Xj650 won’t fire up just cranks
Discussion in 'XJ Technical Chat' started by Ryanyamaha, Dec 19, 2017.
  1. Ryanyamaha
    Ryanyamaha New Member
    Norfolk va
    Hey kinda new to working on bikes and trying to learn. I’m a Yamaha outboard mechanic. I have a 83 xj650 that I got from a kid cheap been sitting a few months he claims... I got it so it sparks on all 4 cylinders ,compression is 130 across and I’ve cleaned the carbs when I took them apart they were
    Not dirty but when trying to start it was not passing fuel through.. I’ve done lots of carbs with work and I cleaned these with ultrasonic cleaner when all apart but I’m still having same issue with it all back together. It will crank and crank but not fire up then when I check plugs there dry!! Why isn’t fuel passing through? Turn petcock on and crack drain screws and carbs are getting fuel just not passing through to motor to fire? Also
    Never messed with carbs that have slide diagrams but they all looked good when I put back and I noticed petcock is one without a vacuum which I’ve read should be fine on these bikes.. any idea of direction to go now would help thanks guys
  2. hogfiddles
    Floats too high.....
    Clogged jets....
    Clogged enricher system.....
    Weak battery......
    Bad electricals.....
    What exactly did you do to "clean the carburetors"
    Stumplifter likes this.
  3. Jetfixer
    Welcome ..go to upper right corner of page click on xj4ever ..go to information overload hour and read.... The Church of Clean. because carbs are 30 plus years old and you do not know what P.O. did or did not do. One big item that is overlooked is to properly clean carbs is full tear down and soak , so ALL rubber seals and O rings need to be REPLACED , the butterfly seals 2 per carb need to be removed and replaced with new seals if not vacuum leaks will result . New seals can be purchased from xj4ever...You will NOT find these on eBay. If you have soaked carbs with these seals still installed it will the seals to perish and leak. To remove you have to separate carb bodies from rails this is "breaking the rack" , pull the butterfly plate by removing the 2 small screws , remove 10mm nut on one side and the E clip on other and slide shaft out this exposes the seals on both sides. From the sounds of your issue your fuel enrichment (choke) is plugged up and your main jet circuit is plugged and as Hogfiddles stated your float level is off . Good luck
  4. Ryanyamaha
    Norfolk va
    I didn’t break rack but completely took apart and soaked in dip tank and then ultrasonic cleaner I clean a lot of carbs at work but there yamaha outboards not to much different.. is here a vacuum issue I’m missing? I see people talk about the vacuum line to the petcock I don’t have one on mine just one fuel line from petcock to carbs?? Is that ok?
  5. Jetfixer
    The vacuum line goes from carb boot nipple usually #3 carb to the petcock , the petcock is put to the ON position , if you put it in PRI this will flow without requiring vacuum ...assuming that you still have OEM petcock . Many folks put after market petcocks in and don't use vacuum at all( I prefer the stock as this way you do not forget to turn off fuel = crankcase full of fuel = stuck float or needle and seat not fully sealing )
  6. Ryanyamaha
    Norfolk va
    Ya I thinks it’s aftermarket no vacuum line on petcock
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    but you know that they are....
    You need to go to Church.
    http://xjbikes.com/forums/threads/in-the-church-of-clean.14692/
  8. hogfiddles
    Fwiw---I do offer carb rebuild services if you need.....
  9. Jetfixer
    One other item not asked are you running PODS or stock airbox? PODS are a waste of time and require jetting experimenting ...CV carbs do not function as designed with them.
  10. hogfiddles
    Even with pods, it should at least fire up, and the plugs should indicate the presence of fuel
    Ryanyamaha likes this.
  11. k-moe
    The second is not possible without doing the first.
    The soaking killed the throttle shaft seals, but as Hogfiddles said, it should at least try to fire if all the jets and passages are clean.
  12. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Did you bench sync the carbs? Could be the butterfly’s are completely closed.
  13. Ryanyamaha
    Norfolk va
    Yes i bench synced them I’m going to go back through carbs and see if I missed something but I’m pretty good with carbs been doing then years.. I could understand if one or 2 were messing up but For all 4 to not be passing fuel through I feel something else is up just didn’t know if there was a vacuum missing or the aftermarket petcock would affect it.. just for all not to be getting fuel I feel something is missing or not
    Doing its job
  14. tabaka45
    Brunswick, Georgia
    Pay special attention to the pilot jet, pilot system passages, and the enrichment (choke) system. My bet is they are clogged up. Or, you could just send the carbs to Hogfiddles and get them back perfect. By the way, can you get it to fire with starter fluid?
  15. Ryanyamaha
    Norfolk va
    Haven’t tried started fluid but went I sprayed carb cleaner to try and get a quick fire it pops and kinda backfires
  16. tabaka45
    Brunswick, Georgia
    Try starter fluid just to see if it will run a little. The take the carbs off and fully clean them. See the Church of Clean referenced above. Take it from personal experience, there are no short cuts and these carbs/bikes aren’t like outboards. Plus, these carbs are 35+ years old.
  17. Ryanyamaha
    Norfolk va
  18. k-moe
    Oh yes there are. It just happens that none of them lead to the correct destination. ;)
  19. hogfiddles
    And the shortcuts always take longer......
  20. Ryanyamaha
    Norfolk va
    Well tried starting fluid just to see if it would fire up for a second before I take carbs back off and nope! Just pops and backfires don’t actually start..! So not sure what’s going on
  21. tabaka45
    Brunswick, Georgia
    Pull the carbs and throughly clean them according to the Church of Clean. And refer to Hogfiddle’s and K-Moe’s comments above. I can personally vouch for their accuracy. You can do it right the second time or be hard headed like me and do it several more times.
  22. hogfiddles
    Hey, verify for us which wire leads go to which plugs.... wondering if you have leads mixed up
  23. Ryanyamaha
    Norfolk va
    1,4 on coil and 2 and 3 on other coil
  24. Ryanyamaha
    Norfolk va
    What order should they go left to right
  25. hogfiddles
    Sitting on bike, 1 to your left knee; 4 to your right knee.
    Now which coil is 1/4 coming from, and which is 2/3 coming from
  26. Ryanyamaha
    Norfolk va
    Coil to my left knee goes from 4 then to 1 then coil to the right goes 2 then 3
  27. Ryanyamaha
    Norfolk va
    Update update after some research I reliazed my coils were plugged up backwards orange to gray and they to orange after I switched the plugs and tried starting fluid bike started right up!!
  28. tabaka45
    Brunswick, Georgia
    Doggies! Hogfiddles is good!
  29. Ryanyamaha
    Norfolk va
    Well
    Probally still not getting fuel lol but it did fire right up when I switched coil plugs then shot up to about 12k before I turned it off lol
    Don’t think firing order has anything to do with fuel delivery on these
  30. Ryanyamaha
    Norfolk va
    Is this right?
