what brake shoes do you recomend
Discussion in 'XJ Technical Chat' started by ElkHavenSeca, Feb 10, 2013.
  1. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    SOK semi metal ok to use so many different available on ebay .??
  2. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    I personally use EBC Kevlar. Any brand of Kevlar pads or shoes will last forever.
  3. ElkHavenSeca
    Sedro woolley wa
    Thank you
  4. bigfitz52
    I use EBC "standard" OEM replacements and they work great.
    DON'T use semi-metallic. The "drum" surface isn't that thick. Kevlar's fine too.
  5. mtnbikecrazy55
    I like ebc's pads on my maxim enough to get ebc's front a d rear for my Seca.
  6. bigfitz52
    I have EBC's OE replacement rear shoes on both my 550s; and EBC pads (whatever "matches" their rotor) on the front of the '83 with an EBC floating rotor.
    I used Yamaha pads with the (drilled) Yamaha rotor on the '81.
    Both bikes have fully rebuilt hydraulic systems and stainless lines.
    The EBC brake still outperforms the improved stock brake; but I can't say how much is pads and how much is the hi-po modern rotor (or the combination of both.)
  7. ElkHavenSeca
    Sedro woolley wa
    As always thank you fitz .. your knowledge is priceless !
  8. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    ElkHavenSeca,
    Ask Fitz about "Girling" the rear drums to get proper contact and allow drums to conform. I thought that was neat. Gonna do it next time a change my drums.
    Gary
  9. bigfitz52
    The term is "centralising" or in Amurrican, "centralizing."
    The (rear) brake on the Norton was made by Girling. Not a bad application though, "to Girling" your brake...
