Running rough
Discussion in 'XJ Technical Chat' started by simon perrin, Aug 19, 2016.
  1. simon perrin
    simon perrin New Member
    cornwall
    Hi I bought a xj550 about 8 months ago it hadn't been used much in the previous 5 years. I've only now got it on the road and it is running rough between 4000-5500 revs, it is fitted with non standard cone type air filters would it be worth getting the carbs synced and going back to standard filters . Electricaly everything seems in good order and starts first time every time and idles about 1200 revs when warm. Thanks for any suggestions
  2. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Try to find a stock air box and air filter, it will be very very difficult to remedy this and other problems while running pod filters.
    The cv carbs do not work correctly with pod filters . And the symptoms you have point to this!
    Alan
    Jetfixer and Yardawg like this.
  3. simon perrin
    cornwall
    Thanks Alan63 will give it try
  4. Jetfixer
    +1 Agree 100% pods suck you will be pulling changing jets reinstalling....testing...pulling carbs changing jets ....repeat.....mean while those that have stock airbox and filter will be out riding ...lol seriously try to get a stock airbox you will be pleased you did in the end.
  5. simon perrin
    cornwall
    Thanks jetfixer will start searching for standard stock right away
