just got a maxim 550
Discussion in 'XJ Technical Chat' started by hughie1987, Mar 8, 2018.
  1. hughie1987
    hughie1987 Member
    pennsylvania
    So I picked the bike up for 150$, no title so far . no tank/seat an broke headlight glass. Guy said it was started about 6 months ago and sat for 5 or 6 years before that. So Im thinking clean the car and check all the fluids and brakes and try to get it started when I can. My plan is to make it a cafe racer to sit along side my cbr600rr.
  2. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Start with the information overload hour. Make it safe first, then customize/modify as you see fit and if at all possible avoid pods. The church of clean is the only way to go with the carbs
    Jetfixer and k-moe like this.
  3. k-moe
  4. hughie1987
    hughie1987 Member
    pennsylvania
    Oh I def plan on making it safe before anything else an making sure it runs right before throw a leg over. The front brake seems stuck so I'm going to check the fluid on that too haha. Anyone ever don't the Vermont method for a new title?
    Anyone recommend a good carb rebuild kit and engine gasket kit?
  5. hughie1987
    hughie1987 Member
    pennsylvania
  6. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    hughie1987 likes this.
  7. Jetfixer
    Good chance the piston is seized on front brake . Pull Caliper remove brake line try compressed air to try to push piston out by using a nozzle where brake line attaches . or if that does not work a grease gun threaded in the same mount and pump it full of grease till piston comes free. You will have to clean it out but replace the internal seal and dust seal. What ever you do ..DO NOT use a pair of hogs to try to remove piston it will chew it up with deep gouges effecting sealing . There is a good chance most bikes calipers have never been rebuilt so the seals are usually rock hard and pistons can corrode . Seal kits are cheap. Also you should replace the rubber hoses with braided steel lines XJ4ever has them, look at your lines if the have an 81,82 etc date on them REPLACE you will be on borrowed time.
  8. hughie1987
    hughie1987 Member
    pennsylvania
    SR500ED and TheCrazyGnat like this.
  9. hughie1987
    hughie1987 Member
    pennsylvania
    Gonna upload stuff to keep track of it on here like the fuse box has broken tabs 20180310_164812.jpg
  10. hughie1987
    hughie1987 Member
    pennsylvania
  11. wgul
    wgul Active Member
    Boston
    I did the VT reg loophole. There is a well know article that says you need to notarize the bill of sale. That is incorrect. Let me know if you have any questions on the process.
  12. hughie1987
    hughie1987 Member
    pennsylvania
    Thanks dude I saw there's a site with an all black background that says u don't need it notorized as well
  13. wgul
    wgul Active Member
    Boston
    I think you may be talking about this site with the black background.
    http://www.chinonthetank.com/2014/04/get-a-title-with-a-vermont-registration/
    It says you need to have the bill of sale notarized but VT registry does not require it. Really good site tho.
  14. hughie1987
    hughie1987 Member
    pennsylvania
    Carb pics ,opinions? Looks clean .. 20180311_123117.jpg 20180311_123117.jpg 20180311_123117.jpg 20180311_123127.jpg 20180311_123142.jpg 20180311_123222.jpg
  15. hughie1987
    hughie1987 Member
    pennsylvania
    Did not know the pictures would be this big when I uploaded them from my phone!
  16. Jetfixer
    Replace fuse block with a blade type fuse block .keeps wiring neat and keeps it looking like rednecks dream .
  17. Jetfixer
    I should have added your boots are not in real good shape. But you could smear them with fuel resistance RTV or an inner tube that is slightly smaller diameter cut to length and stretched over boot . Be cautious of the NEW boots on ebay they have been known to collapse internally . Another item be careful removing the boots the Allen bolts have been known to snap off and can be a bear to remove. If you get them out ok make sure you use anti seize on threads of new bolts do not re use as insurance they are not expensive read ACE hardware or Sears hardare store carry a nice selection of metric fasteers.
  18. MattiThundrrr
    Looks like someone stuffed muffin crumbs in the master cylinder!
  19. hughie1987
    hughie1987 Member
    pennsylvania
    I figured with all the screws etc I'm gonna take it slow so I don't snap anything , I hope
  20. hughie1987
    hughie1987 Member
    pennsylvania
    Yea it's really odd, not sure if I'll be able to get it all out of there or if I should just find another one
  21. hughie1987
    hughie1987 Member
    pennsylvania
    Anyone know if carb cleaner will eat away the floats? Im gonna tear the carbs to clean them soon and curious
  22. Jetfixer
    You need to do a full tear down of carb to bare body ...floats ,needle & Seat ,all jets , butterfly plate and throttle shaft removed , ALL rubber seals removed ...all of this entails "breaking the rack" each carb body after full tear down can the be soaked usually at least 1 hour per carb , followed by washing in hot soapy water and fully dried then you can reassemble carbs. Spray carb cleaner will not get into the tiny internal passages of carb ..especially if carb is really gummed up .
  23. cgutz
    cgutz Well-Known Member
    SE South Dakota
    I also believe (but may be mistaken), that carb cleaner/soaking may destroy the "ancient" shaft seals (and perhaps other small rubber bits inside). If the carbs are plugged/non functional, a full tear down, rebuild is in order.
  24. XJ550H
    your going to rebuild it so just drop it in a gallon of carb dip then use a strand of copper wire from a length of stranded wire to clean out the little holes in the well
  25. hughie1987
    hughie1987 Member
    pennsylvania
    I already planned on doing a full tear down of the carbs I was just curious if i could spray the floats and clean them. I wasn't gonna just spray cleaner in there and stick it back on the bike haha I started taking out the diaphragms last night :)
  26. hughie1987
    hughie1987 Member
    pennsylvania
    Cool I'll try that an see how it goes, when it gets warmer out anyway
  27. hughie1987
    hughie1987 Member
    pennsylvania
    3 outta 4 floats we're stuck an didn't move, the smaller Jets seem to be in here real tight I might spray something in there to try an break them free but what works!
