Is it really a XJ650 seat?
Discussion in 'XJ Technical Chat' started by Bluegray57, Jul 31, 2018.
  1. Bluegray57
    Bluegray57 Active Member
    US
    Some months ago, I bought an "advertised" XJ650 OEM seat off EBAY. My bike has the King/Queen seat and I was thinking about using the second seat as a swap out when desired. When it arrived I unboxed it, gave it a once over and set it aside. Recently I decided to pop it on the bike and give it ago but no joy. The tongue on the bottom front of the seat pan doesn't have enough clearance to slide under the back of the tank. i wiggled, jiggled, pushed and pulled but nothing I did allowed it to fit properly. Now I'm wondering if perhaps this came off an XS something or other but I'm not familiar with fitment details for the bikes.
  2. Toomanybikes
    Tsawwassen bc
    Pics of underside will help I have one here to compare.
    Bluegray57 likes this.
  3. Bluegray57
    US
    It's over at the storage unit. I will post photos later today.
  4. Bluegray57
    US
    Photos of Ebay seat
  5. Bluegray57
    US
    Photo showing front of King/Queen seat
  6. chacal
    That appears to be an XJ650 seat PAN, based on the release mechanism style. Cast into the pan is a set of letters/numbers, if you have those it would be able to make a positive ID.
  7. XJ550H
  8. XJ550H
    front of king seat
    XJ650 seat
  9. XJ550H
  10. Bluegray57
    US
    They dont appear to be. The K/Q seats fits nicely and slides right in. The standard seat won't slide forward at all
  11. Bluegray57
    US
    the plan is to have the seat recovered. I had cut away some of the covering to see if it would allow me to move it forward in place. Interesting that the pattern on top of the XS seat looks similar to mine.
  12. XJ550H
  13. Bluegray57
    US
    Maybe I need to file down the front tab on the seat a tad and see if it helps.
  14. Toomanybikes
    Tsawwassen bc
    That’s an XJ650 seat with the 4h7 number. Same as the one I have
  15. Bluegray57
    US
    There's something odd about the covering on the front of mine. I think its probably the cause of it not fitting properly. Since im going to recover it anyway, i think its time for a little surgery.
  16. XJ550H
  17. Bluegray57
    US
    After a closer look and a bit of surgery, I believe I found the issue. The foam at the front was curled under keeping it from resting forward on the tank. I didn't notice it until I cut away some of the covering.
  18. XJ550H
    does it fit and lock into place now?
  19. Bluegray57
    US
    Ill check tomorrow or Friday. The bike is at a temporary storage until i get my garage cleared out. There's no access to the facility after 6pm local.
  20. Bluegray57
    US
    I removed the entire cover and foam and was able to seat the pan properly and lock into place. It still took a little finagling. Just a tight fit. The new cover is on it's way.
