xj 600 s uk bike electrical questions (help)
Discussion in 'XJ Technical Chat' started by andy willi, May 5, 2020.
  1. andy willi
    andy willi Member
    doncaster UK
    just a quick couple of questions i hope someone can help me . check the pictures out the one with 3 wires is for the indicators can you tell me where they go in the flasher can as the previous owner has cut them off and the other picture s two spare wires and i think they are for the carb heater but dont match up to the wires on the carbs so i thin there is somthing missing all help would be apresiated ,
    see the buld in the hang out lounge ( what have i bought )
    IMG_20200504_161134.jpg IMG_20200504_161140.jpg IMG_20200504_161148.jpg IMG_20200504_161151.jpg IMG_20200504_161151.jpg IMG_20200504_161148.jpg
    600.PNG Br/w would go to pin marked load. Br is hot wire
  3. andy willi
    andy willi Member
    doncaster UK
    still no confused ,
    andy
  4. SQLGuy
    SQLGuy Well-Known Member
    He didn't include enough to see what 28 is. I'd guess it's a three wire flasher module. If so, a generic three wire flasher module should work, with supply on brown, ground on black, and load on brown/white.
  5. SQLGuy
    Black/white is the safety circuit ignition disable to prevent you from cartwheeling your bike by accidentally driving off with the sidestand down. It connects to the TCI.
  6. XJ550H
    28 is the flasher relay
  7. andy willi
    andy willi Member
    doncaster UK
    indicators now sorted generic flasher can and wired up worked first time now just the front lights to sort having major problems with this difficult to explain but turn the side light on all is ok turn the headlight on side light goes out and no headlight , press the high beam flash and side light goes out , on my xj 550 the engine needs to be running for the headlight to work so i asume this is the same but engine wont run for a month awaiting parts any help will be apresiated as the wiring diagram i have is poor to say the least , so if anyone has a good diagram please can i have a copy (xj 600 diversion 4br uk model 1995 ).
    andy
  8. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  9. Mavrick9
    Mavrick9 New Member
    Jamaica
    Can anyone tell if there is a black box that can be used as a substitute for the one on the xj550?
