Tapered steering stem bearings install
Discussion in 'XJ DIY How-To Instructions' started by shovel268, May 11, 2015.
  1. shovel268
    shovel268 Member
    Edmonton Alberta Canada
    hi can someone direct me to a link for installing steering bearing. I messed it up had the all balls kit. I put the larger skinny one on the steering steam and put the smaller fat one in the top of the neck upside down. but couldent get it to seat. it fell out landed in the dirt and bent the outter cage . and followed that up with some not nice words.
    thank you
  2. razz1969
    razz1969 Active Member
    Cleveland, Tx
    Got mine in yesterday, I might do a how to.
    NEEDtoRIDE likes this.
  3. chacal
    Please do that razz!
  4. saftie
    New York, NY
    Did you write anything up?
  5. razz1969
    Cleveland, Tx
    Its been raining non stop since i last posted.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    I started one as well since the question seems to come up frequently but I'm stalled until frame is back from powder. Lemme know if you are working on one so we don't duplicate efforts.
  7. saftie
    New York, NY
    Picking up my frame tomorrow and will work on bike on weekend. I'll figure it out, maybe take pics along the way.
  8. razz1969
    Cleveland, Tx
  9. saftie
    New York, NY
    excellent. better than a youtube video
    thanks much
  10. razz1969
    Cleveland, Tx
    Dont forget to like.
  11. saftie
    New York, NY
    Well, what do you know...
    I already messed that one up resulting in the destruction of the lower bearing.
    Put the dust seal on upside down and was not able to remove the already seated bearing again without destroying it.
    Also, the top ring will not sit flush, it is about twice as high?
    Here a pic of what I mean. It is sticking out too much. I didn't hammer it in all the way, just took a pic to show you. But i measured. Any ideas? I have an 81 xj550 h
    also, the bottom ring completely disappears inside the frame and falls out by itself.
    I might have the wrong set of bearings? Poop. Long weekend and I can't get started on the bike and its assembly.
  12. k-moe
    You probably have the upper and lower races (and bearings) fiipped around. They are different sizes.
  13. saftie
    New York, NY
    No. I thought of that but both were same in height, both fell out.
    I ordered a new set from Len, let's hope this will work.
  14. cutlass79500
    lawrenceville georgia
    Some of the all balls kits especially hondas are so confusing their directions suck . On hondas the upper race does stick up out of the steering head not as far as that. If you ever get in a bind get the numbers off the race and corresponding bearing and go to your local parts store and replace them since you will ruin the lower when you take it back off. A little trick of the trade put your races in the freezer and brgs in the oven they will go on much easier
  15. chacal
    They will!
  16. cutlass79500
    might be an optical illusion but has someone been welding on the lower part of the steering head to down tubes see what looks like a lot of slag
  17. saftie
    New York, NY
    Here a pic from weeks ago. Shows all the welds in that area
  18. saftie
    New York, NY
    Glad to hear Len and I don't doubt it.
    Have had no luck with bike parts lately...
  19. k-moe
    Is that part of a house framing angle I see?! Back away from the welder. That is not the sort of steel that should be used to gusset the steering neck of a motorcycle! What did you use for filler? Welding stainless (I looked the bracket up) to mild steel requires a different filler than mild to mild does. Did you consider that the galvanized finish not only contaminated the weld, it also created a posionous gas when you welded it? What did you do to control heat distortion of the neck? At least the bead looks decent. I'm sorry for the harsh criticism, but there are better materials for your application, and they cost less than that bracket.
  20. saftie
    New York, NY
    Interesting read. Not taken as harsh criticism at all. It is always good to learn, so keep the advice and observations coming.
    Learning to weld is on my list of things to learn in the future. Right now, no clue. For this project, someone else did all the welding and I had to trust his "expertise".
    Yeah, the bracket comes from home depot and is most likely a house framing angle.
    The triangle was only welded there as a stopper so the clipons are not hitting the tank when turning. Welding a piece of metal there seemed the easiest way to achieve that.
  21. saftie
    New York, NY
    The bearings from Len fit perfectly. The upper race was not as high, and fully seated it only sticks out 2 mm or so.
    Still trying to get the lower in properly as I am having a hard time getting the star shaped fix nut (sorry about the wrong terminology) on.
    I think I should have sanded down the powder coating first. That's probably the 2 mm I am now missing to get more thread for the fix nut.
  22. Adam Walker
    Adam Walker Member
    United States
    i've also got an '81 xj550 and was about to order an all balls kit. How can I, also, acquire these proper fit bearings?
  23. Adam Walker
    Adam Walker Member
    United States
    yeah those ^^^^^^
  24. saftie
    New York, NY
    Send a PM to chacal. He will hook you up. Excellent service, fast delivery. Got my stuff within two days, I am in NYC.
  25. Adam Walker
    Adam Walker Member
    United States
    muchos danke
  26. saftie
    New York, NY
    German?
  27. Adam Walker
    Adam Walker Member
    United States
    sperman...
  28. k-moe
    Spandeutsch more like.
  29. Adam Walker
    Adam Walker Member
    United States
    you must be from the other side of la pared
  30. k-moe
    Ich soy de verden.
  31. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    SperMan sounds like the worst superhero. Ever.
  32. chacal
    Thundrrr you're really funny..........
  33. MattiThundrrr
    Thanx. I have read some funny that you have posted too! I use humor to cover my lack of wrench skills and XJ know how. "Matti? He's that funny guy!" as opposed to "Matti? That jerk is always running his mouth." My only worry is that I sidetrack serious threads too much. Don't wanna get in the way of people's progress!
    (He said as he sidetracked yet another thread.)
  34. chacal
    Me too!
    Same here.....
  35. jayrodoh
    jayrodoh YimYam
    Cleveland
    I wish I would've thought to have my powdercoater mask off my VIN, cant read it now :(. Guess I'll be taping and lightly sanding soon.
  36. saftie
    New York, NY
    D'oh.
    Thankfully my powdercoater did that thinking for me...
  37. jayrodoh
    jayrodoh YimYam
    Cleveland
    Yeah, I'm a little surprised they didn't ask/mention it. He said he does a lot of frames.
  38. Adam Walker
    Adam Walker Member
    United States
  39. k-moe
    Whether or not you can restamp and install a VIN tag, or you have to have a shop do it depends on which state you live in. In either case there will be paperwork and usually a fee. This is not something you want to do incorrectly because if a buyer has any reason to suspect fraud you will be on a very big hook.
