Leaky valve cover
Discussion in 'XJ Technical Chat' started by Colin 85 700, Aug 3, 2018.
  1. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    my valve cover started to leak recently, on the right side, sometimes after a lot of riding, my bike smells like burning oil.... Soooo not cool! Is it one of those rubber gaskets you can clean and re-use or is it going to crumble to oblivion when I take it apart?
    If I need new does chacal's store have an e-bay store that takes pay pal?
    Also, can someone post or point me to valve specs while it's off please
    Thanks in advance guys! Your all pretty awesome!love this site! :)
  2. Tim O
    Tim O Active Member
    Charlottesville, VA
    I replace the valve cover gasket with a NOS and was able to reuse donuts although folks tell you not to.
    Think it was like $35
  3. Colin 85 700
    Thunder Bay, ON
    Donuts? It has the little gaskets/o-rings on the bolts then I assume? If so ya, I've had good luck re using those before
    The doughnuts and gaskets can only be reused for so-long. They both harden with age. Of the two, the doughnuts are the ones that you want to be the most elastic, since they are what actually presses on the cover to seal the gasket. The half-moon part of the gasket benefits from the application of oil-resistant RTV to help them seal well.
    Tim O likes this.
  5. Jetfixer
    Ordering from xj4ever is either email chacal or start an IM message , yes he takes paypal , I ordered my gasket from him as well as the doughnuts (mmm doughnuts) .
  6. XJ550H
  7. hogfiddles
  8. Colin 85 700
    Thunder Bay, ON
    Excellent! Thanks guys! Will do on Tues when I'm back at the shop.
  9. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    2nd the suggestion of emailing xj4ever and reading the airhead valve adjustment *thoroughly*. I just did this very thing yesterday. New gasket, donuts, checked valves. Taking tuesday off to ride thru the rockies a bit, and enjoy the freshly buttoned up valve cover.
    Praxeus and Jetfixer like this.
  10. hogfiddles
    YAAAAAAY!!!!!!:D:D:D
    Jetfixer likes this.
  11. Praxeus
    Praxeus Member
    British Columbia
    A bit late on the uptake, but I just wanted to second (or third) the praise of BigFitz and the valve adjustment thread; without it and especially the pictures I would have never been able to do this job.
