Jet positions XJ700 carbs
Discussion in 'XJ Technical Chat' started by Turbobob23, Jul 19, 2017.
  1. Turbobob23
    Turbobob23 Member
    Fredericton N.B. Canada
    Its probably on here somewhere but I can't find it. I've searched the net for just one picture of an XJ700 carb with exactly where the jets are positioned but no luck. I've taken the apart to lean then thoroughly but forgot to mark the exact placing of the jets that end up in the fuel bowl. I marked and positioned correctly the jets under the diaphragm but am now lost for the ones in that end up in the fuel of the fuel bowl. They are #107 or 40 marked on each.
    Any help is greatly appreciated
    Bob
  2. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    I don't have an XJ700.....but I believe the jet in the center of the float bowl is your main jet which would be the #107.....and the other jet is the pilot jet #40
  3. Turbobob23
    Turbobob23 Member
    The vague pictures I have seen to suggest that. Thank you fiveofakind. That's a big help.
  4. XJ550H
    the large jet main jet goes onto the emulsion tube which is under the needle and slide. small jet is pilot jet
