Many uses of the centerstand
Discussion in 'XJ Technical Chat' started by XJ550H, May 20, 2018.
  1. XJ550H
    lets you park more bikes in the garage.
    for the chain drive. chain clean lube and adjustment,
    replacing chain
    check oil level.
    changing oil so it drains more and not onto exhaust.
    tire changes.
    rear brake adjustment.
    MC fluid check and change so it does not spill on bike.
    final drive fluid check.
    valve shim check.
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    A few more:
    Keeps bike upright when parking on hot asphalt, dirt, or other soft surface.
    Cleaning rear tire and rim from grease from chain.
    My favorite:
    Sitting on bike and making 'vrooom' noises in cold weather and or rain.....
  3. k-moe
    Crushes aluminum (and steel) cans, flat.
    Makes pretty sparks when making a hard, fast left turn.
  4. Toomanybikes
    Tsawwassen bc
    Also makes pretty spark when you push it down when being tailgated
  5. XJ550H
    put a couple of theese on the feet
  6. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Makes your bike stand straight up amongst all the Harley's when parked. Kind of like the Pope with a hard on.
    cruiserlover likes this.
  7. Ribo
    Ribo Prefectionist
    Let's you put the bike on a table lift much easier and not worry about it toppling off and killing you.
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Makes matti jealous
  9. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Wait....
    So the Pope likes Harley's?
  10. Bluegray57
    Bluegray57 Active Member
    US
    Better stability when practicing for the "Two-wheel club".... (Think "Mile High Club")
  11. Bluegray57
    US
    and prevents accidents.....
  12. XJ550H
    ouch at least she cushioned the bikes fall
  13. Jetfixer
    show off to sport bike crowd and Harley crowd ...removing rear tire and front too when you put a jack under exhaust ...lets see them do that :D
  14. k-moe
    On an HD I just put a motorcycle jack under the frame and can take both wheels off.
    Parking one on soft ground can be challenging though.
  15. Polock
    hang it over your doorway like a horseshoe for good luck
    Chitwood likes this.
