Question about painting my tank.
Discussion in 'Hangout Lounge' started by tabaka45, Nov 26, 2015.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I have to repair a small dent and will need to repaint the tank. The tank has some simple flame graphics which I plan to duplicate. Also, the current paint is good and the tank has several layers of clear. I'm hoping that I can simply sand the existing clear to a dull finish and then paint a new base coat, graphics and then clear. Would there be any problems with that?
  2. hogfiddles
    Make sure to use the same brand material as the original..... Otherwise you may have some incompatibility issues----- wrinkling, bubbling, not hardening, etc.....
  3. XJ550H
    why not just strip it down completly using aircraft stripper?
  4. Rooster53
    If the paint is in good condition perhaps paintless dent repair is an option. I have seen some guys do a fantastic job of removing dents using this process. I suppose with a motorcycle tank the location and accessibility to the dent becomes the deciding factor.
  5. hogfiddles
    Yup, and it also depends on the dent itself----
  6. Polock
    is it small enough to cover with a XJ4EVER sticker :)
    Stumplifter and hogfiddles like this.
  7. k-moe
    Get a rubber mallet.
    Carefuly measure the dent.
    Walk to the other side of the tank.
    Fabricate a matching dent.
    Better yet do that dentess thing that was mentioned earlier.
  8. Ribo
    Ribo Prefectionist
    How big and obvious is the dent.
    Trying to blend/match a part of the tank like this at the same time as trying to match a graphic etc is very very difficult unless you're a professional auto-body painter with a pro-shop.
    I think you can do what your said and you could make a decent go of it where it wouldn't be obvious to the casual glance if it's not in a glaringly obvious location but if you want it to look perfect or 90% you can either 1) take it to a pro-shop and pay the money to have it done professionally. 2) Strip the tank, repaint and clear it yourself - which is a very time consuming, frustrating but ultimately rewarding thing to do/learn.
    Note if you do it yourself you'll need to use a 2K clear to make it gas proof. That stuff is very dangerous (contains isocyanates) so make sure you use the right precautions and protection. I did it one time and for me it's just not worth it. I'd rather pay someone that has a professional shop with full hood/air extraction to do the clear part at least.
  9. hogfiddles
    Well, I'll differ on that...... I've painted enough things that have wrinkled up from using non- compatible paints. I'll stick with the "use the same brand, or sand it all down" mentality. That works bat for me... Lol
