Painted stock wheels
Discussion in 'XJ Modifications' started by Richard Elbon, Oct 27, 2018.
  1. Richard Elbon
    Richard Elbon Active Member
    LaCenter Washington
    I’ve got this 82 Seca 750 gray and don’t really care for the black on the cast wheels. Anyone paint theirs a different color and have pictures?
  2. S10gto
    S10gto Member
    Ma.
    I didn't change the color but if you want to take a chance and try another color out here is a easy way.
    What I did was prep the old black first. I then polished the aluminum and final washed the wheels. Then very carefully with your finger wipe grease on every part you do not want paint. Now just spray away. When dry wipe off the grease. Hope this helps. Good luck!
  3. S10gto
    S10gto Member
    Ma.
    A gray bike I think i would bead blast the wheels and then just seal them with some polish for a cast finish look. Just a thought.
  4. Richard Elbon
    LaCenter Washington
    ED099AF1-B13F-45EB-A565-2DD97C0E88F0.jpeg 187020D7-8C08-4FC3-9633-411F63DB635E.jpeg I wanted them a contrasting color,here’s my red 83 GS1100E that I just painted the wheels and rotor centers gold. Since the Seca is gray I was just looking for a contrasting color that wouldn’t be too garish. I don’t want to be too loud for the gray,just subtle.
    Jetfixer and Franz like this.
  5. Richard Elbon
    LaCenter Washington
    Your gray idea I’m going to look at. I’d glass bead them at home and clear urethane and possibly polish the lip.
  6. ThinkingTime
    ThinkingTime Member
    Canada
    I had mine powder coated a metallic grey. Looks great.
  7. Richard Owen
    Richard Owen New Member
    Cadole
    Guys , sorry for butting in ,but I was planning to bead blast and clear coat my turbo wheels and would interested in seeing some photos of your wheels and how they came out, thanks in advance
  8. Richard Elbon
    LaCenter Washington
    Mines the red GS with gold Center wheels. I’ll be doing the Seca in the next couple of weeks.
  9. Richard Elbon
    LaCenter Washington
    S10 gto,when I do wheels,rotors,finned valve covers things like that I don’t mask or grease anything,I use an old T-shirt wrapped around my finger dip in enamel reducer and wipe off the area I don’t want painted right away. That’s what I did on the gold wheels and came out great. Naturally that only works if you have a defined edge.
  10. Franz
    Mine are powder coated which I like but paint is better as it is easy to touch up. They were powder coated by the PO. 1991 Yamaha XJ 900f .jpg
    Jetfixer likes this.
  11. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    20150503_185708.jpg Here are my red wheels. Painted with a spray bomb.
  12. Richard Elbon
    LaCenter Washington
    E6B100BD-342B-491B-8A14-72BF8FF7A265.jpeg I just came in from trying bright flat silver and I’m not feeling it. Gonna go to Ace hardware tomorrow to look around at different colors.Thinking a bright blue metallic like on a 69 Camaro. The Seca is gunmetal gray and I don’t want it so dark it looks like a dungeon but not so bright it looks like Huggy bear with diamond sunglasses and purple and green outfit heading downtown to check on the girls:p
  13. Richard Elbon
    LaCenter Washington
    EECF94DC-F62B-499C-B9D6-1CF25FABB4FE.jpeg C295F956-2476-4CB3-A212-3B03250B315A.jpeg After kicking it around for a while I decided to stay with black on the wheels of my Seca. Other than a compression check which is all good this is the start of my cosmetic rehab.I took the front wheel off and removed the rotors. Painted the centers of the rotors and cleaned the heck out of the wheel. OG black is so good I left it. Bleeding the anti dive and brakes next. I put new EBC pads in that came with it. Then onto engine area. Basically just going to clean and detail what’s already there.
  14. jayrodoh
    jayrodoh YimYam
    Cleveland
    52 Buick?
  15. Richard Elbon
    LaCenter Washington
    51 Special
  16. Richard Elbon
    LaCenter Washington
    And others
    Franz, Jetfixer and jayrodoh like this.
  17. Franz
    Great American cars. Don't make them like that anymore.
  18. Richard Elbon
    LaCenter Washington
    Real steel.
  19. Franz
    Yes it would be great to drive one. Beautiful they are.
  20. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Nice cars!
    Im going to paint my rims, did you paint them rubber off or on? I need a new front tire fitted anyhow so when should I paint the rims?
    Not sre if tire shop will eff up my new paint....
    Also, after polishing the aluminum back out did anyone clear them? Or clear first then polish out? Tks
  21. Richard Elbon
    LaCenter Washington
    I painted them with the tires on. Used Vaseline on the tire then sprayed the cast areas. As soon as I got full paint coverage on it I used an old t shirt wrapped around my finger dipped in laquer thinner and wiped clean all the machined areas. Didn’t polish anything,it’s the factory finish.
  22. Colin 85 700
    Thunder Bay, ON
    My rims the aluminum areas are corroded a bit, they need a polish.
    If i use that method ill polish first. Thanks! :)
    I like the vaselene idea n thinner, sounds slick, i was gonna mask tire and sand off paint when dry if i left rubber on.
  23. Richard Elbon
    LaCenter Washington
    D72DDDEE-7FEB-4865-8AA2-E2042400CC8B.jpeg 820326B1-2E26-4F02-9B33-735E6D798485.jpeg I went to a friends house back in the 80s to help him paint the black part of a set of Mopar magnum 500 factory wheels.He taped it all off which was an hour or so. We shot them semigloss black factory color and they turned out nice however against my advice he left the masking tape on and let them sit in the sun for a few days. Yep, tape hardened and was a bitch to get off. I decided to find a better way. Hot Rod magazine did a painting article on a set of early Corvette valve covers shooting Chevy orange between the fins and wiping the fin edges with a lacquer thinner wrapped stick. That’s how I did my projects from then on. Works great and leaves a professional looking part.These are from my 83 GS 1100E,just did a month ago.
  24. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Liquid tire buff, the stuff you clean the inner carcass before applying a patch, plug patch, boot, etc works very well to clean any over spray off of a tire should you get any on it in your painting efforts.
  25. Richard Elbon
    LaCenter Washington
    Which I haven’t finished yet on my Suzuki you can still see a little bit on the tire. Ran out of lacquer thinner and am looking for something like the tire buff that is not quite so toxic to work with.
