Xj550 clutch cable
Discussion in 'XJ Technical Chat' started by Craig middlemore, Nov 10, 2018.
  1. Craig middlemore
    Craig middlemore Member
    Warrington england
    So I have took my clutch cable off due to having to take the clutch case off for repair.
    I've come to put it back together but the when I pull the clutch in the whole cable sticks .
    The wire doesn't seam to move freely in the case .
    It was perfectly fine before I took it off. Is this a new cable need or am I missing something.
    Looked on youtube but can't seam to find anything that helps
    did you take cable completly off the bike or just disconnect it from clutch cover?
    start by lubing the cable.
    does it move freely if it is disconnected from pivot arm?
    check your routing is it pinch by exhaust?
    is the wire clip on the down tube pinching the cable?
    Chitwood likes this.
  3. k-moe
    Is the return spring in place on the clutch throwout arm?
  4. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Most common is you have the cable routed all jackass and there's a sharp bend in it causing it. To stick.. :)
  5. Craig middlemore
    Warrington england
    I've sorted it thank you . Looks like the person who had the bike before me did a short cut fit on a stretched cable. I'll be ordering a new one
