Runs, but not quite right!
Discussion in 'XJ Technical Chat' started by Tom Culbertson, Sep 4, 2018.
  1. Tom Culbertson
    Tom Culbertson New Member
    Loveland, Colorado
    1986 Yamaha MJ700X Maxim X - - - Had not run for a year before I acquired it. I changed the plugs, cleaned the carbs, cleaned the gas tank, replaced the intake rubbers (from air box to carbs), repaired some wiring issues (unrelated to ignition, charging, etc.) put good gas in it...........voila, it runs! But.....it pulls strong on acceleration, sounds "flat" at highway speed and misses intermittently at cruising speed and at idle. Idles fine once it's warm. The carbs were balanced by a pro and mixture set by him, too. No wet plugs. Battery is fine - 12+ volts, charging system putting out proper voltage. What next? Replace ignition coil? This bike has a lot of miles on it, but I know little about it's history.
    The TCI would be the last thing to look at.
    Check valve clearances.
    Describe how you cleaned the carbs.
    How far were they taken apart, and were any parts replaced?
    Were the slide diaphragms inspected?
    Were the fuel levels checked (not just the float heights).
  3. Tom Culbertson
    Loveland, Colorado
    I removed the carbs, took the upper half off, thoroughly cleaned the lower halves with carb cleaner and compressed air. Cleaned the jets, main needles of slight corrosion, ran air through every orifice, did not disturb the diaphragms other than to inspect them. Replaced no parts. The carbs were actually very clean except for some green corrosion in the jets, which I removed. I did not check the float heights.
    I don't think the "miss" I'm getting is a fuel issue. It's too intermittent/irregular. I did not check the valve clearances. I don't know how, other than to read a manual. I'm not a pro at this.
  4. Polock
    start it up, go for a ride till it's warmed up. park it but leave it running and spray some water up on the coils and plug wires with a spray bottle.
    see what happens?
  5. Mototimothy8
    Mototimothy8 Member
    Lewisburg, PA
    Did you by chance take the emulsion tubes out and clean them? They tend to become caked up if they sit without fuel stabilizer in the fuel.
  6. Polock
    could be something silly like the side stand switch
  7. alFrumpus
    alFrumpus Member
    Saskatoon, SK, Canada
    cgutz likes this.
