Stupid question - which screw is for fuel adjustment
Discussion in 'XJ Technical Chat' started by MaximusXJ650, Jul 15, 2019.
  1. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I've just had a brain fart where I've completely forgotten which screw adjusts the amount of fuel going to the engine via the carbs.
    I cant decide between the one under the brass plug or the bigger one between the carbs.
    Xj650 maxim.
    I'm running lean according to the colortune (giving a light blue color) so I dont know which screw to turn to make it more rich.
    I remember from setting the carbs up that i turned the screw under the brass plugs 2.5 turns out
  2. firebane
    firebane Active Member
    Calgary, AB
    The big one just works the idle. You will need to adjust the ones under the brass caps for the colortune.
    MaximusXJ650 likes this.
  3. k-moe
    As above, the screws under the brass caps adjust fuel mixture. Since your caps are still in place the carbs haven't been properly cleaned since being sent to the dealership on the brand-new motorcycle (and the -orings are likely hardened and near-useless).
    The slotted screws between the carbs control the throttle plate synchronization.
    The big knob under and between #2 and #3 controls the idle speed.
    Jetfixer likes this.
  4. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    They have been removed, I removed and refitted them during the carb strip down.
    I saw posts about drilling them out but I took a small thin flathead and prised them out with little to no effort.
    I'm having difficulty tuning in the left side of the engine. During the colortune process I cant seem to get that deep blue colour on #1 & 2 like I can on #3 & 4. It just stays a pale blue which I believe is lean.ė
    I've had the carbs apart again and checked the float setting both wet and dry and its spot on. I even made sure that the tiny hole in the float bowl was clear - if said hole was blocked what would it do?
    The bike runs and rides but bogs when opened full throttle and I cant get past 65mph.
    Losing hope with this, I just want it to run properly...
  5. firebane
    Calgary, AB
    Valves adjusted? Stock Airbox?
  6. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Yes and yes. Full carb strip down, new butteryfly shaft seals and fuel o rings. Been in a ultrasonic cleaner too
  7. k-moe
    Pale blue will be fine, as long as the plug color doesn't show leanness and you don't get any popping on deceleration.
    There might be a small vacuum leak somewhere other than at the carbs. Worth checking out the intake boot base seals and the vacuum port caps to be sure.
    Check the plug color after a good long ride. Look for the color on the ground strap and base ring more than on the insulator. A light grey insulator is fine, but light tan is better. The ground strap should have a noticable change in color just about at the bend (indicating that the plug is reaching the self-cleaning temperature), and the base ring should be sooty all the way around, but not a dark black soot. The big tell for being too lean will be flecks of aluminum on the porcelan or ground strap. At that point the mixture is dangerously lean and needs to be made richer, or the underlying problem found and solved.
    The tiny hole in the bottom of the float bowl is the enrichment jet. If it were blocked you'd have difficulty with cold starts, and nothing more.
  8. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I'll grab a picture of the sparks after work tomorrow.
    Would a small vacuum leak cause the lack of power post 65mph and the bogging down an lower revs on cylinders 1 and 2 (dependant on where the leak is)
  9. firebane
    Calgary, AB
    Have you checked spark plug gap, spark plug cap resistance and coil resistance? Compression check?
  10. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I'm not sure on how to check any of those. I've assumed compression is fine given that it runs. Coil resistance shouldn't play a part should it? No issues on startup
  11. firebane
    Calgary, AB
    All super easy checks.
    Compression is a gauge you buy.. disconnect fuel and plug wires and remove a plug stick in tool, crank bike with throttle open till needle stops moving.. Compression on 1 side.
    Caps get a multimeter and check the ohsm through the cap
    Coils are a bit more to do but not much. You take off the caps and measure the ohm across the leads with caps off for primary and secondary.
  12. XJ550H
    disconnect tci when doing compression test. test is best when a car battery is used as bike battery will drain and starter will slow down
  13. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Are there any how to videos? I'm more of a visual learner Haha.
    I dont want to be spending more money, I feel I've already piled loads into it.
    If only it would run properly (sigh). Its fine for my work commute as I don't get past 40 but on the open road it bogs at full throttle.
    I read these bikes are easily capable of 80+ speeds - I've done so much work on it and I'm starting to feel defeated on the fuelling issue.
  14. k-moe
    Have you removed the top hats and inspected the diaphrams for holes or cracks lately? They may have showed up since the last time you had the carbs off.
