Sync screw?
Discussion in 'XJ Technical Chat' started by Xjrider92117, Feb 3, 2018.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    I have a bit of an idle problem with a 550 SECA. The valves are in spec and the carbs have been fully rebuilt. I have synced the carbs and adjusted the air/fuel mixture screws with a color tune.
    The bike acts as if there is a air leak (which I've checked for and I didn't find one) or the carbs out of sync (which I got very very close to perfect).
    When I press the sync screw down with little force the idle drops down to normal. So it seems there is something either binding or sticking some how.
    My throttle response is good and snaps right back when I grab a handful. The cable isn't binding.
    I have a new stock paper air filter. I also have new manifolds engine to carb and carb to airbox.
    The only thing I can think is to pull the carbs and recheck the return springs. I guess I could have installed wrong.
    Any thoughts before I pull the carbs??
  2. Polock
    don't know about mikuni but hitachi needs to be lined up when you reassemble the rack for things to work smoothly. after it's all together i loosen the rails a little and snap the throttle a few times to let the carbs find their happy place on the rails then snug the screws and snap a few more times to make sure then tighten the rail screws
    Stumplifter and Xjrider92117 like this.
  3. Xjrider92117
    San Jose Ca
    I use a level on all sides to make sure everything lines up.
    But...
    I'm gonna pull them and loosen the rails.
  4. XJ550H
    the deck of a table saw works well for carb reassembly thick piece of tempered glass works too. chacal rents a plate by the day
    HCP20990 Aftermarket carb rack re-assembly ALIGNMENT PLATE.
    are the butterflies properly reinstalled not binding or rubbing the carb throat? centered well?
    gaskets on the carb boots?
    Xjrider92117 likes this.
  5. Xjrider92117
    San Jose Ca
    Yeah, for the butterflies I use the same method as mentioned above by polock.
    New gaskets from chacal.
    I pulled the carbs and did as polock suggested. Went for a nice 20 min ride (it's 70 degrees right now). Up and down the freeway. On my way home hit a few lights. Idle dropped like it should. Seems a lot better now, but not perfect. I'll do another sync tomorrow and see how it goes.
    Thanks for the suggestions!
    Stumplifter likes this.
  6. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    Why make us jealous? That's just cruel.
    Timbox, Stumplifter and Plug like this.
  7. Xjrider92117
    San Jose Ca
    :D
  8. Nuch
    Suffolk County, NY
    I'll get there one day. I have friends in Manhattan Beach. I'm determined to do it on 2 wheels.
  9. Xjrider92117
    San Jose Ca
    And I hope you share the story!
  10. Xjrider92117
    San Jose Ca
    For forgot to mention that I also used some "cable life" on my throttle cable. That may have helped some.
  11. k-moe
    If you still need to isolate the problem, unhook the throttle cable and manipulate the thottl linkage by hand (in neutral, on the center stand). That will telll you if it's the carb alignment, or the cable/ throttle tube. You might want to just go ahead and pull the throttle tube off for a good cleaning, and re-lube it with graphite.
  12. Polock
    sometimes that can work wonders
  13. Xjrider92117
    San Jose Ca
    I actually had a new throttle tube and replaced the old one which had a throttle lock (cruise control) on it. I clean but didn't grease it. I will do so.
  14. k-moe
    Do not use grease! Use a dry graphite powder. Grease will slow the action of the throttle tube, and gum-up in colder temperatures. Grease also gets gooey as it drys out, and as dirt works into it, which can lead to throttle return problems.
    Chitwood likes this.
  15. Xjrider92117
    San Jose Ca
    Sorry. That's what I meant
  16. Xjrider92117
    San Jose Ca
    Didn't get as much done today as I wanted but... I dusted the throttle tube with the graphite. Adjusted the throttle a bit. New plugs and caps. Adjusted the back brake a little. I really wanted to try to sync it again but didn't have time. Still got to ride today so that's always good. I'll get back probably next weekend with an update.
  17. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Synching the carbs, having them truly dialed in tight, can really make a surprising difference. It did for me.
    chacal and cgutz like this.
  18. Xjrider92117
    San Jose Ca
    I got to sync the carbs this weekend. It made a difference. Still not perfect but a bit better.
    I still need to tune with Colortune and sync again.
    Something else weird is going on. If I go out to start the bike cold it fires right up. If I ride for an hour and turn the bike off it fires right back up. If I want 5 minutes after a ride it struggles to start. Could this be caused by rich or lean conditions?
  19. Polock
    cold engines like richer, hot ones like leaner. after 5 minutes your is neither. if the carbs are tuned right and this happens you might need to learn just the right throttle routine to make it go. my lawn mower always did that
  20. XJ550H
    turn petcock to prime for 5 seconds then try in the 5 min start
  21. Xjrider92117
    San Jose Ca
    Try putting some gas in it dummy
  22. Stumplifter
    near Irma, WI
    No way! :p
    I did that once :oops:
  23. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    You've only put gas in it once?!
