Rpm limit 4000
Discussion in 'XJ Technical Chat' started by Hasan Omar ibrahim, Mar 24, 2021.
  1. Hasan Omar ibrahim
    Hasan Omar ibrahim New Member
    Philippines
    Hey folks!
    I've got an 1982 XJ750 here and I have this intermittent issue with the bike.
    The RPM seems to be limited at 4000. When I go above 4000rpm, the rpm just drops and it feels like a misfire, without any backfire. This happens in all gears, including neutral.
    Example: Let's say I am in 5th gear on the highway doing about 85 km/h at 4000 rpm. I turn the throttle grip, RPM goes to about 4100 and then starts going down FAST, bike is still rolling at the same speed. It sounds like it's misfiring, very similar feel to a car's rev limiter. When I release the throttle a little, RPM goes back to steady 4000rpm.
    This issue happens randomly. I can have this happening for 3 days. Then one day I start the bike and it runs perfectly fine to high RPM. Then 3 days later the 4000rom issue stars again.
    Oil is new. Carbs are super clean. spark plugs are brand new.
    Any ideas?
  2. Yammaat
    Yammaat Active Member
    Netherlands
    Perhaps the TCI doesn't compensate for higher rpm's anymore?
    A coldshut somewhere in the TCI?
  3. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Are there any potential issues with the air inlet becoming partially blocked.
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    The airflow in and out is a lot less in neutral than on load, which leads me to believe its a tci issue. But, I'd still check the air filter, inlet etc. Exhaust is a potential limiter, but not so easy to check.
    Hasan Omar ibrahim likes this.
  5. XJ550H
    is it the correct tci?.
    maybe check the charging system see if the voltage output is droping off when this happens.
  6. k-moe
    Hot and humid is the enemy of electronics, especially electronics from the 80's and before.
    The Philippines have plenty of both.
    My bet is that the TCI needs repaired or replaced. Hopefully jsut a corroded trace or solder joint that failed, but the capacitors may have failed.
  7. Dave in Ireland
    Ireland
    Basics first - check, clean and tighten all the connections to the TCI unit and the coils.
    Nasty green corrosion grows out of sight and suddenly things don't work too well.
    k-moe and Simmy like this.
  8. Polock
    spray some water on the coils and wires to see if you can make it happen
  9. Hasan Omar ibrahim
    Philippines
    Thanks for the reply sometimes the bike runs perpectly then suddenly the problem starts again i cant rev it to a high rpm when i check also the volt meter the numbers are flactuating and what is tci? Tci and cdi are the same?? Thanks I’ll wait for your reply
  10. Hasan Omar ibrahim
    Philippines
    The coil are brand new and i have check the resistant it is pretty factory standard
  11. Hasan Omar ibrahim
    Philippines
    Last time i lost spark and i soldered the cdi then it came back to normal then the misfire happen but sometimes when the bike is running for 1 hour it comeback to normal conditions
  12. Hasan Omar ibrahim
    Philippines
    I believe it is the tci because before i lost spark then I soldered the tci then it came back again so maybe i need to solder again all the parts inside the tci
  13. Hasan Omar ibrahim
    Philippines
    What do you suggest do i need to solder the cdi again??
  14. Yammaat
    Netherlands
    TCI.. and Yup.
    There seems to be a method to check whether there is a coldshut and that appears to be to smack it on some flat surface by hand.
    Read it here somewhere I believe but I'm quite reluctant to do so..
    Remember.. everything is almost 40y of age and like amplifiers and such.. the soldering can get brittle and crack.
  15. XJ550H
    Yammaat and Hasan Omar ibrahim like this.
  16. Hasan Omar ibrahim
    Philippines
    Yammaat likes this.
  17. Hasan Omar ibrahim
    Philippines
