Wiz goes cafe
Discussion in 'Other Motorcycles' started by wizard, May 25, 2011.
  1. wizard
  2. zap2504
    zap2504 Member
    Middletown, PA
    There was a guy on the Adventure Riders forum that took a clapped-out Connie and made it naked. Don't think he ever completed the project documentation on-site but it looked like a good concept - actually looked much like a Seca when he took off the fairing/tail and grafted on a XS400 headlight and built a custom seat.
  3. wizard
    Yes, could be an interesting project......
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I'm not usually one for Kawasakis, but I'm sure yours will look awesome. You do a great job on your bikes and can't wait to see this one done.
  5. markie
    markie Member
    Suffolk, England
    I've got to say that Goose's Kwacka still looks horny after all these years.
    Go on Wiz!!
    I wonder how the police would react??!!
  6. wizard
    It will have lights & brakes, markie........
  7. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Thanks Wiz. Can't wait to see you in action.
  8. wizard
    What a difference a day makes ;o)
  9. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    Hey wiz, I've been following your newest pickup....I've tried to stay away from cafe`'ing anthing as I'm worried it will activate the "go fast" button in my brain(and I'll end up broken) but looking at that bike, from this angle it looks to me like a sleeker tank, getting rid of all that clutter at the top of the triples and a smaller front fender and a different exhaust could do wonders.....then it would be time for all the detail goodies such as speciality brakes, grips, controls and trim, you know, the stuff that drains the wallet<LOL>....enjoy your build. It's always fun watching another guy's perspective come to life and as many others here have noted, you do nice, well thought out work.
    jeff
  10. markie
    markie Member
    Suffolk, England
    How many 2 stroke triples have you got Jeff!!
  11. wizard
    JeffK, I'm going with that tank, it's 'beamy'to master the radiator + I might want to go on a looooong journey.
    Before I go any further I need to know I have a strong running motor, so, get the valves in spec', check the comp'then pull the carbs for a clean & sync.
  12. Polock
    are those the cow shim under bucket shims ?
    from time to time kzrider folks seem to strip the cam cap bolts, yours is a newer design but be careful anyhow
  13. cutlass79500
    lawrenceville georgia
    have you driven it yet ? you know the motor is based of the old zx11 and zrx motor with milder cams. I never had a problem with my zx but if it was ridden pretty hard they have a bad time with 2nd gear. They also have a oiling problem with #3 rod .They might have fixed the problem. If it is ever dropped the way the pan is shaped and pick up position till they stall they have no oil pressure it shows its evel head after a few thousand miles. There is a tip over switch that kills the motor if it falls you can get if your worried. I had a zrx and a ninja both with low miles and never had a problem
  14. TIMEtoRIDE
    C'mon - -Wizard doesn't drop bikes !!
    But I can't believe you wouldn't want to enjoy the whole "sport touring" sensation before the tear-down. Isn't it "winter" there??
  15. wizard
    Yeh winter, been raining all week.
    Polock, no shims under buckets here I'm glad to say, just good old ajdustable tappets, all 16 of them ;o)
  16. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Wiz, I read with interest your observation about the weather. Winter time and raining. It is as summer here in the state of Washington as it is winter where you are and we have not had 6 sunny days since the first of the year! PLENTY of rain though. I love the rainy weather but I have just about had enough.
    Ride safe and stay dry!
    Loren
  17. bigfitz52
    Wiz, I was looking at the fiche for that bike. Interesting valve train, very clever. Wait until you take the carbs apart; some interesting design "licks" in there. Also noticed that virtually every part is still available, and not super expensive. There's even a separate section in the fiche called "carburetor parts."
    Looks massive. Good luck "paring" it down.
  18. wizard
    Pictures of the Keihin CVK 32 carbs.........
  19. Alive
    Alive Active Member
    Queensland, Australia
    Watches with anticipation :)
  20. TIMEtoRIDE
    Would be cool to adapt a "remote" idle adjuster to the XJ rack now that I've used them on the GL1500 and the ZZR1200.
  21. wizard
    We could have a contest for the most imaginative design..
  22. Polock
    i've got to stand on my head with a glove on now, how much more remote can it get ?
