XJ PARTS CATALOG, SECTION L: AXLES, WHEELS, TIRES
Discussion in 'XJ4Ever - Supporting Vendor' started by chacal, Oct 11, 2013.
Thread Status:
Not open for further replies.
  1. chacal
    SECTION L:
    WHEELS, AXLES, AND TIRES:
    -- Front Wheel Bearings, axles, speedometer drive, and related.
    -- Rear Wheel Bearings, axles, and related.
    FRONT WHEEL BEARING, AXLE, AND SPEEDOMETER DRIVE PARTS:
    wb2) Original and aftermarket wheel and axle parts, bearings, and seals will restore that like-new ride and feel to your machine.
    Note that if you plan to replace the bearing yourself, that removal of pressed-in bearings such as these can be rather difficult without special tools. We have individual removal/driver tools as well as an 8-piece bearing removal tool kit to help make this job easier, and which are listed further below.
    How to check for worn annular ("ring-shaped") bearings:
    - With the wheel off the ground, grab the tire with hands opposite each other. If the axle is pointing at your navel, push one hand away and pull the other toward you, then reverse the motion. If you feel play, the bearings are shot.
    - Or with the wheel off the bike, stick your finger in the axle hole and rotate. If you feel anything "crunchy," the bearings are shot. Do both sides of the wheel.
    - Worn wheel bearings can make the wheel "wobble", feel like it's out of balance, not allow the back to track straight, or can make it feel as though the bike has a tire low on air.
    Wheel Bearing Removal:
    NOTE: if using our ever-so-handy wheel bearing removal split-collar driver tools, then you can ignore all of this!:
    - Use a long punch (should have a good edge) or the bearing removal tools that we offer.
    - Remove any circlips or retainers.
    - Insert the punch into the wheel and catch the edge of the bearing on the other side. Using a hammer, hit the punch and work around the entire circumference of the bearing. The bearing and seal will eventually be pushed out of the wheel hub.
    - The second bearing can be removed using a punch, a long socket or other suitable driver.
    NOTE: bearings will be damaged during the removal process and should not be reused. The hammer blows transmit their impact through the balls causing small flat spots, which will cause the bearing to quickly fail if reused.
    A fine guide to wheel bearing replacement can be reviewed at:
    http://xjbikes.com/forums/index.php?threads/35134
    and
    http://www.xj4ever.com/wheel%20bearing% ... cement.pdf
    Inspection:
    - Inner Spacer: Check the bore to make certain it is clean and the axle easily passes through it. Check each end for wear and burrs. The edges must be square to seat properly against the new bearings.
    - Wheel Hub: Clean the hub, removing any dirt and corrosion. Make certain not to remove metal. This will adversely affect bearing fit.
    - Outer wheel spacers: Clean the outer wheel spacers and inspect them for wear on either end as well as wear on the outer surface where it makes contact with the seal. If the spacers are excessively worn they should be replaced.
    Wheel Bearing Installation:
    NOTE1: Improper installation will cause bearing damage and dramatically reduce bearing life.
    NOTE2: Freezing the bearing overnight and Heating the wheel hub will cause the hub to expand slightly and will make bearing installation much easier. Make sure the area of the hub that the bearing will be installed into is clean, free of any nicks or burrs or flaws. Polish lightly with 400-grit (or finer) paper for a silky smooth finish, and apply a thin film of lubricant to this area before driving the bearing home properly and evenly.
    The three simple rules to bearing installation are:
    1. Apply pressure ONLY to the outer race of the bearing.
    2. Apply pressure evenly so the bearing remains square to the wheel hub.
    3. Remember to place the inner spacer between the bearings, and make sure to re-install or acquire the proper SPACER FLANGE for your application and model. This thin, flat, flanged spacer fits over one end of the spacer tube, and is vital to proper wheel bearing orientation and performance. Because it is so small, it is easily lost or mis-placed during wheel dis-assembly.
    Definitions: All bearings that we offer are high-speed, single-row ball bearings. Roller-element bearings (ball bearings and roller bearings) are rated according to the standards and specifications of the Annular Bearing Engineers Committee (ABEC), and are graded by how precisely they are machined to their dimensional tolerances. Although other factors come into play in determining the "quality" of a bearing----such as the type and quality of the grease that the bearing is packed with----for all practical purposes, you can consider a bearing with a higher ABEC rating number to be a better quality bearing (1 being the lowest and 7 being the highest for metric-sized bearings). And the more precisely a bearing is machined and assembled, the more costly it will tend to be.
    "Standard-duty" bearings are rated at least to the ABEC-1 standard for bearing design tolerances, and thus for their reliability and longevity in these wheel bearing applications. Depending on usage and conditions, these bearings are good for 20 - 50,000 miles of "typical" use.
    "Medium-duty" bearings are of the same type and grade as used by Yamaha originally, and meet their standards. Although nominally rated at an ABEC-1 standard, most will actually pass the ABEC-3 standard upon inspection. Depending on usage and conditions, these bearings are good for 50,000+ miles of "typical" use.
    "Extreme-duty" bearings are rated at least to the ABEC-3 (or higher) standard for bearing design tolerances, and thus for their reliability and longevity in these applications. Depending on usage and conditions, these bearings are good for the lifetime of your bike with "typical" use.
    By the way, bearings are available that meet ABEC-5 and ABEC-7 standards, but they are outrageously expensive, as they are designed for ultra-duty applications, military equipment and the like, and are not offered by us.
    Some thoughts on the factors that you want to consider when replacing wheel bearings are discussed here:
    http://xjbikes.com/forums/index.php?threads/33443
    Wheel bearings fail for a number of different reasons:
    - old age, usage greater than their intended life expectancy.
    - improper installation techniques (surest and quickest way to kill bearings!). This includes banging on the inner race (the "inner ring") or over-torquing the axle retaining bolts.
    - environmental contamination, especially moisture intrusion caused by high-pressure spray washers which force water in and grease out of the races.
    - extreme use (racing, etc.) that generate heat and loads greater than the bearing grade is designed for.
    - too little, too much, or incorrect type of grease. Although many bearings are sold as "sealed" bearings, for the longest life and best performance, they should periodically be cleaned and re-greased. Too much grease is a bad thing, as it causes the balls to have to "fight" their way through all of the grease, building heat, and thus shortening the bearing life. Most bearings require a 30-40% "fill rate" in their cavity to be properly lubricated, with a high-temp, high-load, water resistant grease such as our HCP8608 Red Moly Grease.
    Finally, ALWAYS replace at least the wheel axle "castle nut" COTTER PINS whenever they have been removed.
    By the way, a neat little "visual tour" of bearing manufacturing are made can be found at:
    Front Wheel Bearing, Seals, and Kits:
    all XJ550, FJ600, XJ600, XJ650, XJ750 air-cooled, and all XJ900 models:
    HCP1786 OEM front wheel medium-duty BEARING, double-sealed, high-speed ball bearing is an exact match of the originals used on all XJ550, FJ600, XJ650, XJ700, 1981-83 XJ750, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Use 2 per wheel. Each:
    $ 42.95
    HCP14334 Aftermarket front wheel high-performance EXTREME-DUTY BEARING, double-sealed, high speed, heavy-duty ball bearing is a correct fit and replacement for the original bearings used on all XJ550, FJ600, XJ650, XJ700, 1981-83 XJ750, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Use 2 per wheel. Each:
    $ 47.95
    HCP1788 OEM front wheel right side bearing GREASE SEAL. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, 1981-83 XJ750, XJ750RL, XJ750-X, and all XJ900RK, RL, N/FN, and F models. models. Also fits all of the following models: 1977-83 XS400, 1982-83 XZ550, 1986 SRX600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-99 XV1100 Virago models. Use 1 per bike. Each:
    $ 14.95
    HCP18754 Aftermarket front wheel right side bearing GREASE SEAL. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, XJ700, 1981-83 XJ750, XJ750RL, XJ750-X, and all XJ900RK, RL, N/FN, and F models. models. Also fits all of the following models: 1977-83 XS400, 1982-83 XZ550, 1986 SRX600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-99 XV1100 Virago models. Use 1 per bike. Each:
    $ 11.95
    HCP1790 OEM front wheel left side bearing GREASE SEAL. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, 1981-83 XJ750, XJ750RL, and all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. models. Also fits all of the following models: 1977-83 XS400, 1982-83 XZ550, 1986 SRX600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-99 XV1100 Virago models. Use 1 per bike. Each:
    $ 15.95
    HCP18753 Aftermarket front wheel left side bearing GREASE SEAL. Fits all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, XJ650, 1981-83 XJ750, XJ750RL, and all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models. models. Also fits all of the following models: 1977-83 XS400, 1982-83 XZ550, 1986 SRX600, 1984-87 XV700 Virago, 1988-97 XV750 Virago, 1984-85 XV1000 Virago, and 1986-99 XV1100 Virago models. Use 1 per bike. Each:
    $ 12.95
    HCP1915 Aftermarket complete front wheel standard-duty BEARINGS AND SEALS KIT, for all XJ550, FJ600, XJ650, 1981-84 XJ750, and all XJ900RK, RL, N/FN, and F models. Two bearings and two seals.
    $ 42.95
    HCP14311KIT OEM complete front wheel medium-duty BEARINGS AND SEALS KIT, for all XJ550, FJ600, XJ650, 1981-83 XJ750, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Contains two bearings and two grease seals.
    $ 99.95
    HCP14380KIT Aftermarket complete front wheel high-performance EXTREME-DUTY BEARINGS AND SEALS KIT, for all XJ550, FJ600, XJ650, 1981-83 XJ750, XJ750RL, and all XJ900RK, RL, N/FN, and F models. Contains two bearings and two grease seals.
    $ 104.95
    HCP19748 Aftermarket complete front wheel standard-duty BEARINGS AND SEALS KIT, for all XJ600 Seca II models. Two bearings and three seals.
    $ 39.95
    all XJ700 models and XJ750-X water-cooled models:
    $ 42.95
    $ 47.95
    $ 14.95
    $11.95
    HCP21439 Aftermarket complete front wheel standard-duty BEARINGS AND SEAL KIT, for all XJ700 and XJ750-X models. Two bearings and one seal.
    $ 42.95
    HCP14324KIT OEM complete front wheel medium-duty BEARINGS AND SEAL KIT, for all XJ700 and XJ750-X models. Contains two bearings and one right-side grease seal.
    $ 89.95
    HCP14381KIT Aftermarket complete front wheel high-performance EXTREME-DUTY BEARINGS AND SEAL KIT, for all XJ700 and XJ750-X models. Contains two bearings and one right-side grease seal.
    $ 104.95
    all XJ1100 and XS1100 models:
    HCP1787 OEM front wheel medium-duty BEARING, double-sealed, high speed ball bearing is an exact match of the originals used on all XJ1100 and XS1100 models. Use 2 per wheel. Each:
    $ 49.95
    HCP14336 Aftermarket front wheel high performance EXTREME-DUTY BEARING, double-sealed, high speed, heavy-duty ball bearing is a correct fit and replacement for the original bearings used on all XJ1100 and XS1100 models. Use 2 per wheel. Each:
    $ 59.95
    HCP1789 OEM front wheel right side bearing GREASE SEAL. Fits all XJ1100 and XS1100 models. Use 1 per bike. Each:
    $ 21.95
    HCP18755 Aftermarket front wheel right side bearing GREASE SEAL. Fits all XJ1100 and XS1100 models. Use 1 per bike. Each:
    $ 16.95
    $ 15.95
    $ 12.95
    HCP1796 OEM front wheel axle shaft hub DUST COVER. Fits all XJ1100 and XS1100 models. Use 1 per bike, on the right side of the wheel. Each:
    $ discontinued
    HCP1916 Aftermarket complete front wheel standard-duty BEARINGS AND SEALS KIT, for all XJ1100 and XS1100 models. Two bearings and two seals comes with this kit. The right side wheel hub dust cover is not included.
    $ 42.95
    HCP14386KIT OEM complete front wheel medium-duty BEARINGS AND SEALS KIT, for all XJ1100 and XS1100 models. Contains two bearings and two grease seals. The right side wheel hub dust cover is not included.
    $ 119.95
    HCP14382KIT Aftermarket complete front wheel high-performance EXTREME-DUTY BEARINGS AND SEALS KIT for all XJ1100 and XS1100 models. Contains two bearings and two grease seals. . The right side wheel hub dust cover is not included.
