Oh dear, I broke something. Carb float pin support post, XJ650RJ 1982 650 Seca
Discussion in 'XJ Technical Chat' started by JMark, Aug 16, 2020.
  1. JMark
    JMark Member
    Minneapolis
    I have two questions about this:
    1. Is it possible to braze or weld the aluminum, JB Weld, etc....
    2. I think I found a used carb body on E Bay. This is carb #3 from left to right. How different is each carb body? I assume the two interior ones are identical, please correct me if I'm wrong.
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    You can tig weld them - but I don't think I would be able to. Having said that, you have nothing to lose. Needs some jigging to hold it in place, remove float valve, gasket, throttle shaft seals?
  3. k-moe
    The inner two carb vodies are identical.
    The square float towers are a bit harder to repair than the round ones.
    The easy path is to get a spare body, but keep that one for later repair.
  4. JMark
    JMark Member
    Minneapolis
    I think for $42 I might just buy the carb body...
    Thanks so much!
  5. Jetfixer
    You can drill a ,a hole in the post and ,the body I have fixed a set of carbs with one body that was broke with JB weld ...you have to have area spotless and let it set up at least 24 hours . Repair was still good after 2 years , but this was on another bike , since I sold it not sure what happened to it.
  6. JMark
    JMark Member
    Minneapolis
    Drill the hole and put a pin in it or something or to give the JB Weld more grip?
  7. k-moe
    The pin is to keep the two halves of the post aligned while the epoxy cures, and to reinforce the joint against lateral movement.
    I'll generally use a length of stiff wire.
  8. JMark
    JMark Member
    Minneapolis
    Sweet! That would save me having to break the rack. I do have a carb body coming but i can run it for the season, then as a winter project I'll adjust the valves and break into the full carb rebuild. I can switch carb bodies if necessary then!
    Thanks all! Love how helpful you all are! Too bad we didn't have this last time I had a Seca (sold it in 1999).
  9. Toomanybikes
    Tsawwassen bc
    I have a few carb bodies$ 25
  10. JMark
    JMark Member
    Minneapolis
    Drat. I ordered one and paid $35 + shipping.
