Replacing 700S head cover gasket
Discussion in 'XJ Technical Chat' started by to the max, May 19, 2022.
  1. to the max
    to the max Member
    Akron, Ohio
    On an 86 700S…
    the circled hole appears to be supposed to be covered by the gasket.
    did they have the wrong gasket on this?
    I’m going to order an OE one so I guess I’ll find out when I get it but I wanted thoughts from yens
  2. Dan Gardner
    Minneapolis, MN
    Looks correct to me. Mine don’t have any gasket at that spot
  3. to the max
    to the max Member
    Akron, Ohio
    Thank you
  4. to the max
    to the max Member
    Akron, Ohio
    Here’s the OEM gasket.
  5. Franz
    That is correct it is not meant to be covered. Your first pic suggests that too as the place the gasket does not cover is dirty.