  23. TIMEtoRIDE
    Well I'd lose in the "imagination" part, because look what I found -
    http://cgi.ebay.com/ebaymotors/06-Yamah ... 212wt_1136
    Who wants to take bets that the thread pitch is the same?? A bolt-in or easy mod?? (sorry for off-topic).
  24. JeffK
    How many 2 stroke triples have you got Jeff!![/quote]
    Yeah but the reality is that none of them, save the 74 H2 make the power of even my lowly DL1000 and it sure isn't known as a powerful bike.
    2 strokes have a reputation that far exceeds the reality....but they are still a blast to ride.
    Wiz, I can understand wanting the liters, especially if distances between stops are as far as we here they are.....but it's HUGE on that frame....maybe an aux tank hidden away somewhere? LOL....
    jeff
  25. wizard
    Here's another easy way to set the rack up for float adjustments.
  26. wizard
    I had to get another comp' gauge, one that could reach down into the deep plug recceses, anyhow, I got strong readings, not that even across the 4, but I'm not too bothered about that as the motor has not run for 7 years & the valves were out of spec', I'll get it running for a while, then check again. Just finishing the feul levels in the bowls, then I'm pretty much ready to fire her up.
  27. wizard
    She's running. ;o)
  28. JeffK
    Isn't that the greatest feeling? Hearing an engine that has layed dormant for years, come back to life....right up there with cotton swabs cleaning a ear itch and s**.
    Congrats,
    jeff
  29. wizard
    I think this is where the chop comes.
  30. wizard
    Good news day, got the carbs synced, I used the 2 tube liquid manometer, with these you have to ballance 1 with 2, then 3 with 4, then ballance the 2 pairs. All good no smoke, charging at 14.8 v @ 2K. Fan cutting in OK, so lets get on with the chop. ;o)
  31. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    I like this, simple but very innovative. Gonna give that a go!
  32. wizard
    2 steps forward & 3 back, I can only find one gear ;o( the PO said the gears were fine lol.
  33. Maxim-X
    ...ah, but did he say when? :roll: :roll:
  34. wizard
    Panic over, apparently these bikes have a 'neutral finder', which only allows you to select first & neutral while stationary, save you 'fishing for'neutral.
  35. wizard
    Made the templates for the rear set peg brackets, the right has to accomodate the brake pedal & M / cylinder.
    These will be cut from 5mm m/s plate.
  36. wizard
    Left side rear set roughed in, gear shift reversed & extended.
  37. Maxim-X
    Hey Wiz, you using a Plasma cutter? That's some clean looking ilnes on those cuts? If you are, why not use T60XX Aluminium and polish the Sh*t out of them?. Just sayin'.
  38. wizard
    That's all handraulic, mini angle grinder, drills, bench grinder = hard yacka.
  39. wizard
    Right rear set / brake set up & tail pipe mock up.
  40. wizard
    Template made for rear mudguard & remote linkage for key opperated seat catch.
  41. wizard
    Final solution to the pipes / cans.
    I'm going to try to keep these meters & build an ally' case.
  42. gunnabuild1
    gunnabuild1 Member
    Pipes look good almost contemporary,tell you what Wiz if anyone can make that fat lady dance it will be you!
    Can you make her comfortable enough to ride for that big tankful though?
  43. wizard
    I don't know about dance, but I'll let you know when she sings. ;o)
  44. wizard
    New meter casing made.
  45. gunnabuild1
    gunnabuild1 Member
    Speechless, that case looks magic!!
  46. markie
    markie Member
    Suffolk, England
    Hi Wiz.
    After you have finished, you'll have to ride by a local weighbridge and see how much weight that lady has shed.
  47. wizard
    Thanks, it's all a bit of a leap into the unknown. 8O
  48. Maxim-X
    Well if that's the case, then I'd say you landed on your feet after that leap!
    Nice bit of work mate!
  49. wizard
    Front fender remodeled.
  50. Maxim-X
    I played with your picture a bit, hope you don't mind. I thought a bit more scalloping on the fender would follow the lines of the tire, rim and forks. I know it's a bit rough, but you can see what I'm aiming for.
