starter rebuild kit question
Discussion in 'XJ Technical Chat' started by borjawil, May 5, 2014.
  1. borjawil
    borjawil New Member
    lansing mi
    Just picked up a rebuild kit for 1982 seca 750. the bolt that goes to one of the brushes has a plastic piece and a few paper washers. Not sure what order to put things in. Im guessing this bolt isnt supposed to touch the starter housing?
    You are correct, that is the positive lead to the starter. It must be fully insulated from the starter housing.
  3. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    That's correct. The bolt is where the POS cable runs to the starter. The plastic piece and washers are to keep the wire from touching the starter housing and frying the internals (and quite possibly a bunch of other electrics).
    The plastic piece should be first, to center the bolt in the hole. Then it's just a matter of stacking the fiber washers so that the cable doesn't touch the housing.
  4. borjawil
    borjawil New Member
    lansing mi
    ok, so it is possible to fry the starter armature? When I check the resistance from the battery neg to the frame/engine i should have resistance yes? if no reistance my starter is bad or is it just the pos bolt touching the starter housing? One more question, if the POS isnt supposed to touch the starter housing, but the bolt is connected to the brush that touches the brush mount which touches the starter housing...see where Im going with this?
  5. Polock
    "When I check the resistance from the battery neg to the frame/engine i should have resistance yes?"
    no, or very very little.
    " One more question, if the POS isnt supposed to touch the starter housing, but the bolt is connected to the brush that touches the brush mount which touches the starter housing...see where Im going with this?"
    + to the bolt...to the brush....that touches the brush holder that is insulated from ground....thru the + brush, thru the armature... to the - brush that is connected to ground....and away we go
  6. tskaz
    tskaz Active Member
    If the bolt is touching the housing it completes the circuit at the bolt instead of following the path through the armature like it's supposed to.
  7. borjawil
    borjawil New Member
    lansing mi
    How is the brush holder insulated?
  8. Polock
    really well :)
    think about what it's made from
  9. borjawil
    borjawil New Member
    lansing mi
    metal...?
  10. Polock
    That's all, just metal ?
    I'm thinking you haven't looked at yours yet, I'm also thinking when you do you'll
    Be smart enough to see how it works.
    There should be no connection between the brush holders, that's your assignment
    Figure out how they do that
