Rebuild not starting?
Discussion in 'XJ Technical Chat' started by Christopher, Sep 24, 2018.
  1. Christopher
    Christopher New Member
    Sacramento
    Okay... so I’m rebuilding a bike.
    Got the brakes done, electrical, etc.
    Me and my buddy got it stared using starting fluid right now with choke on full. It has compression, spark, and I’m using a makeshift gas tank so I don’t have to deal with the vacuum petcock
    It’s not starting now at all without starting fluid. Any suggestions on what I should do?
    It’s a 1980 Yamaha Xj650 Maxim.
  2. Jetfixer
    Yes have you taken carbs to church? If it will not start without starting fluid , choke will not work properly , you will have to pull carbs and remove float bowls. Go to the top of page click xj4ever read the information overload hour lots of good info.
  3. Christopher
    Sacramento
    Yeah, I did a thorough cleaning on absolutely everything.. I'm thinking I didn't set the floats right.
  4. Jetfixer
    Flip carbs over ,pull bowls measure from the flange of carb body at rear of float , should measure 17mm height ,this good starting point , you should wet set carbs to get it right.
