Unidentifiable ports in float bowl Hitachi HSC32
Discussion in 'XJ Technical Chat' started by Robert W Blair, Nov 18, 2020.
  1. Robert W Blair
    Robert W Blair New Member
    Canada
    Hello
    There is a small port from the top of the bowl shell to the bottom of the inside of the bowl.
    It seems to have a fitting inside it.
    It does not permit fluid flow.
    Does anyone have a reference for it, what it should do normally?
  2. mlew
    mlew Well-Known Member
    Apex, NC
    Its the inlet jet for the enrichment(choke) circuit. It needs to be cleaned to allow fuel to flow. the orifice is small, a single strand from a wire brush will usually clean it out
  3. Robert W Blair
    Canada
    Thank You very much.
    Once clean will fluid visibly flow, such as carb cleaner?
  5. k-moe
    Also please keep all questions about your machine in a single thread. The history of what has been done makes it much easier to be able to help you as you refurbish her.
  6. XJ550H
    #80 drill bit glued into a q tip shaft use only if you have problems clearing the hole.
    yes there is a brass insert down that tube
  7. Robert W Blair
    Canada
  8. hogfiddles
    That is the enrichment well, and there is a very tiny non-removable jet down there. You MUST get it unclogged.
    Franz likes this.
  9. Robert W Blair
    Canada
    Got it, thanks
