Wiring Harness Routing??
Discussion in 'XJ Technical Chat' started by outacontrol, May 17, 2021.
  1. outacontrol
    outacontrol New Member
    Oregon
    I have an 82 650rj and it did not have a wiring harness when I bought it. I purchased a harness from a member and should of asked for pictures of the routing. Does anyone have pictures of the routing of this harness?
    thank you
    its in the manual
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    If you need anything more detailed, I have a stock 650rj sitting in the garage now partially torn down. Can take some pics if needed.
    One note that is not shown above, there are two "main" harnesses that come out of the back of the head light. They should criss-cross when going to the frame. The left harness should cross over and go down the right side of the frame and vice-versa. This helps keep the harness from getting tugged when turning the headstock.
