Oil Cooler & Spin on Filter Adapter??
Discussion in 'XJ Technical Chat' started by Chared03HD, Jul 18, 2007.
  1. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    I've devised my own version of the spin on filter adapter and was wondering (before I pull both bikes apart) if I can still use the oil cooler that i recently aquired off of the parts bike -and- the spin on filter adapter together? Or would I have to revert back to the factory filter setup? Is there a diagram of the oil cooler? Will I need a longer center bolt if it does work together?
    Thanks,
  2. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    Anyone...... ?
  3. samsr
    samsr Member
    Colorado Springs
    I guess a picture of what you have for a spin on adapter might help. The oil cooler plat has a back flow vale in it if that is what you mean.
  4. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    It looks identical to the aftermarket spin on adapter, uses factory oring seal and filter used in after market kit. (I'm a machinist... pictures are worth a 1000 words!!) The more I think about it the more I think it will work just fine.
    Nevermind....
  5. RickCoMatic
    You're breaking new ground.
    That Bolt is the Pressure Relief Valve.
  6. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    My adapter is almost a dead ringer to this one, but I put in a little more of a relief cut and outside edge for looks and tapered the interior bore a bit: http://plan9.dnsalias.org:88/xj/products/adapter.html (I know, I know patent infringment... but I'm not selling them so no harm no foul, just made myself one for a total of less than $8.50 in materials - my time is freeeeeeeeee!!)
    My thoughts are that it appears the cooler adapter goes on first using a hollow bolt, than the adapter would mount up as usual in place of the factory filter/bolt/cover, all would work as usual.
    My adapter is made using the OEM replacement o-ring from a fram filter kit, so sealing attributes are in the same location as factory against the block....
    So the pressure relief.... is this eliminated with the spin on kit? Is this bad? The only reason it should need to relieve pressure is in the event of a clogged filter, but if you change oil around the 1500-2000miles mark as I do this shouldn't be a problem!?!?
    Thanks,
  7. Robert
    I hit the link you posted Chared and my overpriced calculator said it couldn't find the server. I think you have a bum link.
  8. RickCoMatic
    That's the way it goes on.
    There's an Special Fastener that holds-on the Cooler section.
  9. Polock
    Chared03HD
    link
    has a built-in pressure relief, don't know if it's right or not
    here's a few cooler adapters
    link
    i thought about a cooler but it hasn't had one for 20 some years so why start now
    now get those chips flying
  10. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    Thanks guys think I'll be working on that project tonight.... Ricko' cooler adapter looks the same, looks like it should work with the spin on Polock posted..... now lets find out!!
    Polock, I thought the same thing about 20 years without one..... but now that I's gots one.... I may as well put it on!! (Just like the engine guards, factory seat hinge pins & seat prop rod I've already swapped over)
