Wiring Diagram Help
Discussion in 'XJ Technical Chat' started by Jmkrull, Feb 12, 2018.
  1. Jmkrull
    Jmkrull Member
    Minneapolis
    Quick Question. None of the the wiring diagrams I've seen give anything remotely useful in terms of a direct pin to pin layout. Right now, I'm strugling with the 3 white 14g wires into the regulator/rectifier off the alternator (not sure why they didn't throw another color in there...) There are three on the bottom of the 4x2 rectifier female connector and a 2-above-1 male off the alternator. Does anyone have a good wiring diagram that traces out pin to pin a little more than just an empty block with indescript wiring going into it?
    Mainly though, as I can figure it out for the most part, what is the pin to pin on the reg/rect to alternator? looking at it from the "front" or connector side of each connector. So, red top left on the reg/rect and the two vertical pins on top for the alt. Thanks.
  2. Jmkrull
    Jmkrull Member
    Minneapolis
    http://www.xj-forum.de/schaltplaene/xj650_maxim/wiring_diagram.pdf
    I found this. It's better. Does this mean it doesn't really matter?
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    its a three phase alternator , makes no difference which way the 3 white wires are.
    stu
    Jmkrull likes this.
  4. Jmkrull
    Jmkrull Member
    Minneapolis
    Awesome! Thank you
  5. bensalf
    yorkshire ,england
    not sure about the 650 but my 600 has "if you look closely" a faint tracer colour red and blue on 2 of the white wires.
    stu
