pilot screw?
Discussion in 'XJ Technical Chat' started by hughie1987, Apr 8, 2018.
  1. hughie1987
    hughie1987 Member
    pennsylvania
    Looking at the clymer manual that finally showed up it says to not turn the pilot screw as it has been set at the factory, looking at the diagram Im having a kinda hard time telling which one it is haha its a 1918 550, cant find any specific pictures of it anywhere either online
  2. Polock
    did they have cameras in 1918 ?
    someone who knows 550's will be along shortly
  3. hughie1987
    hughie1987 Member
    pennsylvania
    yes they had cameras in 1918
  4. XJ550H
    epa required pilot screw be turned and tuned at factory, pilot screw is on top of front throat of carbs it is typical to have a plug over it
  5. XJ550H
    I have a mikuni suzuki rebuild file if you want a copy let me know it used to be a link in info overload
    plug is about 1/8 inch thick you drill a tiny hole in the tiny hole and screw in a sheet rock screw then pull it out
    Cleaning your Mikuni carbs
  6. XJ550H
    but not XJ's;)
    hughie1987 likes this.
  7. hughie1987
    hughie1987 Member
    pennsylvania
    ok Im cleaning the carbs etc I figured it was under the plug! I guess Im gonna leave it be haha
  8. XJ550H
    no you have to remove it to clean it or you may melt the little tiny oring and plug up your pilot jet circuit
  9. Polock
    those rubber o-rings are 30 years old and hard as rocks by now, if they don't seal you can't adjust the idle mixture
  10. Toomanybikes
    Tsawwassen bc
    Never mind that they are probably gummed up.
    1/8 " drill bit . The plug is about 3mm thick don't go to far. Use a drill press if you can and set the stop gauge on it to prevent damaging the mixture screw and insert a #6 screw into the plug. I use a tack puller to remove
