1982 maximum 650 wiring diagnostics again.
Discussion in 'XJ Technical Chat' started by Austinhall maxim, Sep 30, 2020.
  1. Austinhall maxim
    Austinhall maxim New Member
    Westvalley ny
    It started off Iost my turn signals neutral light, break light, and rpm tach would quit working if I hit the rear break or used the turn signal. Ik somethings grounded or not grounding any advise would be amazing. I went through that whole entire bike beginning of summer but I need help
  2. Rooster53
    First of all welcome to XJbikes
    That statement is kind of lacking on details but anyways this may be your issue. The fuse box is prone to corrosion that causes the clips to break and consequently a poor connection or no connection at all. The two links below cover the issue quite well.
    https://www.xjbikes.com/forums/threads/your-fuse-box-a-ticking-bomb-by-rick-massey.2210/
    https://www.xjbikes.com/forums/threads/how-to-install-an-aftermarket-fuse-box.6350/
  3. bigfitz52
    Or something really bad is happening inside the headlight shell, like a loose or exposed wire or two... but yeah, stock fusebox is a weak link as well.
