Oil pump chain slack
Discussion in 'XJ Technical Chat' started by eigenseca, Nov 14, 2020.
  1. eigenseca
    eigenseca Member
    Arkansas
    Is this much slack in the oil pump chain normal? Seems really excessive to me but I can't find anything in the manual about a spec.
  2. Franz
    That's normal slack, nothing to be concerned about.
  3. eigenseca
    eigenseca Member
    Arkansas
    Strange, I've just never seen so much slack in a chain before. I wonder why it was designed like that..
  4. Franz
    My engine is the same I am sure it was designed to last the lifetime of the engine. They are not expensive but I didn't change mine.
    eigenseca likes this.
  5. k-moe
    The slack is to make sure that it doesn't break under load. There is no place to put an automatic tensioner or guide, and neither is necessary for an oil pump.
    Franz likes this.
  6. Mezzmo
    Mezzmo Active Member
    Seems a bit more than what my engine had, but probably fine as its not under much load. Maybe see how much a new chain is if you want to be sure...