    $ 139.95
    Front Wheel Axle Shaft and Related Hardware:
    HCP1779 OEM front AXLE SHAFT, fits all XJ550, XJ650, XJ700, and XJ750 (except 1984 XJ750RL), 1982-83 XS400 J/RJ, 1982-83 XZ550RJ Vision, 1982-83 XT550, 1983 XV500, 1981-83 XV750 Virago , 1983 XV750MK Midnight Virago, 1982-83 XV920 Virago, 1981-82 XV920RH Virago, and 1983 XV920MK Midnight Virago models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 149.95
    HCP1781 OEM front wheel AXLE SHAFT, for all XJ700 and XJ750-X models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 149.95
    HCP20007 OEM front wheel AXLE SHAFT, for all 1984-85 FJ600, 1988 FZ600, 1987-90 YX600 Radian, and 1986 SRX600 models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 34.95
    HCP27921 OEM front wheel AXLE SHAFT, for all 1992-98 XJ600 Seca II, 1997-07 YZF600R, 1992-93 TDM850, and 1989-90 FZR1000 models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 84.95
    HCP19760 OEM front wheel AXLE SHAFT, for all XJ1100, XS1100, 1972-73 XS2 / TX650, 1974-77 XS650, 1978-83 XS650 Specials, 1977-79 XS750, all 1980-81 XS850, 2015-16 SR400, 1978-81 SR500, and 1973-74 TX750 models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 79.95
    HCP1806 OEM front wheel axle shaft CASTLE NUT, for all XJ550, XJ650, 1981-83 XJ750 models, XJ750-D, XJ1100, and XS1100 models.
    $ 12.95
    HCP1807 OEM front wheel axle shaft LOCKING NUT, for XJ750RL and all XJ900RK, RL, N/FN, and F models.
    $ 10.95
    HCP1805 OEM front wheel axle shaft castle nut WASHER, for all XJ550, XJ650, all 1981-83 XJ750 models, XJ750RL, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models.
    $ 5.95
    HCP1803 OEM front wheel axle shaft castle nut COTTER PIN, for all XJ550, XJ650, XJ700, 1981-83 XJ750 models, XJ750-D, XJ750-X, XJ1100, and XS1100 models.
    $ 8.95
    HCP16053 Aftermarket front wheel axle shaft castle nut COTTER PIN, zinc-plated steel, for all XJ550, XJ650, XJ700, 1981-83 XJ750 models, XJ750-D, XJ750-X, XJ1100, and XS1100 models.
    $ 4.95
    HCP16054 Aftermarket front wheel axle shaft castle nut COTTER PIN, stainless steel, for all XJ550, XJ650, XJ700, 1981-83 XJ750 models, XJ750-D, XJ750-X, XJ1100, and XS1100 models.
    $ 5.95
    HCP1783 OEM front wheel axle shaft COLLAR, for all XJ550 Maxim models, XJ650 Maxim and Midnight Maxim, 1981-83 XJ750, 1981-83 XV750 Virago, and 1982-83 XZ550R Vision models. This is the approximately 1" long tube that is fitted on the right side of the wheel hub.
    $ 23.95
    HCP1785 OEM front wheel axle shaft COLLAR, for all XJ550 Seca models, FJ600, XJ650RJ Seca and XJ650 Turbo models, XJ700, XJ750-X, XJ750-D, XJ750RL, and all XJ900RK, RL, N/FN, and F models. This is the approximately 1" long tube that is fitted on the right side of the wheel hub. Without this spacer in place your caliper may rub against your disc brake rotor.
    $ 24.95
    HCP1784 OEM front wheel axle shaft COLLAR, for all XJ1100 and XS1100 models. This is the approximately 3/4" long “stepped” spacer that is fitted on the right side of the wheel hub.
    $ 39.95
    HCP1791 OEM front wheel axle shaft SPACER TUBE, for all XJ550 models, FJ600, XJ650 models, all XJ700 models, all 1981-83 XJ750 models, XJ750RL, XJ750-X, and all XJ900RK, RL, N/FN, and F models. This is the approximately 6" long tube that is fitted through the length of the wheel hub.
    $ discontinued
    HCP1792 OEM front wheel axle shaft SPACER TUBE, for all XJ1100 and XS1100 models as well as all of the following models: 1973-74 TX650, 1973 TX750, 1975 XS650, 1978-83 XS650 Specials, 1979 XS650 Special II, 1980 XS650 Standard, 1977-79 XS750 all models, 1980-81 XS850 all models, 1978-81 SR500, and 1987-2000 XV535 Virago models. This is the approximately 6" long tube that is fitted through the length of the wheel hub.
    $ 17.95
    HCP1794 OEM front wheel axle shaft FLANGED SPACER RING, for all XJ550 models, FJ600, XJ650 models, all XJ700 models, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. This incredibly thin, flanged shimming washer is on the left side of the wheel, behind the bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
    $ 7.95
    HCP1795 OEM front wheel axle shaft FLANGED SPACER RING, for all XJ1100 and XS1100 models. This incredibly thin, flanged shimming washer is on the left side of the wheel, behind the bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
    $ 8.95
    Lower Fork Tube Axle Retaining Hardware:
    HCP4827 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ550 Maxim, XJ650 Maxim, and 1983 XJ750 Maxim models.
    $ 8.95
    HCP4822 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For all XJ650 Midnight Maxim, 1983 XJ750 Midnight Maxim, XJ1100, and all XS1100 Special and Midnight Special models. Each:
    $ 2.95
    HCP4828 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per tube (2 per bike) on both the left and right side lower fork tube. For all XJ550 Seca, FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), and XJ900RK, RL, N/FN, and F models. Each:
    $ 2.95
    HCP7273 OEM front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. Class 10.9 alloy steel sockethead cap screw with a bright finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 4.95
    HCP29771 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. Alloy steel sockethead cap screw with a black oxide finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 1.95
    HCP29772 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. Alloy steel sockethead cap screw with a bright zinc-flake finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 2.95
    HCP29773 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. 18/8 stainless steel sockethead cap screw with a bright finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 2.95
    HCP29774 Aftermarket front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. 316 stainless steel sockethead cap screw with a bright finish. For all 1992-95 and 1997-98 XJ600 Seca II models. Each:
    $ 3.95
    HCP20338 OEM front axle shaft-to-lower tube RETAINING BOLT, use 2 per bike on the left side lower fork tube. For all 1996 XJ600 Seca II models.
    $ 7.95
    HCP2325 OEM front axle shaft-to-lower tube RETAINING BOLT, use 1 per bike on the right side lower fork tube. For 1982 XJ750 Maxim and all XJ700 and XJ750-X models. Each:
    $ 3.95
    HCP2537 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all 1981 XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP3945 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all 1982-83 XJ550 Seca models. Use 2 per tube (4 per bike) on both the left and right side lower fork tube. Each:
    $ 4.95
    HCP26192 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 1.95
    HCP26193 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 18/8 stainless steel, bright finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 2.95
    HCP17110 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, 316 stainless steel, dull finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 3.95
    HCP26189 Aftermarket front axle shaft-to-lower tube retaining bolt FLAT WASHER, alloy steel, black finish, for all XJ550 Seca models, 1984-85 FJ600, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750RL, XJ750P (37H model), XJ700-X and XJ750-X models, XJ900RK, RL, N/FN, and F models. Use 2 per retaining bolt (4 per bike) on both the left and right side lower fork tubes. NOTE: XJ700-X and XJ750-X models only use 1 of the washers per bike). Each:
    $ 2.95
    HCP20322 OEM front axle shaft-to-lower tube retaining bolt FLAT WASHER, for all 1992-94 XJ600 Seca II models. Use 1 per retaining bolt (2 per bike) on the left side lower fork tube.
    $ 7.95
    HCP2185 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 6.95
    HCP2391 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 2 per bike on the following models: all 1982-83 XJ550 Seca, all XJ650 Turbo models. Use 1 per bike on all XJ650 Midnight Maxim and XJ750 Midnight Maxim models. Each:
    $ 7.95
    HCP16209 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 2.95
    HCP16100 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, 1984-85 FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 3.95
    HCP4824 OEM front axle shaft-to-lower tube retaining bolt LOCK WASHER, use 1 per bike on the following models: all 1981-83 XJ750 Seca and XJ750 Euro models. Each:
    $ 9.95
    HCP16209 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, zinc-plated alloy steel, use 1 per bike on the following models: all XJ550 Maxim models, FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 0.95
    HCP16100 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, 18-8 stainless-steel with a bright finish, use 1 per bike on the following models: all XJ550 Maxim models, FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each:
    $ 0.95
    HCP16102 Aftermarket front axle shaft-to-lower tube retaining bolt LOCK WASHER, black-oxide coated finish, use 1 per bike on the following models: all XJ550 Maxim models, FJ600, all XJ650 Maxim models, all XJ700 models, all 1982-83 XJ750 Maxim models, XJ750-X, and XJ1100 models. Use 2 per bike on the following models: all 1981 XJ550 Seca, all XJ650 Euro models, XJ650RJ Seca and XJ650 Turbo models, XJ750-D, XJ750P (37H model), and XJ900RK, RL, and F models. Each::
    $ 3.95
    HCP3494 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 3.95
    HCP24037 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, made from 18/8 stainless steel, use 1 per bike on the following models: all XJ550 Maxim models, all XJ650 (except Midnight Maxim) models, all XJ700 non-X models, all 1982-83 XJ750 Maxim, XJ750-D, and XJ1100 models. Use 2 per bike on the following models: all XJ550 Seca, 1984-85 FJ600, all XJ650 Euro models, XJ750RL, all XJ900RK, RL, N/FN, and F models, and 1979 XS1100 Special models. Each:
    $ 2.95
    HCP3495 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ650 Midnight Maxim and all XJ750 Midnight Maxim models. Each:
    $ 8.95
    HCP24038 Aftermarket front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ650 Midnight Maxim and all XJ750 Midnight Maxim models. Each:
    $ 3.95
    HCP4821 OEM front axle shaft-to-lower tube retaining bolt NUT, use 1 per bike on the following models: all XJ700-X and XJ750-X models. Each:
    $ 8.95
    Front Wheel Speedometer Drive Assembly Components:
    Your speedometer is driven off a drive unit mounted onto the left outer side of the wheel hub, and consists of the CLUTCH unit, the clutch RETAINER, and the large GEAR DRIVE UNIT. Although most non-functioning speedometers can be traced to more common sources of failure (the speedometer head itself, or more likely the speedometer drive cable), we offer these replacement drive units should the need arise.
    HCP1797 OEM speedometer gear drive METER CLUTCH, this is the double-tanged metal washer that rotates along with the wheel and drives the gear unit. For all XJ550, FJ600, XJ650, 1981-83 XJ750 models, XJ750RL, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models.
    $ 14.95
    HCP1798 OEM speedometer gear drive meter clutch RETAINER, flat "stepped" washer that retains the above meter clutch. For all XJ550, FJ600, XJ650, 1981-83 XJ750 models, XJ750RL, all XJ900RK, RL, N/FN, and F models, XJ1100, and XS1100 models.
    $ 7.95
    HCP19753 OEM speedometer drive meter clutch GEAR. For all 1978-79 XS1100 Standard models.
    $ 59.95
    HCP19752 OEM speedometer gear drive meter clutch FLAT WASHER, fits behind the drive gear. For all 1978-79 XS1100 Standard models.
    $ 5.95
    HCP19754 OEM speedometer gear drive meter clutch FLAT WASHER, fits in front of the drive gear. For all 1978-79 XS1100 Standard models.
    $ 5.95
    HCP19759 OEM speedometer gear unit SPRING PIN, fits into the gear unit housing and retains the driven gear. For all 1978-79 XS1100 Standard models.
    $ 6.95
    HCP1799 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all XJ550 Maxim, all XJ650 (except Turbo), and all 1981-83 XJ750 models.
    $ 159.95
    HCP20006 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all 1984-85 FJ600 and 1986-90 YX600 Radian models.
    $ 99.95
    HCP1802 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For XJ750RL and all XJ900RK, RL, N/FN, and F models.
    $ 189.95
    HCP1801 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all XJ700 and XJ750-X models.
