Rev counter signals and horn stop working intermittently
Discussion in 'XJ Technical Chat' started by Uxbridge Brule, Jun 13, 2022.
  1. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    Was at the NYCC this weekend and like the title says signals, horn and rev counter stopped working. Then they start working again put it in the trailer not working took it off the trailer they worked until I got the bike into the garage. Where should I start the search? I see in the Haynes manual the turn signals and horn are same connector but don't know if the rev is in the same group.
    The bike is a 1983 750 Maxim (k)
  2. Rooster53
    I would be checking the signal fuse and fuse clips first, particularly if the other parts of the signal circuit are not working - like the neutral light and brake light.
    Uxbridge Brule and k-moe like this.
  3. Uxbridge Brule
    Uxbridge Ont
    Had a quick look at the fuses when it happened they all looked good in the panel, new panel. Went out today and wiggled the contacts and the instruments 20220615_093700.jpg 20220615_093725.jpg went out again took the good looking fuse out and this is what I found. Always check and recheck it wasn't burnt just a bad connection from the factory. Thanks for the input Rooster53
