Loud Ticking noise in XJ1100, goes away with rpm >~ 1200
Discussion in 'XJ Technical Chat' started by AlexS-XJ1100, May 30, 2021.
  1. AlexS-XJ1100
    AlexS-XJ1100 New Member
    Vancouver
    Hi Guys,
    The bike used to run great, but about 2 years ago a loud clicking noise noise started coming from the engine. Tried a stethoscope, but couldn't find the source of the noise. Performance was not inhibited by the tapping on the way home (the bike has NOT been ridden since this problem occurred). It starts up like you wouldn't believe even after sitting (I'm now a carb god), but the ticking still persists. The ticking is only persistent at 0-1100 RPM, and goes away past that.
    What have I done to address this problem?
    -Checked valve shim clearances, swapped, and ran (no change)
    -Grinded and inspected valves, checked tolerances (all good!?)
    -Inspected wrist pins in pistons (TIGHT!)
    -Inspected journal rods (TIGHT again!)
    -Inspected oil pump and oil hardline (good, lots of oil)
    I'm at a complete loss, where should I go next?
    Thanks in advance for the responses :)
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Have you adjusted the cam chain tensioner?
  3. AlexS-XJ1100
    Vancouver
    Yes, before and after this current disassembly. Done as instructed to in the service manual.
  4. FJ111200
    Slight blowing on one of the exhaust gaskets?
    Jetfixer likes this.
  5. AlexS-XJ1100
    Vancouver
    There doesn't appear to be any leaks, but that's something I can try once it's all back together again (though this tick is likely mechanical as it creates a noticeable vibration).
  6. FJ111200
    Crankshaft bearing?
  7. AlexS-XJ1100
    Vancouver
    I forgot one important thing:
    Ticking only occurs when there is compression. If spark plugs 1 or 4 are pulled, there is no ticking, 2 and 3 make no difference so I consider them to be "good" cylinders. as for if its 1 or 4, 1 has a dark exhaust which is indicative of a "burnt" exhaust valve. However, It still falls within proper specs as per service manual. I have no idea why pulling plug 4 would remove the ticking, but hey, thats why i'm here!
  8. AlexS-XJ1100
    Vancouver
    Oh god, I really hope not. I'm going to check that tomorrow.
  9. FJ111200
    Last thing i'm going to consider now , could it be the HT lead or plug cap shorting on the engine?
    I lied, are the pick up coils held firm?
  10. k-moe
  11. AlexS-XJ1100
    Vancouver
    Edit*** Can this tick occur near 0 RPM?
  12. AlexS-XJ1100
    Vancouver
    Found metal shavings in the strainer cover, oil also looks a little shiny. Maybe it's time to take the engine out...
  13. k-moe
    Yes, and engine noise can cover that sound as engine speed increases.
  14. AlexS-XJ1100
    Vancouver
    Here's a link to a video I took.
    No, the mic is not peaking: It's like a switch, the ticking is much louder than the motor, but goes away in entirety past 1200 rpm (with the occasional click near 1200 rpm).
  15. AlexS-XJ1100
    Vancouver
    Tight as can be
  16. FJ111200
    Listening to your vid, i would go back and check that you adjusted the cam chain tensioner properly.
    It could be at the end of it's adjustment.
  17. k-moe
    Agreed.
    If not that then the alternator chain guide is toast.
    It's definately the sound of a chain rubbing.
    StarGeneral likes this.
  18. AlexS-XJ1100
    Vancouver
    Cam chain was definitely adjusted properly before the tick, I had done it multiple times before with no issues. The cam chain tensioner operating properly with lots of spring force (pics attached). 48000 km, is it possible the cam the chain is toast already??? I'm not sure about the alternator chain itself (about 1/4-3/8" of slack), but guide has lots of meat left on er.
    On another note: engines already apart, and the bearings look old so i'm replacing them no matter what (along with all gaskets including exhaust). I cant find the crankcase numbers that are supposedly hand "etched" into the upper case. Any clue as to where they would be?
  19. FJ111200
    I suppose if the engine is apart then it would be a good opportunity to replace the cam chain with a new one and eliminate that. I replaced mine with a D.I.D. brand.
    Also, a lot of owners, me included, replace the original manual cam chain tensioner for an automatic one, i have on my XS, and i've fitted one from a 1200 V-MAX. Other models of Yamaha fit too and there was a complete list over at Forums - XS11.club Forums
  20. Franz
    Cam chain tensioner plunger looks quite extended in your photograph. How much more adjustment is left on it?
  21. AlexS-XJ1100
    Vancouver
    Ordered a DID chain, I could probably use a new tensioner, I'll look at getting an automatic.
  22. AlexS-XJ1100
    Vancouver
    Thats is currently at full extension, I don't know what it was like when I pulled it out unfortunately. It seems to be in order, so if it is a chain slappin around, It is likely the chain itself and not the tensioner.
    This video shows the noise a little better, pulling plugs 1/4 removes noise.
  23. Franz
    That is what I mean if the tensioner is fully extended when fitted it might not tension the chain at all hence the noise. I would try the tensioner on the engine fully extended to see if the case meets up with the cylinder block. Yes the noise is different with the plugs out.
  24. AlexS-XJ1100
    Vancouver
    Ah gotcha, glad we're on the same train of thought. I'll try putting the tensioner in later today.
  25. Franz
    Your other video when you rev the engine the chain noise (I assume) dissapeares and then starts again when the revs fall because it's rattling on the guides. If you refit the tensioner fully as stated, and take the cam cover off you might see slack in the chain when rotating the crank with a spanner. Move it a clockwise and anticlockwise. Perhaps the chain is so worn the tensioner while working properly is unable to tension it?
  26. AlexS-XJ1100
    Vancouver
    Thats why i'm so confused, I had the cover off and was doing exactly what you described, and the chain on the tensioner side did seem a little loose. I'm about to do a plastigauge on the bearings, I'll plop the head back on and double check the tension once that's done.