    $ 189.95
    HCP19775 OEM speedometer gear drive GEAR UNIT, the large driven gear unit which your speedometer drive cable actually plugs into. For all XS1100 Standard models.
    $ 109.95
    REAR WHEEL BEARINGS, AXLE, AND CLUTCH HUB PARTS:
    and
    Inspection:
    Rear Wheel Bearing, Seals, and Kits:
    all XJ550, FJ600, and XJ600 Seca II rear wheel Bearings, Seals, and Bearing Kits:
    HCP1787 OEM rear wheel medium-duty BEARING, double-sealed, high speed ball bearing is an exact match of the original used in the right side of the wheel on all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986 SRX600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 1 per wheel. Each:
    $ 49.95
    HCP14336 Aftermarket rear wheel high-performance EXTREME-DUTY BEARING, double-sealed, high speed ball bearing is an exact match of the original used in the right side of the wheel on all XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986 SRX600, 1992-98 XJ600 Seca II, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use 1 per wheel. Each:
    $ 59.95
    HCP20054 OEM rear wheel medium-duty BEARING, single-seal, high speed ball bearing is an exact match of the original used on the left inner side of the wheel on all 1984-85 FJ600, 1986-88 FZ600, and 1986 SRX600 models. Each:
    $ 36.95
    HCP29030 OEM rear wheel medium-duty BEARING, single-seal, high speed ball bearing is an exact match of the original used on the left outer side of the wheel on all 1992-98 XJ600 Seca II models. Each:
    $ 62.95
    HCP1834 OEM rear wheel medium-duty BEARING, single-seal, high speed ball bearing is an exact match of the original used on the left side of the wheel on all XJ550, FJ600, YX600 Radian, XJ600 Seca II, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use in the following positions, and note that the sealed side of the bearing is to always be placed facing "outward", facing away from the other left side wheel bearing. XJ550, FJ600, and YX600 Radian models: use 1, in the inner position of the left side of the wheel hub. XJ600 Seca II models: use 2, in the inner positions of the left side of the wheel hub. XJ650, XJ700, and all XJ750 (except 750RL) models: use 2, in both the inner and outer position of the left side of the wheel hub. XJ750RL and all XJ900RK, RL, N/FN, and F models: use 1, in the outer position of the left side of the wheel hub. Each:
    $ 37.95
    HCP14331 Aftermarket rear wheel hi-performance EXTREME-DUTY BEARING, single-seal, high speed ball bearing is an exact match of the original used on the left side of the wheel on all XJ550, FJ600, YX600 Radian, XJ600 Seca II, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use in the following positions, and note that the sealed side of the bearing is to always be placed facing "outward", facing away from the other left side wheel bearing. XJ550, FJ600, and YX600 Radian models: use 1, in the inner position of the left side of the wheel hub. XJ600 Seca II models: use 2, in the inner positions of the left side of the wheel hub. XJ650, XJ700, and all XJ750 (except 750RL) models: use 2, in both the inner and outer position of the left side of the wheel hub. XJ750RL and all XJ900RK, RL, N/FN, and F models: use 1, in the outer position of the left side of the wheel hub. Each:
    $ 49.95
    HCP1836 OEM rear wheel medium-duty BEARING, double-sealed, high speed ball bearing is an exact match of the original used on XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986 SRX600, 1986-90 YX600 Radian, and XJ1100 models. Use in the following positions: XJ550, FJ600 , FZ600, SRX600, and YX600 models: use 1, in the outer position of the left side of the wheel hub. XJ1100 and XS1100 models: use 1, on the right side of the wheel hub.
    $ 64.95
    HCP14338 Aftermarket rear wheel high-performance EXTREME-DUTY BEARING, double-sealed, high speed ball bearing is an exact match of the original used on XJ550, 1984-85 FJ600, 1986-88 FZ600, 1986 SRX600, 1986-90 YX600 Radian, and XJ1100 models. Use in the following positions: XJ550, FJ600 , FZ600, SRX600, and YX600 models: use 1, in the outer position of the left side of the wheel hub. XJ1100 and XS1100 models: use 1, on the right side of the wheel hub.
    $ 79.95
    HCP27961 OEM rear wheel clutch hub OIL SEAL, for all XJ550, 1982-83 XS400, 1975 XS500B, 1973-74 TX500, 1982-83 XT550, 1984-95 XT600, 1993-94 GTS1000, 1991-95 FZR1000, and 1990-92 FJ1200 models. NOTE: this is the original 8mm thick seal; the replacement HCP4768 and HCP18756 seals below are only 7mm thick. The 7mm seals will work, but it’s worth mentioning that those replacement seals will seat deeper into the cavity and not “seal” quite as well due to the introduced gap. Use one per bike. Each:
    $ 24.95
    HCP27999 Aftermarket rear wheel clutch hub OIL SEAL, fits all XJ550, 1982-83 XS400, 1975 XS500B, 1973-74 TX500, 1982-83 XT550, 1984-95 XT600, 1993-94 GTS1000, 1991-95 FZR1000, and 1990-92 FJ1200 models. NOTE: this is the correct 8mm thick seal; the replacement HCP4768 and HCP18756 seals below are only 7mm thick. The 7mm seals will work, but it’s worth mentioning that those replacement seals will seat deeper into the cavity and not “seal” quite as well due to the introduced gap. Use one per bike. Each:
    $ 19.95
    HCP4768 OEM rear wheel clutch hub OIL SEAL, for all XJ550, 1982-83 XS400, 1975 XS500B, 1973-74 TX500, 1982-83 XT550, 1984-95 XT600, 1993-94 GTS1000, 1991-95 FZR1000, and 1990-92 FJ1200 models. NOTE: this is the replacement 7mm thick oil seal which is thinner than the original 8mm thick seal.. These 7mm seals will fit and work, but it’s worth mentioning that this thinner seal will seat deeper into the cavity and not “seal” quite as well due to the introduced gap. Use one per bike. Each:
    $ 17.95
    HCP18756 Aftermarket rear wheel clutch hub OIL SEAL, fits all XJ550, 1982-83 XS400, 1975 XS500B, 1973-74 TX500, 1982-83 XT550, 1984-95 XT600, 1993-94 GTS1000, 1991-95 FZR1000, and 1990-92 FJ1200 models. NOTE: this is the replacement 7mm thick oil seal which is thinner than the original 8mm thick seal.. These 7mm seals will fit and work, but it’s worth mentioning that this thinner seal will seat deeper into the cavity and not “seal” quite as well due to the introduced gap. Use one per bike. Each:
    $ 13.95
    HCP20073 OEM rear wheel clutch hub OIL SEAL, for all 1984-85 FJ600, 1986-88 FZ600, 1986 SRX600, and 1986-90 YX600 models. Use one per bike. Each:
    $ 17.95
    HCP20931 OEM rear wheel clutch hub OIL SEAL, for all 1992-98 XJ600 Seca II models. Use one per bike. Each:
    $ 13.95
    HCP4767 OEM rear wheel right side bearing OIL SEAL, use one. For use on 1986-88 FZ600, 1986 SRX600, 1992-98 XJ600 Seca II, 1984 XJ750RL, and all XJ900RK, RL, N/FN, and F models.
    $ 16.95
    HCP18757 Aftermarket rear wheel right side bearing OIL SEAL, use one. For use on 1986-88 FZ600, 1986 SRX600, 1992-98 XJ600 Seca II, 1984 XJ750RL, and all XJ900RK, RL, N/FN, and F models.
    $ 11.95
    HCP1917 Aftermarket complete rear wheel standard-duty BEARINGS AND SEALS KIT, for all XJ550 models. Three bearings and one seal comes with this kit. NOTE: the left side inner wheel bearing was originally a single-sealed bearing, not the double-sealed bearing as is included in this kit. It is recommended that one of the plastic seals be removed before installation (a small screwdriver can be used to gently pry it out). The sealed side of the bearing always faces "outward", away from the other inner bearing, when installed.
    $ 42.95
    HCP14325KIT OEM complete rear wheel medium-duty BEARINGS AND SEAL KIT, for all XJ550 models. Contains three bearings and one oil seal.
    $ 149.95
    HCP14383KIT Aftermarket complete rear wheel hi-performance EXTREME-DUTY BEARINGS AND SEAL KIT, for all XJ550 models. Contains three bearings and one oil seal.
    $ 189.95
    HCP19802 Aftermarket complete rear wheel standard-duty BEARINGS AND SEALS KIT, for all 1984-85 FJ600, 1986-88 FZ600, and 1986 SRX600 models. Three bearings and one seal comes with this kit.
    $ 44.95
    HCP26350 Aftermarket complete rear wheel standard-duty BEARINGS AND SEALS KIT, for all 1986-90 YX600 Radian models. Three bearings and one seal comes with this kit.
    $ 49.95
    HCP19749 Aftermarket complete rear wheel standard-duty BEARINGS AND SEALS KIT, for all XJ600 Seca II models. All four bearings and two grease seals are included in this kit.
    $ 59.95
    all XJ650, XJ700, and XJ750 (except XJ750RL models) rear wheel Bearings, Seals, and Bearing Kits:
    HCP1787 OEM rear wheel medium-duty BEARING, double-sealed, high speed ball bearing is an exact match of the original used in the right side of the wheel on all XJ550, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Use 1 per wheel. Each:
    $ 49.95
    HCP14336 Aftermarket rear wheel high-performance EXTREME-DUTY BEARING, double-sealed, high speed ball bearing is an exact match of the original used in the right side of the wheel on all XJ550, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Use 1 per wheel. Each:
    $ 59.95
    HCP1834 OEM rear wheel medium-duty BEARING, single-seal, high speed ball bearing is an exact match of the original used on the left side of the wheel on all XJ550, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Use in the following positions, and note that the sealed side of the bearing is to always be placed facing "outward", facing away from the other left side wheel bearing. XJ550 models: use 1, in the inner position of the left side of the wheel hub. XJ650, XJ700, and all XJ750 (except 750RL) models: use 2, in both the inner and outer position of the left side of the wheel hub. XJ750RL and all XJ900RK, RL, N/FN, and F models: use 1, in the outer position of the left side of the wheel hub. Each:
    $ 37.95
    $ 49.95
    HCP14336 Aftermarket rear wheel hi-performance EXTREME-DUTY BEARING, double-sealed, high speed ball bearing is an exact match of the original used in the right side of the wheel on all XJ550, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Use 1 per wheel. Each:
    $ 59.95
    HCP14331 Aftermarket rear wheel hi-performance EXTREME-DUTY BEARING, single-seal, high speed ball bearing is an exact match of the original used on the left side of the wheel on all XJ550, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Use in the following positions, and note that the sealed side of the bearing is to always be placed facing "outward", facing away from the other left side wheel bearing. XJ550 models: use 1, in the inner position of the left side of the wheel hub. XJ650, XJ700, and all XJ750 (except 750RL) models: use 2, in both the inner and outer position of the left side of the wheel hub. XJ750RL and all XJ900RK, RL, N/FN, and F models: use 1, in the outer position of the left side of the wheel hub. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Each:
    $ 49.95
    HCP1918 Aftermarket complete rear wheel standard-duty BEARINGS KIT, for all XJ650, XJ700, and XJ750 (except 1984 XJ750RL) models. Three bearings only, as no "bearing seals" were used on these models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. NOTE: the left side inner and outer wheel bearings were originally a single-sealed bearing, not the double-sealed bearing as is included in this kit. It is recommended that one of the plastic seals be removed before installation (a small screwdriver can be used to gently pry it out). The sealed side of the bearings always faces "outward", away from the other inner bearing, when installed.....thus the two inner bearings will have their "open" sides facing each other.
    $ 39.95
    HCP14315KIT OEM complete rear wheel medium-duty BEARINGS KIT, for all XJ650, XJ700, and XJ750 (except 1984 XJ750RL) models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Contains three bearings.
    $ 104.95
    HCP14384KIT Aftermarket complete rear wheel hi-performance EXTREME-DUTY BEARINGS KIT, for all XJ650, XJ700, and XJ750 (except 1984 XJ750RL) models. Also fits the following Virago models: 1984-87 XV700, 1981-87 XV750 (including 1983 Midnight version), 1982-83 XV920 (including 1983 Midnight model), 1984-85 XV1000, and 1986-99 XV1100 models. Contains three bearings.
