Rear shocks
Discussion in 'XJ DIY How-To Instructions' started by Kris Taylor, Feb 15, 2015.
  1. Kris Taylor
    Kris Taylor Member
    Jacksonville,Fl
    How do you adjust them? Lower and raise them?.....81 xj650 maxim
    You adjust preload by rotating the lower ramped collar (the tool for this is in the factory toolkit). There is no provision for changing ride-height.
  3. Kris Taylor
    Kris Taylor Member
    Jacksonville,Fl
    I don't have that tool
    A substitute can be made from round bar of the proper diameter. Fatory toolkits come up on Ebay regularly, and aren't expensive. You could also consider upgrading to new shocks.
  5. Kris Taylor
    Kris Taylor Member
    Jacksonville,Fl
    Any shocks work?
  6. hogfiddles
    AS long as you have the right length, the right size eyes, the right depth of the eyes, and the overall diameters of the shock springs, perches, and covers aren't too big................
  7. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Old Honda shocks have a clevis on one end, be wary when shopping to stay away from Honda-compatible ones.
  8. hogfiddles
    Yup, that's why I was that specific......
  9. kwes
    kwes Member
    tampa
    How would one go about finding out the proper specs needed for a shock replacement/ swap?
  10. hogfiddles
    Measure yours
    kwes likes this.
  11. Altus
    Altus Active Member
    London, Ontario
    Stock shock length is 12.5" eye-to-eye.
    Most common upgrade is to the Progressive Suspension 412 series shocks.
    Part number with standard rate springs is 412-4205, and with heavy duty springs it's 412-4206.
    kwes likes this.
  12. bclark
    bclark New Member
    Rochester, NY
    Kris Taylor likes this.
  13. Kris Taylor
    Kris Taylor Member
    Jacksonville,Fl
    I like that place. I have gotten a lot of stuff from there ordered and also going in.
