throttle shaft seals
Discussion in 'XJ Technical Chat' started by bensalf, Aug 30, 2017.
  1. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    is it possible to change the throttle shaft seals on my carbs, (mikuni bs 32's) without removing the butterflies.
    I have some fine seal picks, going to order new seals to do job over winter. I don't like the look of the butterfly screws, on these carbs. I did the ones on my café racer, a couple of years ago, but frightened to try taking the screws out on these?
    cheers
    stu
    Unfortunately not. The construction of the linkages does not allow access to both seals unless the throttle plates and throttle shafts are removed.
  3. Plug
    Plug Active Member
    Missouri
    I had one screw that was too stripped to remove even after grinding the back off of it, but was able to drill it out without damaging the threads....the stripped out head made a perfect center....guess I got lucky.
  4. bensalf
    yorkshire ,england
    oh, right , --bummer:(
    stu
  5. Toomanybikes
    Tsawwassen bc
    That bike in your pic looks like wheelbase is a little shorter than it should be
  6. bensalf
    yorkshire ,england
    that's right ,forks were bent and headstock twisted.
    but this is what it looks like now.
  7. bensalf
    yorkshire ,england
    ahh, I've been blocked
  8. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Phuckbucket!
    Toomanybikes likes this.
  9. Toomanybikes
    Tsawwassen bc
    Phuckitbucket
    MattiThundrrr likes this.
  10. XJ550H
    i can see it . Very nice and shiny. nice job.
  11. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    It's a shame that a woman hasn't figured out how to swap them w/o removing the butterflies....any woman can remove and replace her bra without removing her shirt...she should be able to figure out how to replace those damned seals....but till that happens, we'll be pulling valves and using bondo and locktite red!
    jeff
  12. MattiThundrrr
    If they aren't able, but willing to learn, I give a seminar. I don't really focus on the replacement bit...
    Stumplifter likes this.