    $ 124.95
    all XJ750RL and XJ900 rear wheel Bearings, Seals, and Bearing Kits:
    $ 49.95
    $ 59.95
    $ 37.95
    $ 49.95
    HCP1838 OEM rear wheel medium-duty BEARING, single-shield, high speed cylindrical roller bearing is an exact match of the original used on XJ750RL and all XJ900RK, RL, N/FN, and F models. Use in the following positions: in the inner position of the left side of the wheel hub.
    $ 339.95
    HCP4767 OEM rear wheel right side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1787 or HCP14336 wheel bearing listed above. For use on FJ600, XJ750RL, and all XJ900RK, RL, N/FN, and F models.
    $ 16.95
    HCP18757 Aftermarket rear wheel right side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1787 or HCP14336 wheel bearing listed above. For use on FJ600, XJ750RL, and all XJ900RK, RL, N/FN, and F models.
    $ 11.95
    HCP14326KIT OEM complete rear wheel medium-duty BEARINGS AND SEAL KIT, for all XJ750RL and XJ900RK, RL, N/FN, and F models. Contains three bearings and a grease seal.
    $ 399.95
    HCP14385KIT Aftermarket complete rear wheel hi-performance EXTREME-DUTY BEARINGS AND SEAL KIT, for all XJ750RL and XJ900RK, RL, N/FN, and F models. Contains three bearings and a grease seal. NOTE: this kit contains the stock OEM HCP1838 cylindrical bearing for the left inner position.
    $ 419.95
    all XJ1100 and XS1100 rear wheel Bearings, Seals, and Bearing Kits:
    $ 64.95
    $ 79.95
    HCP19583 Aftermarket rear wheel medium-duty BEARING, high speed cylindrical roller bearing is an exact match of the original used on all XJ1100 and XS1100 models. Use in the following position: in the left side of the rear wheel hub.
    $ 99.95
    HCP4755 OEM rear wheel right side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1836 or HCP14338 wheel bearing listed above. For XJ1100 and XS1100 models.
    $ 19.95
    HCP20952 Aftermarket rear wheel right side bearing OIL SEAL, use one. This seal goes on the outer face of the HCP1836 or HCP14338 wheel bearing listed above. For XJ1100 and XS1100 models.
    $ 16.95
    HCP4756 OEM rear wheel left side bearing OIL SEAL, use one. For all XJ1100 and XS1100 models.
    $ 16.95
    HCP19636 Aftermarket rear wheel left side bearing OIL SEAL, use one. For all XJ1100 and XS1100 Standard models.
    $ 12.95
    HCP4784 OEM rear wheel left side bearing and hub DUST BOOT, use one. For all XJ1100 and XS1100 models.
    $ 39.95
    HCP19584KIT Aftermarket complete rear wheel medium-duty BEARINGS AND SEALS KIT, for all XS1100 and XJ1100 models. Contains two bearings and their grease seals. NOTE: this kit contains the stock type cylindrical bearing for the left side.
    $ 179.95
    Rear Wheel Clutch Hub Parts:
    And while you've got the rear wheel off to replace the bearings, it's a great idea to inspect and replace those rear wheel clutch hub O-rings, Oil Seals, and clutch hub rubber Dampers as needed. NOTE: some models used either one, two, or three o-rings.
    HCP2327 OEM rear wheel clutch hub O-RING, for all XJ650, XJ700, all XJ750 models, and all XJ900RK, RL, N/FN, and F models. This o-ring has an outside diameter of approximately 64mm, and is very "fat" (3.5mm cross-section). Use one per bike, location varies by model as shown below.
    $ 14.95
    HCP20751 Aftermarket rear wheel clutch hub O-RING, for all XJ650, XJ700, all XJ750 models, and all XJ900RK, RL, N/FN, and F models This o-ring has an outside diameter of approximately 64mm, and is very "fat" (3.5mm cross-section). Use one per bike, location varies by model as shown below.
    $ 10.95
    XJ650 all models (except Turbo): on the outer side of the clutch hub.
    XJ650 Turbo: on the inner side of the clutch hub, at the wheel’s center hub splines.
    XJ700 all models: on the outer side of the clutch hub.
    XJ750-X models: on the outer side of the clutch hub.
    XJ750 all 1981-84 models: on the outer side of the clutch hub.
    XJ900 all models: on the outer side of the clutch hub.
    HCP4935 OEM rear wheel clutch hub O-RING, for all XJ650 Turbo, XJ700-X, XJ750-X, XJ750-D, XJ750RL, and all XJ900RK, RL, N/FN, and F models. This o-ring has an outside diameter of approximately 53mm, and has a 2.5mm cross-section. Use one per bike, location varies by model as shown below.
    $ 9.95
    HCP18759 Aftermarket rear wheel clutch hub O-RING, for all XJ650 Turbo, XJ700-X, XJ750-X, XJ750-D, XJ750RL, and all XJ900RK, RL, N/FN, and F models. This o-ring has an outside diameter of approximately 53mm, and has a 2.5mm cross-section. Use one per bike, location varies by model as shown below.
    $ 6.95
    XJ650 Turbo: on the outer side of clutch hub, at the outer position.
    XJ700-X: on the inner side of the clutch hub, at the outer position.
    XJ750-X: on the inner side of the clutch hub, at the outer position.
    XJ900 all: on the inner side of the clutch hub.
    HCP4932 OEM rear wheel clutch hub O-RING, for all XJ650 Turbo, XJ700-X, XJ750-X, and XJ750-D models. This o-ring has an outside diameter of approximately 65mm, and has a 2.5mm cross-section. Use one per bike, location varies by model as shown below.
    $ 16.95
    HCP20752 Aftermarket rear wheel clutch hub O-RING, for all XJ650 Turbo, XJ700-X, XJ750-X, and XJ750-D models. This o-ring has an outside diameter of approximately 65mm, and has a 2.5mm cross-section. Use one per bike, location varies by model as shown below.
    $ 11.95
    XJ650 Turbo: on the outer side of clutch hub, at the inner position.
    XJ700-X: on the inner side of the clutch hub, at the inner position.
    XJ750-X: on the inner side of the clutch hub, at the inner position.
    HCP4770 OEM rear wheel clutch hub inner O-RING, for all XJ1100 and XS1100 models. Use one per bike.
    $ 9.95
    HCP29258 OEM rear wheel clutch hub inner O-RING, for all XJ1100 and XS1100 models. Use one per bike.
    $ 7.95
    HCP4769 OEM rear wheel clutch hub outer O-RING, for all XJ1100 and XS1100 models. Use one per bike.
    $ 14.95
    HCP29257 Aftermarket rear wheel clutch hub outer O-RING, for all XJ1100 and XS1100 models. Use one per bike.
    $ 10.95
    HCP23165 OEM rear wheel clutch hub-to-wheel mounting BOLT. Use 6 per wheel on all on all 1984-85 FJ600 models. Each:
    $ 1.95
    HCP23165SET5 OEM rear wheel clutch hub-to-wheel mounting BOLTS, set of 6:
    $ 11.50
    HCP4763 OEM rear wheel clutch hub-to-wheel mounting BOLT. Use 5 per wheel on all on all 1982-83 XJ650 (except Turbo) Turbo models, all XJ700 non-X, and all 1981-83 XJ750 models. Each:
    $ 4.95
    HCP4763SET5 OEM rear wheel clutch hub-to-wheel mounting BOLTS, set of 5:
    $ 21.95
    HCP4764 OEM rear wheel clutch hub-to-wheel mounting TABBED LOCK WASHER, retains the nut to the stud via "bend-over" tab arms. Each washer spans three studs, so use 2 per wheel on all on all XJ650 Turbo models, all XJ700-X, and XJ750-X models. Each:
    $ 14.95
    HCP4764SET2 OEM rear wheel clutch hub-to-wheel mounting TABBED LOCK WASHER, set of 2:
    $ 28.95
    HCP23166 OEM rear wheel clutch hub-to-wheel threaded stud NUT, retains the hub to the stud. Use 6 per wheel, for all 1984-85 FJ600 models. Each:
    $ 4.95
    HCP23166SET6 OEM rear wheel clutch hub-to-wheel threaded stud NUTS, set of 6:
    $ 28.95
    HCP1764 OEM rear wheel clutch hub-to-wheel threaded stud NUT, retains the hub to the stud. Black alloy steel. Use 6 per wheel, for all XJ650 Turbo models, all XJ700-X, and XJ750-X models. Each:
    $ 3.95
    HCP1764SET6 OEM rear wheel clutch hub-to-wheel threaded stud NUTS, set of 6:
    $ 21.95
    HCP9925 Aftermarket rear wheel clutch hub-to-wheel threaded stud NUT, retains the hub to the stud. Bright zinc-plated alloy steel. Use 6 per wheel, for all XJ650 Turbo models, all XJ700-X, and XJ750-X models. Each:
    $ 1.95
    HCP9925SET6 Aftermarket rear wheel clutch hub-to-wheel threaded stud NUTS, set of 6:
    $ 10.95
    HCP9926 Aftermarket rear wheel clutch hub-to-wheel threaded stud NUT, retains the hub to the stud. Bright 18/8 stainless steel. Use 6 per wheel, for all XJ650 Turbo models, all XJ700-X, and XJ750-X models. Each:
    $ 3.95
    HCP9926SET6 Aftermarket rear wheel clutch hub-to-wheel threaded stud NUTS, set of 6:
    $ 19.95
    HCP4777 OEM rear wheel clutch hub rubber DAMPER, the siamesed triangular rubber wedges used on all XJ550 models and all XJ900RK, RL, N/FN, and F models. Use six per bike. Each:
    $ 14.95
    HCP4777SET6 OEM rear wheel clutch hub rubber DAMPERS, set of 6:
    $ 84.95
    HCP24291 OEM rear wheel clutch hub rubber DAMPER, the siamesed triangular rubber wedges used on all 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Use three per bike. Each:
    $ 59.95
    HCP24291SET3 OEM rear wheel clutch hub rubber DAMPERS, set of 3:
    $ 219.95
    HCP26242 Aftermarket rear wheel clutch hub rubber DAMPER, the siamesed triangular rubber wedges used on all 1984-85 FJ600, 1986-88 FZ600, and 1986-90 YX600 Radian models. Use three per bike. Each:
    $ 29.95
    HCP26242SET3 Aftermarket rear wheel clutch hub rubber DAMPERS, set of 3:
    $ 79.95
    HCP4776 OEM rear wheel clutch hub rubber DAMPER, these cylindrical metal-cased rubber bushings have the integral threaded stud and are used on all XJ650 Turbo models, XJ700-X, and XJ750-X models. Use six per bike. Each:
    $ 49.95
    HCP4776SET6 OEM rear wheel clutch hub rubber DAMPERS, set of 6:
    $ 279.95
    HCP4782 OEM rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW, with captive washer. Use 4 per wheel on all on all XJ650 all (except 1983 Turbo) models, all XJ700 non-X, all 1981-83 XJ750 models, and all XJ1100 and XS1100 models. Each:
    $ 8.95
    HCP4782SET4 OEM rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS, with captive washer. Set of 4:
    $ 32.95
    HCP60 OEM rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW. Use 4 per wheel on all on all XJ900 models. Zinc-plated alloy-steel, panhead, phillips-drive, each:
    $ 3.95
    HCP60SET4 OEM rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS. Set of 4:
    $ 11.50
    HCP910 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW. Use 4 per wheel on all on all XJ900 models. Zinc-plated alloy-steel, panhead, phillips-drive, each:
    $ 1.95
    HCP910SET4 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS. Set of 4:
    $ 6.95
    HCP62 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW. Use 4 per wheel on all on all XJ900 models. 18-8 stainless-steel, panhead, phillips-drive, each:
    $ 2.95
    HCP62SET4 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS. Set of 4:
    $ 9.95
    HCP308 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW. Use 4 per wheel on all on all XJ900 models. 18-8 stainless-steel, polished button head, hex-drive, each:
    $ 2.95
    HCP308SET4 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS. Set of 4:
    $ 9.95
    HCP310 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW. Use 4 per wheel on all on all XJ900 models. 18-8 stainless steel, smooth polished socket head, hex-drive, each:
    $ 2.95
    HCP310SET4 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS. Set of 4:
    $ 9.95
    HCP64 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREW. Use 4 per wheel on all on all XJ900 models. Black oxide-coated steel, ribbed socket head, hex-drive, each:
    $ 1.95
    HCP64SET4 Aftermarket rear wheel clutch hub cover plate ("shroud")-to-wheel mounting SCREWS. Set of 4:
    $ 6.95
    HCP4783 OEM rear wheel clutch hub cover plate ("shroud")-to-wheel mounting BOLT. Use 4 per wheel on all on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Each:
    $ 1.50
    HCP4783SET4 OEM rear wheel clutch hub cover plate ("shroud")-to-wheel mounting BOLTS. Set of 4:
    $ 5.75
    HCP306 OEM rear wheel clutch hub cover plate mounting bolt FLAT WASHER, bright zinc-plated alloy steel. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Use 1 per bolt. Each:
    $ 2.95
    HCP914 Aftermarket rear wheel clutch hub cover plate mounting bolt FLAT WASHER, bright zinc-plated alloy steel. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Use 1 per bolt. Each:
    $ 1.95
    HCP1353 Aftermarket rear wheel clutch hub cover plate mounting bolt FLAT WASHER, bright 18/8 stainless steel. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Use 1 per bolt. Each:
    $ 2.95
    HCP65 Aftermarket rear wheel clutch hub cover plate mounting bolt FLAT WASHER, black oxide-coated stainless steel. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Use 1 per bolt. Each:
    $ 2.95
    HCP55 OEM rear wheel clutch hub cover plate mounting bolt LOCK WASHER. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Zinc-plated alloy steel. Each:
    $ 1.95
    HCP913 Aftermarket rear wheel clutch hub cover plate mounting bolt LOCK WASHER. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Zinc-plated alloy steel. Each.
