What is this?
Discussion in 'XJ Technical Chat' started by Robb, Oct 5, 2016.
  1. Robb
    Robb Member
    Bolingbrook, IL
    I just finished wrapping up my XJ750 Seca after changing the steering head bearings. I think I remember taking this piece of harness out of the headlight bezel but can't remember where it goes, also everything seems to be working properly and I can't find any unmatched connectors in the bezel. Does anyone recognize this?
    That does not look familiar to me either.
  3. Greggy
    Greggy Member
    Ohio
    I just seen that rubber piece on the right side of wires in your picture, it goes to the starter solenoid, right next to the battery
  4. Greggy
    Greggy Member
    Ohio
    I can check and see were it goes tomorrow if you need me to, let me know
  5. Toomanybikes
    Tsawwassen bc
    Fuel level sensor wire?
  6. Robb
    Robb Member
    Bolingbrook, IL
    Thanks for the offer Greggy but... brain cells have just been stimulated by your post... this is the connector that goes to the stator in my CB650 Honda. I replaced the stator a few weeks ago and this is the connector from the old one. It must have gotten mixed up with the Seca parts. That rubber connector has been haunting me. It's the seal for the back of the alternator case where the wire passes through.
    TheCrazyGnat and k-moe like this.
  7. k-moe
    nope.
    DrewUth likes this.
  8. k-moe
    nope.
  9. Robb
    Robb Member
    Bolingbrook, IL
    Just confirmed... it's from the Honda. Thanks for your responses.
  10. Toomanybikes
    Tsawwassen bc
    From a Honda?so it's not a fuel sensor wire, maybe neutral indicator? So you hiding Honda parts in your seca??? Smuggling Honda parts to a Yamaha party...
    The grommet on the wire was the stumper.
    Stumplifter likes this.
  11. Toomanybikes
    Tsawwassen bc
    You say "the" Honda ,what model ?
  12. Toomanybikes
    Tsawwassen bc
  13. Greggy
    Greggy Member
    Ohio
    It looked like this piece, but no not so much
  14. Robb
    Robb Member
    Bolingbrook, IL
    No, when I replaced the stator and rotor in my CB650 a couple months ago this connector was left on the floor and somehow got pushed behind the lawn mower when I cleaned up afterwards. I did a much more thorough clean up after changing the Seca's steering head bearings... actually pushed the lawnmower out of the way and swept behind it, which is where the mystery part turned up.
    The good news is, I finally found the little Yamaha emblem that covers the two screws that hold the center handlebar cover. When I took this thing off I thought "this looks like something I'm going to loose", so I put it someplace where I wouldn't lose it... or find it. (In the case with the Dremel.) I forgot my number one rule for not losing easily lost parts.... pretend you just lost the item and then put it in the first place you look for it.
    Stumplifter and Toomanybikes like this.
  15. Toomanybikes
    Tsawwassen bc
    I have a "what the hell is it bucket" just for those things you can't toss because you know it goes somewhere and once a month I sort everything by brand and tag them ;)
    quebecois59 and Robb like this.
