Main jet washer dimensions (5mm vs 6mm ID)
Discussion in 'XJ Technical Chat' started by unplugged1981, Apr 20, 2026 at 5:18 PM.
  1. unplugged1981
    unplugged1981 New Member
    Canada
    Hi everyone,
    I’m currently working on my main jet seat of my 1981 Yamaha midnight maxim xj650 and need some advice on a replacement washer.
    The washer measures that is currently on my bike
    • ID: 5 mm
    • OD: 12 mm
    • Thickness: 1 mm
    I’m having a hard time sourcing that exact 5 mm ID locally, but I can easily find one with these specs on a Yamaha dealer not far from my place :
    • ID: 6 mm
    • OD: 12 mm
    • Thickness: 1 mm
    Since the outside diameter and thickness are identical, do you think that extra 1 mm of clearance on the inside diameter will cause issues with the seal or seating of the jet? I want to make sure I won't run into fuel bypass issues or have it off-center enough to cause a problem.
    Has anyone run a 6 mm ID washer in this spot before, or is it better to hold out for the exact 5 mm match?
    Thanks in advance
  2. Secacsm89
    Secacsm89 Member
    Hit up the pages on the website link XJ forever-at the top right on the website. I'm still working on my extensive rebuil,d with the carburetors myself.
  3. unplugged1981
    Canada
    thanks I’ll check that out!
  4. unplugged1981
    Canada
    Is there a specific page that deals with the characteristics of the main fuel jet washer?
    Also is it possible to put a brass washer?
