Lithium battery regulator
Discussion in 'XJ Technical Chat' started by Karl9309, May 8, 2020.
  1. Karl9309
    Karl9309 New Member
    Montreal, QC, Canada
    Hi everyone,
    I have a 1982 XJ650RJ. I replaced the original lead-acid battery for a lithium ion battery Shorai (model: LFX14L2-BS12). I was wondering if it was dangerous or bad for the battery to use the original regulator? It works fine, the bike runs great, but haven't tried it for long distance yet.
    If it is not a good idea to use the original regulator, what should I buy?
  2. SQLGuy
    SQLGuy Well-Known Member
    From what I can see on their site, you should be fine with the stock regulator. I expect that they have a built-in circuit to handle balancing the charging of the individual cells.
  3. Polock
    why can't i put a cheap RC 4S, 4000ma 30C LiPo in my bike, i'm not sure why i need a expensive, official mc starter battery ....?
    l
  4. SQLGuy
    Well, for one thing, at 14.8V output from such a battery, your charging system won't be able to keep it fully charged.
  5. Polock
    i'm not sure it has to, my voltage stays around 13.8 to 14, a 4s charges around 16.8 so it just won't get to full charge.
    over charging is when things get tricky
  6. Karl9309
    Karl9309 New Member
    I've heard that the stock regulators will send higher voltage to the battery while the bike is running. For lead-acid batteries this is alright because it can handle the voltage. I've heard for lithium ion batteries anything above 14V will cause overcharging and can possibly overheat the battery. It can be bad with time and the batterie life will diminish.
    This is all that i've read. I want to know if this is all just a myth or is there actual proof that this is true
  7. Polock
    lipo cells charge at 4.2v/cell so a 4 cell would normally charge at 16.8. the most the bike could make if the regulator works is 14.?.
    i think if anything it might hurt the battery from being under charged, and it would waste a lot of battery capacity
    and i'm not sure 10 gauge wire on the battery would cut it
