen bc
    And you have removed the spring clip under the dust seal that holds the oil seal ? Then it should pull out with a few pulls of the tube. Some times it requires a few hard pulls to get bushing to pop out
  3. Proar
    Proar Member
    Denmark
    The spring clip is out to. Spoke with my mechanic today and he also said it might be a bushing. I gues im just a bit nervous of being too rough
  4. hogfiddles
    The tube acts sort of like a slide hammer to drive it out from the inside.
  5. Proar
    Proar Member
    Denmark
    so before i go and do something stupid i need to be clear. mild violence is actually the answer for once?
    Stumplifter likes this.
  6. k-moe
    Yes.
    So long as this
    Which somtimes looks like this
    Has been removed.
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Mild violence?!
    Is that like no more than 3 cuss words per fork? ;)
  8. Kickaha
    New Zealand
    Seriously? People get by with just that?
  9. Bushy
    Bushy Active Member
  10. Proar
    Proar Member
    Denmark
    I got them of yesterday so yeah mild violence for president!
  11. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1.Good job.Inspect the entire front braking system and wheel/tire while you're there.
    Gary H.
