Valve adjusting tool xj650
Discussion in 'XJ Technical Chat' started by Carl LaFong, Apr 22, 2021.
  1. Carl LaFong
    Carl LaFong Member
    ontario
    Hi
    Anyone have the dimension for making this tool. Looks like a little work on a piece of angle iron.
    Also on line source for shims
    Thanks in advance for leads.
    Valve adjusting tool:
    Shim pool: start a conversation with @hogfiddles
    Roast644 and XJ550H like this.
  3. JCH
    JCH Active Member
    seattle wash
    The tool is relatively inexpensive... it's the shim's that can gets pricey unless you can find someone that's willing to do exchanging of shims, I found a Dealer here in my area but I think that they end up using or running out of the common used same shim size. I wouldn't used the cheap aftermarket shims because they don't fit right in the bucket, that's my experience anyway. I don't like using the wire or plastic tie method or putting anything between the valve face for that matter. The tool worked great for me.
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    The tool is a PIA to use, I much prefer the wire method. Hogfiddles runs a shim pool here, reach out to him for details on swapping shims.
  5. hogfiddles
    Dimensions are:
    1. get a bag of zip ties at harbor freight
    2. use them
    3. Go ride
    jayrodoh likes this.
  6. Carl LaFong
    Carl LaFong Member
    ontario
    I know this might be sacrilege but has anyone surface ground shims? Using original ungound side up.
  7. hogfiddles
    There are some who have done it, but it’s really pointless
    biggs500 likes this.
  8. Dave in Ireland
    Ireland
    Yep, when out in the backwoods with no money, I had to grind a shim or two.
    Worked fine, being careful.
    A decent micrometer or vernier is a must, though.
  9. bigfoot 56
    bigfoot 56 New Member
    rapid city sd
    where do you get the tool from
  10. biggs500
    biggs500 Active Member
    Sherwood WI
  11. hogfiddles
    Once again.....
    Or see k-moe’s wire pic
