"Top end only" rebuild question: clean out bottom end?
Discussion in 'XJ Technical Chat' started by SecaMaverick, Apr 20, 2010.
  1. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    I decided to do a top end rebuild on my 550 Seca, and there's 40,000 miles on her. While I was tapping the cylinder jug off, some of that gasket debris and rust from the studs got down into the bottom end (before I could get rags shoved in under the pistons.
    I'm only doing top end and am not splitting the case, so what's a good process for getting it cleaned out sufficiently? I plan on doing an oil and filter change within the first 50 miles.
  2. SecaMaverick
    Northeast Ohio
    No takers?
  3. wizard
    Drop the pan, 10 mins' as you have the pipes off already.
