rpms wont go down!
Discussion in 'XJ Technical Chat' started by nissinator, Sep 13, 2012.
  1. nissinator
    nissinator New Member
    i have a 1980 maxim 650 on first startup it idles just fine (just cleaned carbs) i drive it for a while then come back and click it into neutral and release the clutch and the rpms just keep going higher and higher...any ideas?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Have you checked for vacuum leaks at the carb to head boots and throttle shaft seals? Are the carb sync ports caps dry or cracked?
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Did you initially set the idle after the engine was fully warmed up? Try riding the bike a couple of miles and then adjusting the idle with the idle screw.
  4. bigfitz52
    Sure.
    Verify your valve clearances;
    precisely wet-set the float levels;
    and do a running vacuum sync.
    You've only begun.
  5. mook1al
    mook1al Member
    Talladega, AL
    You might also check that the throttle cable is moving freely and not binding or routed incorrectly.
  6. MrPhys
    MrPhys Member
    Knightdale, NC
    No frigg'n joke
  7. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    At least you know your compression is good! Vacuum leak....
  8. aaron_acrusto
    aaron_acrusto Member
    Pittsburgh, pa
    Close the choke?