    $ 1.75
    HCP57 Aftermarket rear wheel clutch hub cover plate mounting bolt LOCK WASHER. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. 18-8 stainless steel. Each.
    $ 2.95
    HCP59 Aftermarket rear wheel clutch hub cover plate mounting bolt LOCK WASHER. Use with the HCP4783 bolt above on all 1983 XJ650 Turbo models, all XJ700-X, and XJ750-X models. Black oxide-coated alloy steel. Each.
    $ 1.95
    HCP21749 OEM rear wheel clutch hub cover plate mounting bolt FLAT WASHER, use 1 per bolt (total of 6 per hub) on all XJ1100 models. Each:
    $ 7.95
    HCP2230 OEM rear wheel clutch hub cover plate mounting bolt LOCK WASHER, use 1 per bolt (total of 6 per hub) on all XJ1100 models. Each:
    $ 7.95
    HCP22225 Aftermarket rear wheel clutch hub cover plate mounting bolt LOCK WASHER, zinc-plated alloy steel. Use 1 per bolt (total of 6 per hub) on all XJ1100 models. Each:
    $ 2.95
    HCP22227 Aftermarket rear wheel clutch hub cover plate mounting bolt LOCK WASHER, 18/8 stainless steel. Use 1 per bolt (total of 6 per hub) on all XJ1100 models. Each:
    $ 3.95
    HCP4775 OEM rear wheel clutch hub cover plate mounting bolt NUT, use 1 per bolt (total of 6 per hub) on all XJ1100 models. Each:
    $ 6.50
    Rear Wheel Axle Shafts and Hardware:
    HCP4799 OEM rear wheel AXLE SHAFT, for all XJ650, all XJ700, all 1981-83 XJ750 models, XJ750-D, XJ750-X, 1982-83 XZ550 RJ/RK Vision, 1982-83 XV750 Virago K/J, 1983 XV750 MK Midnight Virago, 1982-83 XV920 Virago J/K, and 1983 XV920 MK Midnight Virago models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 132.95
    HCP4810 OEM rear wheel AXLE SHAFT, for all XJ750RL and XJ900RK, RL, N/FN, and F models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 139.95
    HCP4809 OEM rear wheel AXLE SHAFT, for all XJ100 and XS1100 models. Does not include any accessory parts (washers, spacers, collars, etc.).
    $ 149.95
    HCP4801 OEM rear wheel axle shaft FLANGED CASTLE NUT, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. NOTE: this nut is the correct 22mm, dark-phosphate plated version of this nut as originally fitted onto all XJ550, XJ700, and XJ750-X models. All XJ650, XJ750 non-X, and XJ900 models used the same type of nut, but it had a smaller (19mm) hex, a smaller diameter flange, and natural finish. This larger nut will also fit these models properly.
    $ 13.95
    HCP4808 OEM rear wheel axle shaft CASTLE NUT, for all XJ1100 and XS1100 models. Correct 27mm hex, bright plated, non-flanged nut as original.
    $ 34.95
    HCP1805 OEM rear wheel axle shaft castle nut WASHER, for all XJ550 models.
    $ 5.95
    HCP2328 OEM rear wheel axle shaft castle nut WASHER, for all XJ650, all XJ700, all XJ750, and all XJ900RK, RL, N/FN, and F models.
    $ 6.95
    HCP4807 OEM rear wheel axle shaft castle nut WASHER, for all XJ1100 and XS1100 models.
    $ 5.95
    HCP1803 OEM rear wheel axle shaft castle nut COTTER PIN, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models.
    $ 8.95
    HCP16053 Aftermarket rear wheel axle shaft castle nut COTTER PIN, zinc-plated steel, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models.
    $ 4.95
    HCP16054 Aftermarket rear wheel axle shaft castle nut COTTER PIN, stainless steel, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models.
    $ 5.95
    HCP4928 OEM rear wheel axle shaft castle nut COTTER PIN, for all XJ1100 and XS1100 models.
    $ 8.95
    HCP16085 Aftermarket rear wheel axle shaft castle nut COTTER PIN, zinc-plated steel, for all XJ1100 and XS1100 models.
    $ 4.95
    HCP16086 Aftermarket rear wheel axle shaft castle nut COTTER PIN, stainless steel, for all XJ1100 and XS1100 models.
    $ 5.95
    HCP1795 OEM rear wheel axle shaft FLANGED SPACER RING, for all XJ550, FJ600, XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. This is the incredibly thin flanged shimming washer on the right side of the spacer tube, behind the right side wheel bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement. NOTE: the original “spacer flange” is larger in diameter than this replacement, and is trapped in a “well” cut into the wheel below the bearing pocket on the right side. The replacement does the same job; however, since it is smaller in diameter than the original spacer, it needs to be installed further onto the spacer tube so that it misses the “land” for the original and just does its spacing off the inside of the casting itself. Then it works fine…..it’s only there to make the spacer tube line up with the axle and prevent the tube from “falling down” and getting mis-aligned before inserting the axle shaft. A good explanation is shown here (about 1/2-way down the page):
    https://www.xjbikes.com/forums/threads/rear-wheel-bearing-replacement-how-to-w-pics.35134
    $ 8.95
    HCP4787 OEM rear wheel axle shaft FLANGED SPACER RING, for all XJ1100 and XS1100 models (except 1978 XS1100 Standard) models. This is the incredibly thin flanged shimming washer on the right side of the spacer tube, behind the right side wheel bearing. A necessary part and one that is easily damaged during bearing removal or forgotten during replacement.
    $ 8.95
    HCP4785 OEM rear wheel axle shaft bearing retaining CIRCLIP, for all XJ1100 and all 1979-81 XS1100 models. The large “c-cli[p” is fitted directly to the right of the right side wheel bearing (between the wheel bearing and the oil seal). Use 1 per bike. Each:
    $ 11.95
    HCP4765 OEM rear wheel axle shaft COLLAR, for all XJ550 Maxim, Seca, and Euro models and 1982-83 XS400 R/RJ/K/RK models. This is the 36mm long, flanged “waistline” shaped spacer hat is fitted into the rear wheel clutch hub unit and is on the inner side of the inner left side wheel bearing. Each:
    $ discontinued
    HCP28471 Aftermarket rear wheel axle shaft COLLAR, for all XJ550 Maxim, Seca, and Euro models and 1982-83 XS400 R/RJ/K/RK models. This is the 36mm long, flanged “waistline” shaped spacer hat is fitted into the rear wheel clutch hub unit and is on the inner side of the inner left side wheel bearing. Each:
    $ 39.95
    HCP4815 OEM rear wheel axle shaft COLLAR, for all XJ550 Maxim and 1986-90 YX600 Radian models. This is the 1-1/4" wide “hour-glass” shaped spacer that is fitted on the right side of the wheel, outside of the brake backing plate.
    $ 39.95
    HCP28472 Aftermarket rear wheel axle shaft COLLAR, for all XJ550 Maxim and 1986-90 YX600 Radian models. This is the 1-1/4" wide “hour-glass” shaped spacer that is fitted on the right side of the wheel, outside of the brake backing plate.
    $ 32.95
    HCP4816 OEM rear wheel axle shaft COLLAR, for all XJ550 Seca models. This is the 1-1/2" wide “hour-glass” shaped spacer that is fitted on the right side of the wheel, outside of the brake backing plate. Also fits the following non-XJ models: 1976-77 XS360 B/C/D/2D, 1978-79 XS400 2E/2F, 1982-83 XS400 J/RJ/K/RK, 1962-64 YD3, 1963 YDT1, 1962 YDS2, 1965-66 YM1, 1965-66 YDS3, 1967 YR1, 1968 YR2, 1969 R3, 1970-72 R5, 1969-70 DS6, 1972 DS7, 1973-75 RD250, and 1973-75 RD350 models. Each:
    $ discontinued
    HCP21013 Aftermarket rear wheel axle shaft COLLAR, for all XJ550 Seca models. This is the 1-1/2" wide “hour-glass” shaped spacer that is fitted on the right side of the wheel, outside of the brake backing plate. Also fits the following non-XJ models: 1976-77 XS360 B/C/D/2D, 1978-79 XS400 2E/2F, 1982-83 XS400 J/RJ/K/RK, 1962-64 YD3, 1963 YDT1, 1962 YDS2, 1965-66 YM1, 1965-66 YDS3, 1967 YR1, 1968 YR2, 1969 R3, 1970-72 R5, 1969-70 DS6, 1972 DS7, 1973-75 RD250, ad 1973-75 RD350 models. Each:
    $ 37.95
    HCP9315 OEM rear wheel axle shaft COLLAR, for all XJ550 and 1982-83 XS400 R/RJ/K/RK models. This is the 9/16" wide spacer that is fitted on the left side of the wheel, just inside of the chain puller assembly.
    $ discontinued
    HCP21014 Aftermarket rear wheel axle shaft COLLAR, for all XJ550 and 1982-83 XS400 R/RJ/K/RK models. This is the 9/16" wide spacer that is fitted on the left side of the wheel, just inside of the chain puller assembly.
    $ 22.95
    HCP20074 OEM rear wheel axle shaft COLLAR, for all FJ600 models. This is the spacer that is fitted on the left side of the brake backing plate.
    $ discontinued
    HCP4803 OEM rear wheel axle shaft COLLAR, for all XJ650, all XJ700, all XJ750, and all XJ900RK, RL, N/FN, and F models. This is the 5mm thick spacer washer that is fitted on the right side of the brake backing plate (all models except XJ900RK) and on the far right end of the axle shaft (XJ900RK models).
    $ 13.95
    HCP4813 OEM rear wheel axle shaft COLLAR. This is the 1/2" thick spacer washer that is fitted on the right side, just outside of the oil seal, on all 1993-98 XJ600 Seca II, 1986-88 FZ600, and all XJ900RK, RL, N/FN, and F models, as well as on the following models: 1986 SRX600, 1989-99 FZR600R, 1987 FZ700, 1986-87 FZX700 Fazer, 1986-88 FZ750, 1987 FZR750R, and 1987-88 FZR1000 models.
    $ 34.95
    HCP4806 OEM rear wheel axle shaft COLLAR, for all XJ550 Maxim and 1986-90 YX600 Radian models. This is the wide “hour-glass” shaped spacer that is fitted on the right side of the wheel, just inside of the brake backing plate (XS850, XS1100, and XJ1100 models) or just inside of the drive chain puller (XS650 models). Use 1 per bike on 1979-81 XS650 Special, 1980-81 XS850 Special, 1979-81 all XS1100 Specials, and XJ1100 models.
