Seca 750 whine
Discussion in 'XJ Technical Chat' started by stv1991, May 15, 2017.
  1. stv1991
    stv1991 Member
    Very nice Seca 750. 10,000 miles, carbs professionally cleaned and adjusted, fresh oil change with proper motorcycle oil, valves checked. Bike runs like a brand new motorcycle. Problem is there seems to be what sounds like gear whine. I don't know if it's coming from the engine or drivetrain.
    Do these bikes have this sound? It's the first shaft bike I've ever had. The sound seems excessive to me.
    Any hints on where to start troubleshooting on this?
  2. Jetfixer
    The rear diff can whine ..have you checked oil level? Another possible whine is the speedometer put you had an cluster at around 30 miles per hour see if vibrates if so that could be issue. Unless it is so loud you need ear plugs ...just ride.
  3. stv1991
    stv1991 Member
    It is pretty loud. I haven't checked the rear differential, what oil should I put in there if it's low?
  4. Polock
    could be the middle gear whine, it has to do with the driveline doing a 90 to spin the driveshaft. some bikes do it more than others. there's nothing you can do about it, doesn't hurt anything.
    there's also a middle gear clunk that has to do with springs and mechanisms that replace the cush drive on a chain bike. feels like someone kicked the back tire when you start out. disregard that too.
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    The motors whine too because of the chain driven alternator (or so I've read). Does the whine increase with the speed of the bike or with the RPM's of the motor? If with the motor RPM, its the engine like shown in this video (again this is normal sound).
    Stumplifter and TheCrazyGnat like this.
  6. hogfiddles
    Good video.
    How about giving a clip of yours if yours is drastically different?
  7. jayrodoh
    jayrodoh YimYam
    Cleveland
    I rode to work today and was paying more attention to the whine(s) way more than usual. There's definitely a drive whine too from the gears. Both are normal though.
    Ditto
  8. ftnpenlvr
    ftnpenlvr New Member
    NH
    Mine has similar whine, but, my exhaust is somewhat louder (not intentional - item 126 on the list of things to tinker with)
  9. jsngrimm
    jsngrimm Member
    Akron,Ohio
    My Maxim 650 does it, totally normal for these bikes. When you first get one of these old XJs and read about/drive them you quickly learn they made a lot of weird yet normal noises
  10. hogfiddles
    Yup, perfectly normal.....and COOL. You can hear one coming a mile away. literally. It's really fun at a carb clinic to see a bunch of guys working on bikes, other bikes going by on the road....and then all of a sudden some heads will pop up and someone will say,"here comes one"..........sure enough, about a minute later, an Xj slows down and pulls in. Gotta love that whistle
    Simmy and Stumplifter like this.
  11. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    My xj700n has a whine and I have been trying to track it down. You can only hear it when accelerating and it disappears around 3000 rpm. It is nowhere near as bad as the bike in that video.
  12. hogfiddles
    Paul, that's a NORMAL sound
    Paul Howells and k-moe like this.
  13. joejr2
    Santa Fe,NM
    The cooling fins on the engines tend to whine on acceleration thats what all those rubber inserts
    stuck between the fins are for.
  14. k-moe
    They don't whine, they sing (like a xylophone). :)
    Stumplifter likes this.
