Value of used XJ650 motor
Discussion in 'XJ Technical Chat' started by fastenova, May 24, 2011.
  1. fastenova
    fastenova Member Premium Member
    Redmond, OR
    What is a '82 maxim 650 motor/trans worth in "good" shape assuming good compression?
    This is a YICS motor with approx 22K miles on it, runs but carbs are clogged. I have my own set of carbs. I would just be buying the engine.
    I'm in Oregon, if region matters. Going to look at a motor this week and need some ideas of what to offer.
  2. Robert
    Assuming good compression you should expect to drop $200~300 depending upon condition. Does it include the starter? Carbs? If so, lean higher. If there is anything wrong with the compression, I wouldn't offer more than $100 for the parts.
