Seca 650 Project
Discussion in 'XJ Technical Chat' started by Glen Botterbrodt, May 8, 2018.
  1. Glen Botterbrodt
    Glen Botterbrodt Member
    Washington D.C.
    Good afternoon all!
    Today I get the privilege of creating my project/restoration thread since last night I finally got my Seca to run! My plan has been/currently is/was to not start the teardown until I know the bike is
    running/ worth the time without blindly tearing down the thing.
    Last night I managed to get the bike running off Carb cleaner enough to hear it idle and be satisfied.
    So today I began the teardown process. I took a lot of pictures of wire connections and routing to ensure I get things put back together properly. I also labeled each part as it was removed; so I went from a complete bike to its current state. I am stuck here until tomorrow when my buddy is coming over to help remove the engine. I also need to get passed the stuck swingarm bolts and get a larger socket.
    Start:
    (this is an old picture but what I began with today)
    Progress:
    Final:
    Here I am until i get an extra set of hands and a socket for the swingarm.
  2. Glen Botterbrodt
    Washington D.C.
    Slow and steady on my progress.
  3. Polock
    maybe you've done this but hang it from the steering neck so any water in the frame can drain out. and there are drain holes where the swingarm bolts go, keep them open.
    right now is the time to putty up and smooth down the welds around the steering neck, makes a nice look when it's finished
    chacal likes this.