    $ 47.95
    HCP4751 OEM rear wheel center hub SPACER TUBE this 2-1/2" long tube spacer fits into the center of the wheel hub, and the HCP1795 flanged spacer ring fit onto the right end of it. For all XJ550 Seca, XJ650, XJ700, and all XJ750 (except XJ750RL models), as well as the following non-XJ models: 1982-83 XS400 J/RJ/K/RK, 1982-83 XZ550 RJ/RK, 1981-83 XV750 Virago, 1983 XV750MK Midnight Virago, 1982-83 XV920 Virago J/K, and 1983 XV920MK Midnight Virago models. Also fits the front wheel on all of these models: 1973 and 1975 RD250, 1973-75 RD350, 1976-78 RD400, 1973-74 TX500, and 1975-78 XS500 B/C/D/E models. Each:
    $ discontinued
    HCP21015 Aftermarket rear wheel center hub SPACER TUBE this 2-1/2" long tube spacer fits into the center of the wheel hub, and the HCP1795 flanged spacer ring fit onto the right end of it. For all XJ550 Seca, XJ650, XJ700, and all XJ750 (except XJ750RL models), as well as the following non-XJ models: 1982-83 XS400 J/RJ/K/RK, 1982-83 XZ550 RJ/RK, 1981-83 XV750 Virago, 1983 XV750MK Midnight Virago, 1982-83 XV920 Virago J/K, and 1983 XV920MK Midnight Virago models. Also fits the front wheel on all of these models: 1973 and 1975 RD250, 1973-75 RD350, 1976-78 RD400, 1973-74 TX500, and 1975-78 XS500 B/C/D/E models. Each:
    $ 27.95
    HCP4752 OEM rear wheel center hub SPACER TUBE this 2-1/2" long tube spacer fits into the wheel hub, and the HCP1795 flanged spacer ring fits onto the right end of it. For all XJ550 Maxim, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models, Each:
    $ 39.95
    HCP21016 Aftermarket rear wheel center hub SPACER TUBE this 2-1/2" long tube spacer fits into the wheel hub, and the HCP1795 flanged spacer ring fits onto the right end of it. For all XJ550 Maxim, 1984 XJ750RL Seca, and all XJ900RK, RL, N/FN, and F models, Each:
    $ 29.95
    HCP12325 OEM final drive output/wheel clutch hub SPACER TUBE this almost 3” long tube spacer fits on the wheel side of the final drive housing, into the splined clutch hub on the left side of the wheel. If this spacer is missing, you will not be able to align the rear wheel properly side-to-side within the swingarm. For all XJ650, XJ700, XJ750, and all XJ900RK, RL, N/FN, and F models. Each:
    $ 24.95
  2. chacal
    WHEEL BEARING/AXLE TOOLS:
    NOTE: SOME OF THE FOLLOWING TOOLS ARE AVAILABLE FOR RENTAL!!: some tools are a one-time or infrequent use tool, so it may be more economical for you to rent them from us, rather than to purchase outright. Please see the “rental” section within the THE TOOLBOX section of our catalog at:
    http://xjbikes.com/forums/index.php?threads/xj-parts-catalog-section-p-the-toolbox.44630
    and review the availability and procedures in the TOOL RENTAL section.
    A cheap and simple method for bearing removal and installation involves heating the bearing (so the ID of the race grows fractionally) while also cooling the shaft (so its OD shrinks). The combination of these two methods can make bearing work amazingly easier:
    heating:
    shrinking:
    These tricks work well for steering head bearing replacement, wheel bearing replacement, tranny gears, etc. For wheel bearings, you of course want to shrink the bearing and heat (somehow) the wheel hub (a good heat gun is an amazing tool...........).
    Wheel Bearing Removal Tool Kit:
    Sold individually or as a complete shop set, these 'split-collar" SPLIT-COLLAR BEARING PULLERS AND DRIFT TOOLS make removing wheel bearings a pleasure rather than a chore! No more trying to find the proper size and length drift rod and then clumsily using it inside a long, blind tool.........that's just "too" old-skool. These pullers are simply placed within the bearing shaft hole, the drift rod is entered into the split collar slot, you give the rod a good whack with a hammer, and out she comes! Turns a pain-in-the-butt procedure into a 1-minute operation. NOTE: since these pullers work by "grabbing" onto the inner bearing race, once they are used to remove a bearing, the bearing is no longer re-usable.
    A fine guide to wheel bearing replacement can be reviewed at:
    http://xjbikes.com/forums/index.php?threads/35134
    and
    http://www.xj4ever.com/wheel%20bearing% ... cement.pdf
    HCP17851 Aftermarket wheel bearing removal DRIFT ROD, special size tip properly fits all of the split-collar drivers below. You will need only one of these rods regardless of how many different size drivers you will use.
    $ 29.95
    HCP17853 Aftermarket wheel bearing removal SPLIT-COLLAR DRIVER, proper size for use on all XJ550, XJ650, XJ700, XJ750, and XJ900 front wheel bearings.
    $ 16.95
    HCP17854 Aftermarket wheel bearing removal SPLIT-COLLAR DRIVER, proper size for use on all XJ550 left inner or right side rear wheel bearings, and all inner and outer rear wheel bearings on all XJ650, XJ700, XJ750, and XJ900 models, as well as on XJ1100 and XS1100 front wheel bearings. NOTE: 1984 XJ750RL Seca and all XJ900 models use a cylindrical bearing on the left inner position, and a bearing puller is not necessary for removal of that bearing.
    $ 16.95
    HCP17855 Aftermarket wheel bearing removal SPLIT-COLLAR DRIVER, proper size for use on all XJ550 left outer side rear wheel bearing and XJ1100 and XS1100 right side rear wheel bearing.
    $ 16.95
    HCP17856 Aftermarket wheel bearing REMOVAL TOOLS KIT, one proper size drift and driver for use on all XJ550, XJ650, XJ700, XJ750, and XJ900 front wheel bearings.
    $ 44.95
    HCP17857 Aftermarket wheel bearing REMOVAL TOOLS KIT, one proper size drift and 2 drivers for use on all XJ550 rear wheel bearings.
    $ 59.95
    HCP17858 Aftermarket wheel bearing REMOVAL TOOLS KIT, one proper size drift and driver for use on all XJ650, XJ700, XJ750, and XJ900 rear wheel bearings or XJ1100 and all XS1100 front wheel bearings.
    $ 44.95
    HCP17859 Aftermarket wheel bearing REMOVAL TOOLS KIT, one proper size drift and driver for use on XJ1100 and all XS1100 rear wheel bearings.
    $ 44.95
    HCP17865 Aftermarket wheel bearing REMOVAL TOOL SET, one proper size drift and the 3 drivers for use on all XJ550 front and rear wheel bearings. NOTE: this kit contains all the drivers to also allow the removal of all front and rear wheel bearings on XJ650, XJ700, XJ750, XJ900, XJ1100, and all XS1100 models.
    $ 69.95
    HCP17866 Aftermarket wheel bearing REMOVAL TOOL SET, one proper size drift and the 2 drivers for use on all XJ650, XJ700, XJ750, and XJ900 front and rear wheel bearing removal.
    $ 59.95
    HCP17867 Aftermarket wheel bearing REMOVAL TOOL SET, one proper size drift and the 2 drivers for use on XJ1100 and all XS1100 front and rear wheel bearing removal.
    $ 59.95
    HCP7850 Aftermarket wheel bearing REMOVAL TOOL SET, heavy-duty complete set of 6 different size split-collar drivers and two drift rods allows you to service any model front or rear wheel bearings on all XJ-series bikes and many other models.
    $ 74.95
    Specialty Sockets and Wrenches:
    it56) Aftermarket specialty SOCKETS and ADAPTERS are for specific-use purposes as described below.
    HCP22023 Aftermarket extended depth 19mm SOCKET, used to remove the front wheel axle castle nut on XJ750RL and XJ900 models, and the rear axle castle nut on XJ650, 1981-83 XJ750, and XJ900 models. Chrome-plated, 6-point, 3/8" drive.
    $ 14.95
    HCP22024 Aftermarket extended depth 22mm SOCKET, used to remove the front wheel axle castle nut on XJ550, XJ650, 1981-83 XJ750, XJ1100 and XS1100 models, and the rear axle castle nut on XJ550, XJ700, and XJ750-X models. Chrome-plated, 6-point, 3/8" drive.
    $ 16.95
    HCP11336 Aftermarket standard depth 27mm SOCKET, used to remove your swingarm pivot bolt and nut on all XJ650 - XJ1100 models, and the rear axle castle nut on XJ1100 and XS1100 models. Chrome-plated, 6-point, 1/2" drive.
    $ 19.95
    HCP10300 Aftermarket 3/8"-to-1/2" DRIVE ADAPTER. For use with the HCP10298, HCP10299, HCP10530, HCP11336, HCP22025, or the HCP22947 sockets, and the 10mm and 12mm HCP10302 stud extractors included in the HCP10301 tool kit. Most people have the standard 3/8" drive ratchet wrenches in their tool kits already, and the larger 1/2" drive sockets can be used with those ratchets with this converter/adapter. Chrome-plated, 1/2" male drive, 3/8" female receiver.
    $ 13.95
    Super-Penetrant Fluids and Lubricants:
    Sometimes, the toughest part of working on a vehicle is battling the effects of time: seized fasteners, caused by rust, corrosion, and other factors, turns what should be a 5-minute effort into a 50-minute (or more) chore, complete with rounded-off, ruined, or snapped fasteners, e-z outs, heli-coil inserts, and more.........and that's just not right.
    While the proper use of our various Anti-Seize products will prevent these nightmares from occurring in the future, you're stuck in the here-and-now, and the best way to handle these obstacles is to have the proper tools at the stand-by; and in the case of fastener seizure, the proper "tool" is a can or two of our SUPER PENETRATING LUBRICANTS at the ready; a couple of squirts, a little bit of time-----perhaps some heat for those really nasty situations----and you're on your way again, hopefully not too much worse for the experience.....
    Great for use on all fasteners, fork tube cap bolts, intake and exhaust manifolds bolts, studs, and nuts, lock cylinder tumblers, or anywhere an un-cooperative fastener can be found. Can even be used to help un-seize frozen engines!
    Be aware that these products are not your typical, garden-variety, run-of-the-mill "retail" type products; these are designed an used as industrial- and military-strength products, meaning they have special formulations that include a dollop more of the "good stuff" within them to solve the toughest seizure problems imaginable (the "good stuff" ingredients cost more, and it is those compounds that are left out of or reduced in concentration in "retail" level consumer products).
    NOTE: the following product(s) can only be shipped via ground transport (which thus eliminates the postal Priority Mail, postal Express Mail, or private carrier Expedited levels of service for this item) and cannot (and will not----don't even ask!) be shipped outside of the continental USA. Additionally, there may be a per-package weight or quantity restriction, and thus multiple-unit orders of this product may have to be shipped in separate packages and will incur additional shipping charges.
    HCP10331 Aftermarket standard-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Oil-based lubricant penetrates down into spaces of one-millionth of an inch to handle the most reluctant seizures. Actually dissolves the rust and corrosion that causes the seizure; lubricates and displaces moisture to prevent rust re-formation. This product is what we use and recommend for freeing stuck fork tube cap bolts and other such challenging fasteners.
    $ 44.95
    HCP11974 Aftermarket super-duty PENETRATING LUBRICANT, in a generous 13-ounce aerosol can. Same as our standard-duty formula above, but also includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. The cat's-meow of penetrating fluids, can even be used to un-seize frozen engines or as an engine assembly lube! This fluid is also a great choice for use as a drive cable lubricant.
    $ 46.95
    HCP10333 Aftermarket extreme-duty PENETRATING LUBRICANT, in a generous 16-ounce aerosol can. Same as our standard-duty formula above, but also includes liquid silicone to enhance and speed up the penetrant action. This product is also an exceptional choice for use as a control-cable lubricant.
    $ 47.95
    Rust Removal and Prevention Fluids:
    rr4) Concentrated RUST REMOVER magically dissolves rust on all iron-based metals. Spray or wipe directly onto rusty parts, or immerse the items in a container full of this solution (diluted), let it work, then rinse off. Highly concentrated, easy to use, leaves the metal surfaces grease-free and ready for further processing or finishing. GREAT FOR DE-RUSTING THE INSIDE OF GAS TANKS!
