Whos good with electronics?
Discussion in 'Hangout Lounge' started by Toreadorranger, Jan 27, 2009.
  1. Toreadorranger
    Toreadorranger Member
    Salem, CT
    Im in the process of eliminating all the switches from the handlebars on my XJ650. Im going to be building a special plate that will hold the switches along with my mini speedo. to start the bike I need a momentary switch correct? I found a Momentary On-OFF switch. I eliminated the turns so the only other switch I need is for the Hi-Lo beam. Which would be a On-On switch.
    So if Im correct are these the right switches?
    To start the bike,
    Toggle Switch - 20 Amp Sealed Screw Terminal SPST MOM-OFF
    To switch high to low beams,
    Toggle Switch - 20 Amp Sealed Screw Terminal SPDT ON-ON
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    I would use an Off-On-On to be able to kill the lights when starting and if ever needed.
    Look here at this diagram I modified to simplify everything!
  3. dwcopple
    bay city, michigan
    the switch would go on the G line to the Headlight. I am not running a HI/LO light so I modified it
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    You need a Momentary "ON" for the start switch, and a SPDT (ON-ON NOT ON-OFF-ON) for the hibeams like you said. The start switch doesn't have to be high current, the headlight switch can be 20A but that's overkill, 10A would be fine with stock lights.
  5. Toreadorranger
    Salem, CT
  6. dwcopple
    bay city, michigan
    yessir
  7. dwcopple
    bay city, michigan
    dude, autozone and advance auto, pep boys, etc. all have 'em on the shelf as well as a kick-a$$ 6 ATC fuse block for far less $$$... And the fuse block has a single power in!!! Simple to hookup and less wires too!
  8. Toreadorranger
    Salem, CT
    I have chacals fuse block already so thats not needed, but tomorrow Ill make sure to check autozone and advanced auto.