  15. XJ550H
    are all the exhaust pipes equally getting hot? be carful just slap each one see if any feel colder
    sounds like your running on 3 cylinders.
    use a meter and measure the resistance between spark plug cap 1 and 4 should be 21k ohms do the same thing for caps 2 and 3 again 21k ohms
    if you fail above step unscrew spark plug caps from spark plug wires retest spark plug wires.
    test spark plug caps from each end should get 5 k ohms
    what kind of plugs are you running?
    ends of spark plug wires may be corroded and may need to be trimmed 1//8 to 1/4 inch.
    in next step note wire positions.
    then go to the tci disconnect the 4 position connector and measure ohms from red/white wire to gray wire and red/white wire to orange wire looking for 2.5 ohms for each set plug it back in .
    meter set to 200 ohm or lower setting
    that completes the ignition coil test
    pick up coils
    then unplug 6 position connector read ohms from black wire to gray wire and black wire to orange wire see spec below
    then test black wire to ground you should get no reading
    plug connector back in testing done
    your specs
    XJ650 models:
    Pick-up coils:
    1980-81 XJ650 Maxim and Midnight Maxim: 700 ohms +/- 20% = 560 ohms to 840 ohms acceptable range
    1982-84 XJ650 Maxim: 650 ohms +/- 20% = 520 ohms to 780 ohms acceptable range
    Ignition Coils:
    Primary side (input from main wiring harness):
    2.5 ohms +/- 10% = 2.25 ohms - 2.75 ohms acceptable range
    Secondary side (spark plug wires, without their end caps):
    11K ohms +/- 20% = 8,800 ohms - 13,200 ohms acceptable range
    Spark plug caps:
    5K +/- 20% = 4,000 to 6,000 ohms per cap acceptable range
    Spark plugs:
    0 ohms per plug
    also run bike inside barn and look up under tank see if you have a light show going on from coils and wires
  16. XJ550H
    blue bunsen blue anything but white thats lean. do not get hung up on the pilot jets.
    if you apply a little choke do you get the color you seek or yellow?
    with choke off
    briefly bring rpm up over 3krpm 3500 rpm is good what color do you get?
    RangerG likes this.
  17. XJ550H
    are you sure air jets are in correct spots under the hats ? 80 goes near the screw hole.
    are any of your pilot jets swapped with the main jet? main jet has a washer under it and connects to emulsion tube under slide needle
    pilot is farthest from float.
  18. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Thanks xj550h I'll be sure to give these suggestions a go tonight if I get chance.
    To check, when I'm doing the resistance checks, do I connect the red cable from the meter to red/white wire when checking 4 position cable and to the black wire when checking the 6 position?
    See picture for jet positioning:
  19. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Just noticed this pilot is a 40 and the main is 110...
    But this is correct in accordance with the church of clean (I have a US import)
  20. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    No I haven't although I can't see them having holes since I last put them in at the beginning of the month.
    I'll do xj550h suggestions as the bike would need to be started on some of them and if still no luck I'll check the diaphragm.
  21. XJ550H
    each connector seperatly disconnect from tci . tou are measuring resistance meter color/polarity does not matter.
    red/white wire and orange wire measure resistance
    red/white wire and gray measure resistance
    for pickups 6 position connector
    black wire to gray wire measure resistance
    same black wire to orange measure resistance
    the test is done on wires in the connector body not between the 2 connectors
  22. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Got you, on a side note I checked the exhausts and all 4 were hot so it's definitely running on all 4
  23. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Cable 1 and cable 4 = 22.5k
    Cable 2 and 3 = 22.7k
    Plug (spark cap) 1 = 7.6k (replaced with spare at 5k)
    Plug 2 = 6.2k (replaced with spare at 5k)
    Plug 3 = 5.5k
    Plug 4 = original had no reading but had a spare which read 5.7k
    Ignition coil primary
    3.3 on both sides
    Ignition coil secondary
    11.5k on both sides
    4 pin: (ignition off)
    Red/white to orange = 3.1
    Red/white to gray = 3.0
    6 pin:
    Black to grey = 730
    Black to orange = 732
    Only thing that seems to be out is the ignition coil at primary side. Could this be the fault? If so what's the fix?
    Plugs used are the NGK BP7ES
  24. firebane
    Calgary, AB
    So to go over a few things..
    Are your caps stock OEM? or NGK replacements?
    NGKs will be 5 ohm and the #4 showing no reading if its OEM should have a resistor inside that can be replaced.
    Primary resistance on the coils is a tad on the high side. Are they stock coils? Should be closer to 2.5 ohms
    Secondary resistance on the coils is good
  25. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I couldn't tell you now that I've chopped and changed. One is a red ngk and the others are black/grey from memory.
    As theres no history with the bike it's hard to find out what stock and what's not. I would go with them being stock although I replaced one coil with a UK spec one I had in the garage
  26. XJ550H
    you have found your problem a bad cap cylinder was not firing no reading is an open cap.
    touch your meter probes together see what you get for a reading in the lowest ohms setting subtract that from the primary readings you have listed
  27. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I changed the cap and took the bike for a spin. The bottom end power issue seems to be fine however still cant get passed 65mph. The bike revved slightly higher.
    This plug is from cylinder 1 and is new. I put it in just before leaving for the ride:
    Now I'm led to believe I'm running rich - I I colortuned and vacuum synced prior to heading out.
    I checked the cables and they read 0.3 so with a reading of 3.3 from primary, 3.0 is still over. Is it worth getting some new coils? I've found a set in the UK for £40
  28. firebane
    Calgary, AB
    New coils wouldn't hurt. You are definitely running rich.
  29. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    New coils are on order. Estimated a week?!
    I'll have another go with the colortune and see if I can adjust. Bottom end power is there and is good