    HCP12358 Aftermarket RUST DESTROYER FLUID, in a 16-ounce plastic bottle. Best to transfer into an old windex spray bottle (etc.) and use with a spray nozzle. After use, it is recommend that the de-rusted parts be immediately painted (or similar) or coated with fogging oil, lubricant, or other surface finish to prevent flash surface-rusting of the newly cleaned parts. Each:
    $ 39.95
    Here are a few other good ways to de-rust metal products:
    - soak iron (steel) parts in heated vinegar (doesn’t matter what kind) overnight, then rinse with clean water. and finally spray with fogging oil (or similar) to prevent rust from re-forming.
    http://www.mopedarmy.com/wiki/Removing_rust_from_a_gas_tank
    http://users.eastlink.ca/~pspencer/nsaeta/electrolysis.html
    http://www.moreg.org.au/dissolving_rust.htm
    http://www.htpaa.org.au/article-electro.php
    http://xjbikes.com/forums/index.php?threads/32838
    http://xjbikes.com/forums/index.php...val-no-frills-easiest-fastest-cheapest.48196/
    http://www.robertscycle.com/chrome-clean.html
    http://www.xjbikes.com/forums/threads/teds-2nd-82-xj750-maxim-bobber-project.47929/#post-478002
    http://www.practicalmachinist.com/vb/general-archive/rust-removal-using-molasses-90452/
    HCP11475 Aftermarket aerosol FOGGING OIL, top end lubricant coats, clings, and protects metal surfaces against rust and prevents ring seizure when an extended period of non-use is expected (winter storage). Spray directly into cylinders (thru the spark plug holes), rotate the engine over a few turns with the starter motor (but with plugs still removed-----do not allow the engine to start!) to spread the oil about, and your pistons, cylinders, rings will live happily ever after...............or, at least until you start up the engine next spring! 12-ounce can will fog many a cylinder, exhaust system component, fuel tank, etc.
    $ 22.95
    HCP20866 Aftermarket industrial-strength RUST PREVENTION COATING, in a standard 10-ounce aerosol can. This protectant goes on clear and prevents rust from forming on all surfaces (including bare metal) for up to a year, even in an outdoor environment. Can be applied over painted surfaces, or easily removed with mineral spirits. Great way to protect "work in progress" type projects.
    $ 34.95
    HCP20867 Aftermarket industrial-strength RUST PREVENTION COATING, in a standard 10-ounce aerosol can. Heavy-duty formula goes on clear, and then dries to a wax-like finish, prevents rust from forming on all surfaces (including bare metal) for up to a year, even in humid or outdoor environments. Easily removed with mineral spirits. Great way to protect "work in progress" type projects.
    $ 37.95
    Assembly Fluids and Lubricants:
    Wheel Bearing Grease:
    HCP8608 Aftermarket gear and bearing synthetic RED MOLY GREASE. High temperature, water resistant, extreme pressure and high-load strength synthetic organic moly grease is far superior to black moly disulfide (petroleum-based) products. Use on steering neck bearings, wheel bearings, starter motor gears, and swingarm bearings. 14 oz. tube.
    $ 29.95
    Anti-Seize Paste:
    xx1) Fastener ANTI-SEIZE PASTE. Yeah, it's smelly and makes a slippery mess on your fingers, but this stuff is a life-saver for any true wrencher, because it prevents problems down the road. Use it on any metal fastener that does not require a "loctite" thread-locker material to be used. This means on just about every fastener that is carb, engine case, or suspension-related! (except for carb upper and lower rack-mount screws and butterfly valve screws, which do require the use of a thread-lock fluid). If you think that it might, sometime, in the future, need to come off: use anti-seize compound! NOTE: the "base" metal material used in the different anti-seize pastes below do not determine what type of fastener to use such pastes on; it merely signifies what base material is used to create the anti-seize paste. You can use any "base-metal" anti-seize paste on any type of fastener and metal.
    NOTE: the use of anti-seize compounds will result in a TORQUE-MULTIPLYING EFFECT……..the result of a reduction in friction between the threaded contact points……and thus fasteners treated with anti-seize compound should have their torque values reduced by at least 10-15% when installed into steel material, and up to 25% into aluminum materials or other “soft” metals” (such as spark plugs into cylinder heads, or almost any other type of fastener into the engine) …… note that this rule applies only to service manual torque specifications on fasteners that are not indicated to be treated with anti-seize fluid by the factory …. if the factory manual specifies the use of an anti-seize coating, then the specified torque value for that fitting already takes into account the “reduced torque” necessary.
    http://raskcycle.com/techtip/webdoc14.html
    http://www.cncexpo.com/MetricBoltTorqueNm.aspx
    http://www.bmwmotorcycletech.info/sparkplugs.htm
    http://www.antiseize.com/pdf/torque_specifications.pdf
    HCP1264 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 1-ounce squeeze tube, for smaller jobs.
    $ 8.95
    HCP29921 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based in a 4-gram pillow pack, for individual jobs (enough for a single carb rack, or front-end rebuild, brake system rebuild, etc.)
    $ 3.95
    HCP1265 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in a 4-ounce tub with a brush-lid, for larger jobs.
    $ 9.95
    HCP9784 Aftermarket fastener ANTI-SEIZE PASTE, standard grade aluminum-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9763 Aftermarket fastener ANTI-SEIZE PASTE, standard-grade copper-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 13.95
    HCP9764 Aftermarket fastener ANTI-SEIZE PASTE, premium-grade nickel-based formula in an 8-ounce tub with a brush-lid, a lifetime supply for your motorcycle!
    $ 19.95
    xx2) The next most important tool: fastener THREAD LOCKER FLUIDS. Use on any fastener that you don't normally ever remove, to make sure that it stays that way. Comes in a variety of formulas, each one designed for a specific use as explained below. NOTE: the damper rod retaining bolt (in the very bottom of the fork tube lower leg, screwing up into the bottom of the damper rod) requires the use of the HCP1267 / HCP27756 medium-strength or the HCP1268 high-strength thread-locking fluid. Yamaha recommend the high-strength fluid, but we’ve found that the medium-strength fluid works as well and makes future dis-assembly a bit easier.
    HCP1266 Low Strength THREAD LOCKER FLUID, 6ml squeeze tube. This is a semi-permanent formula that provides moderate vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for upper and lower carb rack mount screws and the butterfly valve-to-throttle shaft retaining screws. A little bit goes a long way.......
    $ 11.95
    HCP1267 Semi-Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners.
    $ 11.95
    HCP27756 Semi-Permanent THREAD LOCKER FLUID, 0.5ml squeeze tube. This is semi-permanent formula that provides good vibration-loosening resistance, while still allowing for easy disassembly of the fastener with hand tools. This formula is recommended for use with 6-20mm fasteners. Small single-use tube is great for, well, small jobs!
    $ 4.95
    HCP1268 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is a high-strength formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP1269 Permanent THREAD LOCKER FLUID, 6ml squeeze tube. This is both a high-strength AND high-heat formula that provides superior vibration-loosening resistance, and requires the use of heat or special tools to break loose the fastener for disassembly.
    $ 11.95
    HCP20860 Aftermarket industrial-strength ASSEMBLY LUBE, in a standard 12-ounce aerosol can. Heavy-duty formula includes graphite to not only enhance and speed up the penetrant action, but also gets down into the pores of the metal for the greatest possible lubrication possible. Won't wash away, protect against rust and corrosion, stable from 0-degrees up to 250-F. This fluid is also a great choice for use as a drive cable lubricant.
    $ 41.95
    HCP20862 Aftermarket super-duty ASSEMBLY LUBE, in a generous 10-ounce aerosol can. The cat's-meow of lubricants, infused with pure moly disulfide, it goes on wet and then dries in 1-2 hours to a super-slick, high-pressure, hi-temp, bearing-like finish which provides the ultimate level of protection. Prevents rust and corrosion, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can even be used as an engine, tranny, and drivetrain assembly lube!
    $ 44.95
    HCP20863 Aftermarket super-duty GRAPHITE LUBE, in a generous 10-ounce aerosol can. The 800-pound gorilla of lubricants, it's infused with pure graphite, goes on wet, and then dries in 10 minutes to a super-slick, high-pressure, bearing-like finish which provides the ultimate level of protection. Prevents rust, won't wash off, throw off, and won't attract dust or dirt. Surfaces must be clean and dry of previous oils, etc. before application. Can be used as an engine assembly lube, bearing or bushing pre-lube, great for lock cylinders, and all metallic sliding surfaces. Use where dusty or dirty conditions render oil-based lubricants ineffective or undesirable.
    $ 42.95
  3. chacal
    SECTION L:
    WHEELS AND TIRES:
    -- Wheels and Tires.
    WHEELS AND TIRES:
    Unlike with automotive wheels and tires, there's no really good reasons why you can't do as good a job of changing tires and balancing your wheel/tire combo as a shop can. Although all the fancy tire dis-mount - mount machinery and spin-balancers are very impressive looking, they also add quite a bit of cost to the process (call around in your local area for pricing and you'll see what I mean!).
    By spending some labor time and effort yourself (for wheel removal and tire dis-mount and re-mounting; those are the big consumer of your time), the money you can save can easily pay for the cost of upgrading to some much nicer, high-quality tires, which is where the true safety and performance gains can be realized.
    We offer a complete variety of all the tools and products needed for you to perform these jobs. Also, be aware the best time to inspect and replace your wheel bearings are when the wheels are off the bike for a tire change, so don't forget to review those items, too.
    NOTE: If you feel unqualified in performing such actions, then by all means don't attempt these tasks yourself; however, if you can follow instructions and are have the patience and skills needed to do things correctly, then these tasks----and savings----are certainly achievable, even if it's your first time.
    Tire Valves:
    Maintaining proper air pressures in your tires is critical for both safety and performance....always check your tire air inflation for proper pressures before riding!
    NOTE: "Load" is the total weight of rider(s), cargo, and accessories (It does not include the weight of the motorcycle itself, nor the fuel, oil, etc.). “Cold” means the ambient air temperature before you begin riding; in other words, the tires (and the air inside them) must not already have been heated by previous riding, nor from being stored (for example) in a heated garage before riding on a freezing cold day, etc. “Sustained high-speed riding” means for longer freeway (etc.) riding conditions.
    The specification below are for bikes fitted with the stock size wheels and tires.
    XJ550 Maxim :
    load up to 198 lbs.: Front / Rear tire pressures: 26psi / 28psi cold
    load of 198-425 (max) lbs.: Front / Rear tire pressures: 28psi / 32psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 28psi / 32psi cold
    XJ550 Seca and Euro:
    load up to 198 lbs: Front / Rear tire pressures: 26psi / 28psi cold
    load of 198-423 (max) lbs.: Front / Rear tire pressures: 28psi / 40psi cold
    FJ600:
    load of 198-414 (max) lbs.: Front / Rear tire pressures: 28psi / 32psi cold
    XJ650 Maxim/Midnight Maxim:
    load up to 198 lbs.: Front / Rear tire pressures: 26 psi / 28psi cold
    load of 198-353 lbs.: Front / Rear tire pressures: 28psi / 32psi cold
    load of 353-507 (max) lbs: Front / Rear tire pressures: 28psi / 40psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 32psi / 36psi cold
    XJ650 Turbo:
    load of 198-366 (max) lbs.: Front / Rear tire pressures: 32psi / 36psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 28psi / 32 psi cold
    XJ650RJ Seca:
    load of 198-353 (max) lbs.: Front / Rear tire pressures: 28psi / 32psi cold
    load of 353-507 (max) lbs.: Front / Rear tire pressures: 28psi / 40psi cold
    XJ700 air-cooled:
    load of 198-542 (max) lbs.: Front / Rear tire pressures: 28psi / 40psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 30psi / 32 psi cold
    XJ700-X water-cooled:
    load of 198-525 (max) lbs.: Front / Rear tire pressures: 28psi / 40psi cold
    XJ750 Maxim/Midnight Maxim:
    load of 198-507 (max) lbs.: Front / Rear tire pressures: 28psi / 32psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 32psi / 32psi cold
    XJ750 Seca:
    load of 198-474 (max) lbs.: Front / Rear tire pressures: 28psi / 32psi cold
    XJ900RK:
    load up to 198 lbs: Front / Rear tire pressures: 32psi / 36psi cold
    load of 198-428 (max) lbs.: Front / Rear tire pressures: 36psi / 42psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 36psi / 42psi cold
    XJ1100:
    load of 198-407 (max) lbs.: Front / Rear tire pressures: 28psi / 40psi cold
    XS1100:
    load of 198-407 (max) lbs.: Front / Rear tire pressures: 28psi / 36psi cold
    Sustained high-speed riding: Front / Rear tire pressures: 36psi / 40psi cold
    Of course, there’s always a trade-off between tire traction and tire wear, which varies mainly due to riding style and tire inflation pressure . Lower pressures will typically increase tire temperatures, which then will soften the rubber and increase grip. This increased grip will cost you greatly in terms of tire tread life (and gas mileage) though. And total load (weight) will also affect tire temperatures -- the more weight , the greater the tire temperature (and thus the better the grip, and the less the tread life……..)..
