intake question
Discussion in 'XJ Modifications' started by Lou627, Nov 28, 2007.
  1. Lou627
    Lou627 Member
    Queens, NY
    If I put on pod filters and adjust jets correctly, how much fuel effeciency will I lose. Id guess a 25% increase in air = 25% increase in gas. Is this thinking right? Are these recommended for long trips, thats mainly what I ride. Am I just being vain because they look so sharp? If you guys suggest them is there much difference btw a $40 set and $100? Thanks, Lou
  2. cruzerjd
    cruzerjd Member
    Eugene, Oregon
    I went from mid 30's to 30 flat with pods and jstting, so figure about 16%. The difference between a $40 set of EMGO pods and a $100 set of K&N's is quality and longevity. The EMGO's are pleated paper with a wire mesh outer and glued on end caps. The K&N's are oil empregnated cloth material, with the end caps actually molded into the cloth weave. I have used both. On my Z1 i had K&N Ovals and they worked flawlessly, most EMGO pods are better than nothing but performance can be improved upon. I kow the guys over at Kawasaki triples Woldwide prefer the Uni foam filters for their 2 strokes. cruzerjd
  3. greengoon
    greengoon Member
    Chesapeake Virginia USA
    I used pod filters on my 81 XJ650. I got them off of ebay. I am getting 50 mpg now that I got the carbs almost right...
    That's running 80 miles a day at interstate speeds and running it hard!
    George
  4. Gbambeck1
    Gbambeck1 Member
    Richmond, Va
    I have the K&N Pods and the crancase filter just sitting here in a box... I think I'm goin gto try them out today and see how they do. I'm not sure if the carbs were jetted from the PO or not for the exhaust but here goes nothin...