  28. SR500ED
    SR500ED Member
    Smithville Ontario Canada
    Has anyone had luck using an ultrasonic cleaner, and what liquid to use. I'll be taking mine off soon and am dreading what I may find. When I put the bike away I couldn't drain the carbs as the drain screws were stuck.
  29. XJ550H
    Kroil is good for stuck parts. carb dip for soaking bodies start with spray cleaner to loosen the floats.
    ultra sonic cleaners work great
    fyi that brass tube does not remove but needs to be cleaned out
  30. k-moe
    Oooo. OEM brake fluid, aged to perfection. ;)
  31. SR500ED
    SR500ED Member
    Remember, brake flud should be changed every 2 years whether the bike is used or not.
  32. kosel
    MInneapolis, MN
    Tapioca in a master cylinder? I've not seen that mod before.
  33. kosel
    MInneapolis, MN
    I just did mine in heated, distilled water. They were first soaked in carb cleaner, then into the ultrasonic.
  34. XJ550H
    that way when you add more it does not spill onto your gas tank and ruin the paint
  35. hughie1987
    hughie1987 Member
    pennsylvania
    What brass tube? Are you talking about the emulsion stube? they pop out after you remove the jet, or are you talking about the skinny brass tube thats got a pin hole in the end? Can I spray carb cleaner into the smaller jet because 2 of them are really suck. And I need a way to push the pins out so I can remove the floats!
  36. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    The skinny tubes are best left alone, but take care not to damage them. Also, I had to use heat to shift the float pivot pins, high watage soldering iron did the trick.
    Numerous screws needed a tap with a punch.
  37. XJ550H
    tube with red arrow does not remove you need to use a guitar string to clear it. high e string or there are tiny brushes you can buy. you need the proper fit screw drivers to remove the removable jets NOT ALL JETS ARE REMOVABLE.
    you can remove the pilot air jet on the top of the carb the main jet and emulsion tube under it( large jet closest to float hindge) and pilot jet just infront of main jet. thats it.
    those jets in the rear throat of carb do not come out
    Cleaning your Mikuni carbs
    check your inbox for carb book with tips
  38. XJ550H
    float pin removal
    post.JPG keep spraying and soaking pin hindge before trying to remove it
    Minimutly and hughie1987 like this.
  39. hughie1987
    hughie1987 Member
    pennsylvania
    cool thanks for th ereplies now i just need to figure out how to get the 2 stuck smaller jets out! the slot looks kinda messed up on them, I got 2 out just fine I dont think my screw driver will do the job , what does everyone else do to get stcuk messed up jets out? is the metal soft enough that I can just tap my screwdriver into the jet til it bites?
  40. Minimutly
    West Wales, uk
    Well I used my plumbers blowlamp - it has a very accurate pointy blue flame, but I don't especially recomend it unless you know what your doing. An electric heat gun might be better.
  41. XJ550H
    soak it with kroil if the slots are messed up
    i ground down the sides of a screwdriver to get it to fit down the hole and ground down the end to nake a good fit into the slot of the jet.
    if you have to you can use a #1 screw extractor (no drilling required) use a tee handle to remove jet but keep soaking it in kroil untill you remove it. or you can pay a machine shop to extract it.
    keep in mind spare carb bodies run 20 to 30 dollars if you snap off the extractor.
    this is the wrong time of year to buy motorcycle parts on ebay as the prices climb the closer to spring you get.
  42. hughie1987
    hughie1987 Member
    pennsylvania
    Well I don't have kroio but got some PB an let it soak and used the 98cent screwdriver that fits perfectly into the slot btw,from Lowe's, an put pressure on it an cracked it loose! Gonna need a new jet tho how much are they haha 20180318_133406.jpg
  43. XJ550H
    not much but do not buy the ones with holes in the sides
    chacal sells them (len from www.xj4ever.com) start a conversation with him for a quote. he has throttle shaft seals too and any other part for carbs
  44. hughie1987
    hughie1987 Member
    pennsylvania
    20180410_194957.jpg so this is everything I've removed from the carbs, wasn't sure about the plunger with rubber grommet? The butterfly valves work and move perfect so I think it's pointless to remove them they move and spring back like new 20180410_195008.jpg 20180410_195027.jpg
  45. Jetfixer
    To replace butterfly seals you have to remove plate and slide shaft out a MUST do Item if you have broke the rack and ALL rubber seals need removed and carbs soaked in carb cleaner for at least 1 hour per carb , this is the true church of clean .....spray carb cleaner will not get into small passages of the carb to properly clean out gum and varnish deposits. Note xj4ever sells the proper shaft seals , you won't find these on eBay , or 2 #11 Buna O rings can be used .
  46. Chitwood
    You need to remove them to replace the seals that are in there or you will end up doing it all over again because of vacuum leaks
  47. XJ550H
    the screws are peened on the butterflys so they need to be filed down for removal. the plungers just unscrew with a socket
    Chitwood likes this.
  48. hughie1987
    hughie1987 Member
    pennsylvania
    Dont see anything in the clymer book about removing the butterfly shafts etc
  49. XJ550H
    thats because the standard practice was to sell you a new set of carbs. peened screws need a special tool to peen them . throttle shaft seals require the shafts to be removed to replace the 35 year old seals.
  50. hughie1987
    hughie1987 Member
    pennsylvania
    I have a dremel I could removed the peened ends with, gonna look up the seals an see where they are i guess haha thanks