    You should typically increase tire pressures when increasing the load. A good rule of thumb is to adjust your tire pressure such that the temperature increase causes the front tire pressure to increase 1 to 2 psi over cold, and the rear tire pressure increases 2 to 4 psi over cold (so, you will measure the tire pressures before riding (“cold”), and then measure the pressures after 15 or 20 minutes of riding. If the pressure increase is more than the above, add more pressure. If the pressure does not increase then you are over-inflated.
    Running the tire at the maximum pressure under all conditions means sacrificing grip when lightly loaded.
    All of the above motivates me to remind you that you should always “dress for the slide, not for the ride”……..
    HCP1773 OEM wheel rim complete TIRE VALVE, straight style, 1-1/2" stem height is approximately the same length as original. For all XJ-series bikes except the XJ700 or XJ750-X models on the rear wheel, which used a 90-degree angle (bent) stem. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. NOTE: some models may have used shorter valve stems. Each:
    $ 19.95
    HCP1773SET2 OEM wheel rim TIRE VALVES, straight style, set of 2:
    $ 37.95
    HCP9192 Aftermarket wheel rim complete TIRE VALVE, straight style, 1-1/2" stem height is approximately the same length as original. For all XJ-series bikes except the XJ700 or XJ750-X models on the rear wheel, which used a 90-degree angle (bent) stem. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. NOTE: some models may have used shorter valve stems. Each:
    $ 16.95
    HCP9192SET2 Aftermarket wheel rim TIRE VALVES, straight style, set of 2:
    $ 29.95
    HCP1763 OEM wheel rim complete TIRE VALVE, right-angle bent style, 1-1/2" stem height and 1-3/8" reach is approximately the same length as original. For all XJ700 and XJ750-X models on the rear wheel. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. Each:
    $ 22.95
    HCP1763SET2 OEM wheel rim TIRE VALVES, straight style, set of 2:
    $ 42.95
    HCP9193 Aftermarket wheel rim complete TIRE VALVE, right-angle bent style, 1-1/2" stem height and 1-3/8" reach is approximately the same length as original. For all XJ700 and XJ750-X models on the rear wheel. Complete valve includes the stem, internal valve, black plastic cap, o-ring, special washer, and two mounting nuts. Each:
    $ 16.95
    HCP9193SET2 Aftermarket wheel rim TIRE VALVES, straight style, set of 2:
    $ 29.95
    HCP9195 Aftermarket wheel rim VALVE STEM CAP, polished chrome acorn cap is a very close copy of the original metal screw-on cap (but lacks the central dimple). Replaces the plain black plastic caps that come on the replacement valve stems. Each:
    $ 3.95
    HCP9195SET2 Aftermarket wheel rim VALVE STEM CAPS, set of 2:
    $ 6.95
    HCP9194 Aftermarket wheel rim VALVE STEM CORE, internal brass valve core with o-ring exactly replaces leaking and damaged originals on all style (straight and bent) valve stems. If your stem is leaking air, this is the inexpensive way to fix it. Each:
    $ 2.95
    HCP9194SET2 Aftermarket wheel rim VALVE STEM CORES, set of 2:
    $ 4.95
    HCP9196 Aftermarket VALVE STEM TOOL, handy 4-in-1 tool allows you to properly remove and insert the stem core, and also clean/chase/re-thread the internal and external stem threads.
    $ 5.95
    HCP23811 Aftermarket PIVOTING-HEAD AIR CHUCK, heavy-duty aair chuck features a fully pivoting head with allows easy access in tight spaces!. Very high quality aluminum body has standard 1/4” NPT internal female threads which allows use with all standard air hose couplers and fittings.
    $ 39.95
    HCP23817 Aftermarket high performance DIGITAL AIR PRESSURE GAUGE, heavy-duty, battery-powered digital display air pressure gauge display pressures in 0.1psi increments and is accurate to +/- 0.6psi at any pressure reading. Round aluminum body has a shock-resistant rubber boot, large back-lit easy to read LED display, push-button pressure-release valve, 18” long rubber hose with dual swivels and a brass ball-type air chuck. Very high quality and much more accurate than standard tire pressure gauges, this gauge makes checking your tire pressure a job you’ll look forward to doing.
    $ 89.95
    Wheel Service Tools:
    HCP12960 Aftermarket wheel ROLL STAND. This nifty little device is specially designed for people who do not have a centerstand, as it allows the wheel/tire unit to be rotated as if the rear wheel was off of the ground.......even though it's not, as the tire is setting on this small square "stand" that has free-spinning rollers front and back (sort of like a chassis dyno). So you can roll the rear wheel into this "stand", but the bike on the side stand, and rotate the wheel/tire unit for chain maintenance (550 models) or other such activities. NOTE: not designed for operating the rear wheel under engine load!
    $ 79.95
    Tire Mounting Tools:
    Here's a variety of tools to make the chore of tire dis-mounting and mounting of your tires just a wee bit easier (and much less expensive than having a dealership perform these tasks!).
    HCP12959 Aftermarket portable TIRE CHANGING STAND. Looks like a small, short stool, and allows you to lay the wheel (with brake rotors or rear sprocket still installed) onto the stand, getting it up off the ground, and holds the wheel securely-----allowing you to lever the tire onto or off of the rim easily (without having to fight a moving wheel). Can be used on all XJ-series wheels.
    $ 159.95
    HCP1753 Aftermarket tire BEAD POPPER, this molded plastic wedge, when firmly whacked with a mallet or hammer, gently "pops" stuck tire beads away from the inner rim flange without risking damage to the wheel rim in this critical area.
    $ 29.95
    HCP1754 Aftermarket tire BEAD SETTER. This large, tough molded rubber donut "o-ring", when placed between one lip of the tire and the rim, allows a tire to be inflated and the beads set "automatically" (instead of having to struggle trying to hold both tire beads against the rim). As soon as the opposite bead sets against the rim, the rising air pressure forces this bead setter out from the other side, thus seating the beads easily, quickly, and with a minimum of effort. For 16" wheels as used on the rear of all XJ550 Maxim, XJ650 Maxim, XJ750 Maxim, and XJ1100 models.
    $ 119.95
    HCP1755 Aftermarket tire BEAD SETTER. This large, tough molded rubber donut "o-ring", when placed between one lip of the tire and the rim, allows a tire to be inflated and the beads set "automatically" (instead of having to struggle trying to hold both tire beads against the rim). As soon as the opposite bead sets against the rim, the rising air pressure forces this bead setter out from the other side, thus seating the beads easily, quickly, and with a minimum of effort. For 18-19" wheels as used on the front or rear of all XJ-series bikes.
    $ 119.95
    HCP1750 Aftermarket TIRE SPOON, 10" cupped "spoon" is safer to use on tubed tires than the tire irons listed below when removing the tire from the wheel. Plastic handle.
    $ 24.95
    HCP1751 Aftermarket TIRE SPOON, 16" cupped "spoon" is safer to use on tubed tires than the tire irons listed below when removing the tire from the wheel. Aluminum handle.
    $ 39.95
    HCP9772 Aftermarket CURVED TIRE IRON, 15" cast steel tire "pry bar" helps you lever the wheel bead over the edge of the tire safely and without risking damage to your wheel rims or the tire. You will need to use 2-3 tire irons (a mix of straight and curved versions) to mount a tire.
    $ 21.95
    HCP9773 Aftermarket STRAIGHT TIRE IRON, 16" forged steel tire "pry bar" helps you lever the wheel bead over the edge of the tire safely and without risking damage to your wheel rims or the tire. You will need to use 2-3 tire irons (a mix of straight and curved versions) to mount a tire.
    $ 21.95
    HCP1749 Aftermarket pair of nylon RIM EDGE PROTECTORS, these curved plastic guards, placed under the above tire irons, provide the utmost in protection from rim edge damage when changing tires.
    $ 17.95
    Wheel Weights and Wheel Balancing Tools:
    HCP10490 Aftermarket WHEEL BALANCER. Contrary to popular belief, you don't have to spin-balance motorcycle wheels to achieve satisfactory results. With this simple tool, and a pair of hi-rise common jackstands ("hi-rise" means more than 15" lift off the floor level), you can professionally balance your own tire/wheel assembly. High quality tool-steel axle, low-drag bearings, and precision-machined wheel holder collets provide you with the means to spin-balance all XJ-series wheels in a matter of minutes. Set-up and balancing directions are included. Properly cared for (meaning: don't drop it or beat on it!), this balance will last a lifetime. WARNING: this device (and your knowledge of how to use it correctly) will tend to make you real popular with other bike owners............
    $ 179.95
    HCP1747 Aftermarket wheel rim STICK-ON WEIGHT, 7-gram (.25 ounce), black finish, self-adhesive backing. For all XJ-series bikes. Each:
    $ 6.95
    HCP1747SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
    $ 21.95
    HCP1748 Aftermarket wheel rim STICK-ON WEIGHT, 7-gram (.25 ounce), chrome finish, self-adhesive backing. For all XJ-series bikes. Each:
    $ 6.95
    HCP1748SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
    $ 21.95
    HCP10546 Aftermarket wheel rim STICK-ON WEIGHT, 7-gram (.25 ounce), natural finish, self-adhesive backing. For all XJ-series bikes. Each:
    $ 6.95
    HCP10546SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
    $ 21.95
    HCP4834 OEM wheel rim CLIP-ON WEIGHT, 10-gram (.353 ounce). For all XJ-series bikes. Each:
    $ 16.95
    HCP4834SET4 OEM wheel rim WHEEL WEIGHTS, set of 4:
    $ 59.95
    HCP9197 Aftermarket wheel rim CLIP-ON WEIGHT, 10-gram (.353 ounce), slightly wider than original. For all XJ-series bikes. Each:
    $ 11.95
    HCP9197SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
    $ 39.95
    HCP4835 OEM wheel rim CLIP-ON WEIGHT, 20-gram (.706 ounce). For all XJ-series bikes. Each:
    $ discontinued
    HCP9198 Aftermarket wheel rim CLIP-ON WEIGHT, 20-gram (.706 ounce), slightly wider than original. For all XJ-series bikes. Each:
    $ 11.95
    HCP9198SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
    $ 39.95
    HCP4836 OEM wheel rim CLIP-ON WEIGHT, 30-gram (1.06 ounce). For all XJ-series bikes. Each:
    $ discontinued
    HCP9199 Aftermarket wheel rim CLIP-ON WEIGHT, 30-gram (1.06 ounce), slightly wider than original. For all XJ-series bikes. Each:
    $ 11.95
    HCP9199SET4 Aftermarket wheel rim WHEEL WEIGHTS, set of 4:
    $ 39.95
    HCP12956 Aftermarket clip-on weight INSTALLATION and REMOVAL TOOL, for use with OEM or aftermarket clip-on style wheel weights only. For all XJ-series bikes. Each:
    $ 19.95
    HCP12955 Aftermarket clip-on weight INSTALLATION and REMOVAL TOOL, for use with OEM or aftermarket clip-on style wheel or spoke weights. For all XJ-series bikes. Each:
    $ 24.95
    HCP12957 Aftermarket stick-on weight REMOVAL TOOL, for use with OEM or aftermarket stick-on style wheel weights only. For all XJ-series bikes. Each:
    $ 11.95
  4. chacal
    iv
  5. chacal
    .v.
  6. chacal
    v.
  7. chacal
    v..
  8. chacal
    v...
  9. chacal
    .x
  10. chacal
    .x.
Thread Status:
Not open for further replies.
