PM notification error.
Discussion in 'Suggestion Box' started by Hired_Goon, May 17, 2006.
  1. Hired_Goon
    Hired_Goon Member
    Oz
    Had a problem yesterday with the forum. every time I opened a different page or post on XJbikes a small window would pop up. Window was blank with error 404(page not found) in the title bar. Closed and reopened site and still there
    Took a while to annoy the cr@p out of me so I looked at the page source. Found a window.open statement relating to PM's. Looked in my inbox and sure enough someone sent me a PM. Read it and the problem went away.
    Question is, why the 404 error. I don't use any popup blocker on this comp. I do use Zonealarm lite version but can't see any options for blocking in this version.(I know the pay for version has it)
    Using win2000 and no blocker in IE version I have.
    Any Suggestions????
    PS. Anyone want to send me a test PM to see if it's still happening today. If it does I'll do a screen capture of the window.
  2. Hired_Goon
    Hired_Goon Member
    Oz
    Ok, JDRich sent me a PM and that helped me sort out where the error lies and might give Sno something to do.
    Error came up as attached. Now the problem seems to be the way I enter the forum. Being a lazy Aussie my shortcut into the forums is this.
    http://www.xjbikes.com/Forums/search/se ... posts.html
    Which takes me straight to new posts and bypasses three or four mouse clicks. Doing it this time gave me the same error window so I took a screen cap and clicked on Forum Index to find this post and put in a reply.
    Once the forum index loaded the PM notification box came up as it should.
    I clicked close window then went back to new posts and no more popups.
    All good, but shows there may be a bug in the notification if one doesn't enter via the forum index.
    No big problem as now I know what it is, it's easily fixed.
    Sorry, Sno, I know you have enough to do without me giving you work. :?
  3. SnoSheriff
    MB, CAN
    Funny you should mention this 'feature'. I've seen this blank notification error on my work PC but at home it's all good. At work I use IE (like you in the screen shot) but at home I use Firefox.
