Need HELP with xj750 FORK CAP
Discussion in 'XJ Technical Chat' started by Dec 100, Jul 21, 2025.
  1. Dec 100
    Dec 100 New Member
    Ireland
    Hello, so I've ran into an issue while trying to rebuild the forks on this 1984 xj750 seca
    I have one fork removed from the bike, and then I compressed the cap and removed the circlip.
    The issue is that the cap won't come out, it's meant to pop out from the tension of the spring with the circlip removed but it seems to be seized in there.
    Does anyone have any suggestions as to how I can solve this??
    Thanks in advance
  2. Franz
    Turn it upside down a hit it against a block of wood see if that does it. Keep yourself clear of the shock leg in case the spring pops out.
  3. Dec 100
    Dec 100 New Member
    Ireland
    Yeah I tried this already, unfortunately it didn't work.
    I also used a bottle jack to compress the fork against wood and it hasn't moved at all.
    I have it soaking in wd40, maybe I'll try it again with some time for the oil to help free it
  4. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    If you have a Dremel with a wire brush, run that around in the circlip groove to remove the rust crustys. Soak good with your favorite penetrant. With a hammer and wood block, tap the cap gently DOWN into the tube...lightly and about a thousand times. The spring will push it back up incrementally as the gunk clears out.
    k-moe and Franz like this.
  5. Dec 100
    Dec 100 New Member
    Ireland
    OK I'll try this!
    Sounds like a good idea
    Franz likes this.
  6. k-moe
    It works. BTDT.
