Round two for the xj550
Discussion in 'XJ Technical Chat' started by irritateddave, May 23, 2013.
  1. irritateddave
    irritateddave Member
    Virginia
    xj550 sitting for ten years// first bike
    Im still learning all of this, but I think I added a link to previous forum where you guys helped me get xj550 maxim sitting in a block of varnish for ten years start again. (thanks) Anyway, it starts every time now, however the rpms jump straight to 7000 rpms then start climbing slowly. I haven't let it climb past 8000 so I don't know if would blow itself up or not. So any advice as to where to start to resolve this issue would be appreciated.
  2. moellear
    moellear Member
    Lima, Ohio
    that's incredibly high rpms for an initial startup on the bike. make sure the throttle cable has some slack. and when you put the carb bank on the bike, you did a bench level sync for the butterflies correct?
  3. irritateddave
    Virginia
    :oops: Uhhh no... The butterfly flaps all looked like they were all the way closed already, and the only way Ive heard of to set them is with a straightened paper clip to set the gap, and then Im not sure how to get past setting the first one. ..................guess ill be pulling off carbs..........again
  4. moellear
    moellear Member
    Lima, Ohio
  5. bigfitz52
    So you didn't really do a bench sync.
    Are the valves in spec now?
    Did you individually wet-set the float levels?
  6. irritateddave
    Virginia
    thanks moellear. That actually makes a sense to me. I'll have it shortly with reply.
  7. irritateddave
    Virginia
    Yeah, I set each float levels individually to 2 mm +/- 1mm just like you instructed in my last thread. That's when the bike started (I think I cried a little by accident JK) I have neglected the valves though. Would tight valves cause extremely high idle?
  8. moellear
    moellear Member
    Lima, Ohio
    +1.
    No sense in getting the carbs synced if the valve shim clearances are not in spec. its not hard or scary to check either. Float levels are a pain in the @s$ but once they are correctly set, you'll know it and be happy with yourself. Hence the reasoning why I get such great gas mileage on my 550 maxim
  9. bigfitz52
    How about YOU WON'T GET the carbs properly sync'ed if the valves aren't in spec?
    I coulda sworn we've said "get your valves in spec" more than once in response to this issue...
  10. irritateddave
    Virginia
    yes you did. it was also stated to get the bike running before worrying about anything else like valve specs ect...... The bike is running now. Annddd now I will check valve clearances. Thanks
