XJ 550 testing charging system
Discussion in 'XJ Technical Chat' started by wkxj, Aug 20, 2018.
  1. wkxj
    wkxj Member
    nm
    Hello, I'm looking for info on testing my charging system.
    I bought a new gel battery and was hoping it would do the trick. Part of the time it will charge around 4k rpm's but not all of the time and now the battery is getting drained enough that the bike isn't starting. I checked and cleaned the the plate and brushes. The bike does not like to run well between 2 and 3 k rpm's. I'm looking for some tests to use on the bike.
    Thanks Will
    the basic tests are covered in this thread way at the bottom
    make sure your grounds are there and clean.
    one is on the coil mounting bolt this is the harness ground . the one from battery to motor and from motor to frame at the battery box mounting screw
  3. wkxj
    wkxj Member
    nm
    Thank You!
  4. XJ550H
    I remember that rusty plate
  5. wkxj
    wkxj Member
    nm
    yeah no doubt lol. It was pretty crusty
